Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo General
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Jul 24, 2009, 10:38 PM   #1
Personal Sales Rating: (1)
Garage is empty, add now
Drives: 2008 Mitsubishi Evo X
Points: 3,304, Level: 35
Points: 3,304, Level: 35 Points: 3,304, Level: 35 Points: 3,304, Level: 35
Daily Activity: 0.4%
Daily Activity: 0.4% Daily Activity: 0.4% Daily Activity: 0.4%
Car won't start right away..pls help.
so i have a 2003 evo 8 and had gotten the ACT clutch XTSS and prolite flywheel installed.. the car in the beginning runs great and smooth.. still breaking in the clutch.. at about 300 miles now.. after which the problem started. after shutting the engine of the car to go in the house and eat, i come back out to turn it on and the car just wouldn't turn on.. i tried to turn the car on several times but no crank.. jus a click.. battery is working because all the lights are on. tried again still no crank but jus a clicking noise. after 7 minutes of continues torture the car decides to turn on and since then the car is able to start on its on even after shutting the engine.
the car then would be okay for a couple of days..3 days later the same thing happened. i would shut the whole car off and after a few minutes wouldn't turn on.. try again and nothing.. and after a couple of minutes it would turn on again and be okay for a couple of days. i really don't know whats goin guys.
the car would never shut off while running but would jus not start when the whole car is shut off..
at first thought it was the starter but then the car would start after a few minutes..
then again happened for the third time today. this time the boost gauge was reading 0 and so does the greddy spec b boost controller. can it be the starter then? my mechanic said the my solenoid is going bad.. can that be the problem and reason the car wouldn't start? what should i do?
thank you
from a concerned evo owner
Tristan
Online
Old Jul 24, 2009, 10:42 PM   #2
TS8
Personal Sales Rating: (15)
Drives: 03 EVO8
Points: 4,592, Level: 43
Points: 4,592, Level: 43 Points: 4,592, Level: 43 Points: 4,592, Level: 43
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
I had a problem like this when my battery connections were little loose.
Take your time and look for any loose connections.
Offline
Old Jul 24, 2009, 10:45 PM   #3
D420mac's Avatar
Drives: Tarmack Black 2006 EVO IX MR "Black Beast", Gunmetal Grey 2007 Outlander, Octane Blue 2008 EVO GSR
Points: 2,313, Level: 29
Points: 2,313, Level: 29 Points: 2,313, Level: 29 Points: 2,313, Level: 29
Daily Activity: 0%
Send a message via Yahoo to D420mac
it's your fly wheel, sometines the starter hangs up on it. put your car in gear open the door and give it a slight nudge by pushing on the pavement, rocking the car and see if that works. mine does the same thing.
__________________
2006 Tarmack Black EVO IX MR Highly Modded 711WHP 603 TQ "Black Beast"
2007 Gun metal Grey Outlander XLS stock
2008 Octane Blue EVO X GSR Stock for now....
"Get Boosted"
Check out my website:
http://mitsubishievoix.ning.com/
Offline
Old Jul 24, 2009, 10:49 PM   #4
D420mac's Avatar
Daily Activity: 0%
if it is clicking it may be the battery, but my light weight flywheel does the same thing, but when I turn the key it's just one click, it does not turn over and the battery voltage indicator goes from 12VDC to about zero because the starter is drawing so much current trying to spin the flywheel.
__________________
"Get Boosted"
Offline
Old Jul 24, 2009, 10:51 PM   #5
do i need to change the solenoid? checked everywher for loose connections but didn't see anything. i just don't want to get stuck in the middle of nowhere. can any test figure out whats goin on? is this a serious problem?
Online
Old Jul 24, 2009, 10:54 PM   #6
yeah thats exactly what i hear.. just one click. no cranking. but it would continue to do that for a couple of minutes.. then when you least expect it the car would jus start. i'm so lost.. should i get a new battery?
Online
Old Jul 24, 2009, 11:03 PM   #7
what should i do? considering i have to bring this car to get dyno tuned next friday
Online
Old Jul 24, 2009, 11:34 PM   #8
D420mac's Avatar
Daily Activity: 0%
you said it does this only after the new clutch and flywheel correct?
Dude it's not the Battery I told you that in the first place, it's the starter hanging up on the flywheel. turn the key a few times if that dosent work put your car in gear on a flat surface, clutch petal out and rock it back and forth a few times, and then push the clutch in and it should start up, if it dosent work the first time do it again until it starts. It's common with the light weight flywheel's that's a fact.
but it could be the starter, but usually you will not hear the click. The click is the solenoid pushing out the starter gear, which sometimes hangs up on the aftermarket flywheels. Normally you would just change the whole starter if there any issues with it, but I don't believe there is because it sounds like it is working since you hear it everytime you try to start the car.
If it sounds like click click click click..etc when you turn the key, or there is no power no fuel pump, no lights, nothing then it may be the battery is dead but after reading your OP it does not sound like the battery!
__________________
"Get Boosted"
Offline
Old Jul 29, 2009, 05:24 PM   #9
Personal Sales Rating: (0)
Points: 1,871, Level: 25
Points: 1,871, Level: 25 Points: 1,871, Level: 25 Points: 1,871, Level: 25
Daily Activity: 0%
If it didn't start after you were driving a while, then it probably isn't the battery. The drive should've charged up the battery, even if you have one that's on it's way out. But, won't hurt to test the voltage.
Offline
Old Jul 29, 2009, 06:15 PM   #10
Personal Sales Rating: (18)
DIDYSIS's Avatar
Drives: Evo 9 MR
Points: 3,023, Level: 33
Points: 3,023, Level: 33 Points: 3,023, Level: 33 Points: 3,023, Level: 33
Daily Activity: 0%
any updates?
Offline
Old Jul 30, 2009, 05:37 PM   #11
thanks d420mac.. well i been tryin to do what you said.. after a while it does start up..but so far so good.. thanks for the help.. i appreciate it.
Online
Old Jul 30, 2009, 06:00 PM   #12
Personal Sales Rating: (9)
EatSleepBoost's Avatar
Drives: bby 8
Points: 5,252, Level: 46
Points: 5,252, Level: 46 Points: 5,252, Level: 46 Points: 5,252, Level: 46
put a starter in it.
__________________
2.4L Fp green
Offline
Old Jul 30, 2009, 06:30 PM   #13
Personal Sales Rating: (19)
1d10t's Avatar
Drives: 2005 RR Rs
Points: 4,813, Level: 44
Points: 4,813, Level: 44 Points: 4,813, Level: 44 Points: 4,813, Level: 44
Send a message via MSN to 1d10t
I would think if the starter was hanging up on the flywheel, that the main fuse would blow.
Take it to a shop, not the internet. Sounds a lot like a dying battery cell to me. If you hear the solenoid of the starter click, the solenoids doin its job, but with out enough amperage to spin the motor. Maybe the voltage regulator is going out on your alternator?
Take it to a shop that can perform the necessary tests
__________________
RIP
DamnITzMe (Mekee Xiong)
F/S
30,000 miles
Oem intake mani w/ tb (milspec shaft seals) pm me
Offline
Old Jul 31, 2009, 08:26 AM   #14
D420mac's Avatar
Daily Activity: 0%
it started after he replaced the clutch, and flywheel. It must be the battery. When it does it on my car it blows no fuze, but it does draw alot of current, and causes my battery meter to peg all the way over to zero volts, and as soon as I turn the key back it pops right back to 11+-1Vdc. I have an optima yellow top. and in my case it's the flywheel.
__________________
"Get Boosted"
Offline
Old Jul 31, 2009, 08:14 PM   #15
Personal Sales Rating: (3)
MitsuJDM's Avatar
Drives: '05 VIII, '98 Malibu
Points: 10,402, Level: 67
Points: 10,402, Level: 67 Points: 10,402, Level: 67 Points: 10,402, Level: 67
Daily Activity: 1.4%
Daily Activity: 1.4% Daily Activity: 1.4% Daily Activity: 1.4%
Send a message via AIM to MitsuJDM
I'm thinking it's starter/flywheel related. Mine will do this from time to time. Probably once out of every 15-20 times I start my car. Not enough that I'm too concerned. After 5-6 attempts the car will start right up.
A bad battery will crank slow and car the car to make many rapid clicks once it quits trying to crank. And usually a battery doesn't SUDDENLY go bad. You should notice the car cranking slower, and slower and slower as the days go on, but most people don't notice it until it's completly shot. If the car makes a single click and won't turn over, but will eventually start up with no issue, it is NOT the battery. It's a starter/flywheel issue. It's almost as if the ring gear and the starter don't want to line up when you hit the key. Like D420mac said, try rocking the car. I personally have never tried this, but it makes sense. I'm going to give it a try next time mine gives me trouble
__________________
-Rich-
My Photography
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
away, car, clicking, clicks, days, doesnt, eventually, regulator, shut, start, starting, starts, turnover, voltage, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
