Gauges with adjustable brightness
Old Feb 7, 2009, 05:43 PM
getcha's Avatar
Hi, and yes I searched(search function opens up cases of cans of worms) and yes I've read the mfg stuff.
I am curious to find out what gauges have adjustable backlights.
I will be going more than likely with an Oil Temp and Oil Pressure then probably Boost or wideband depending.
I wanted something with a warning and or peak but for at night I really dont like being peripherally blinded, I like a darkish cockpit
I would look for the old greddy warnings but im not sure if they are backlight adjustable or if many/any are for that matter
Thanks in advance everyone
EDIT: White face is not needed however is preferred
Old Feb 7, 2009, 07:20 PM
Akisan2's Avatar
Defis are the gauges that have all the features you are looking for.(if you don't mind the $$)
Old Feb 7, 2009, 07:41 PM
bboy_RES's Avatar
+1 for the Defi gauges. you can use the Control Unit II to change the brightness of the gauges.
Old Feb 7, 2009, 08:51 PM
metal4all6's Avatar
Yep, you can adjust the Defi gauges I have them and it's nice to be able to adjust them depending on how bright it is outside.
Old Feb 8, 2009, 08:14 AM
EvoDom's Avatar
Defi
Old Feb 8, 2009, 11:03 AM
EvowagonIX's Avatar
Defi rules
Old Feb 8, 2009, 11:06 AM
Former Vendor
Curt@MrLed's Avatar
Or you can hook them up to the interior lights and use the stock dimmer switch.
Old Feb 8, 2009, 05:32 PM
getcha's Avatar
Really...? I could probably get the defi warning gauges and do it that way right? Do you think it would shorten the light life of them?
If the dimmer switch was at say 25% from the off position would they all have the same level of brightness?
Can you PM me an idea of how to do this?
Old Feb 8, 2009, 06:45 PM
nothere's Avatar
most nice gauges have that feature.
such as proparts or
prosports spec
plus you don't need the "box" with all the other gauges.
