Intermediate shaft stuck in t-case
Old Jun 1, 2020, 10:11 AM
yellowevo82's Avatar
Any ideas for me to get this out . C clip must of been warn can’t remove the intermediate shaft from t-case. Slide hammer isn’t working
Old Jun 1, 2020, 12:58 PM
Ozwald's Avatar
That happend to me before.
The hole in the center should be threaded.
Put in a bolt and a slide hammer will pop her out.
Other way would be take the other side off and run a long punch though the tranny.
Old Jun 1, 2020, 01:23 PM
heel2toe's Avatar
What is your slide hammer method? It seems to always work for me so perhaps there is something silly that is limiting you? Also, may I ask why you are removing it? The xcase can be pulled with that one still installed so perhaps you dont even need to remove it just yet?
Old Jun 1, 2020, 01:41 PM
Put the long shaft on passenger side. Wrong side. I have a wave track so you can’t pop it out from other side. Used a slide hammer and 5lb hammer and it won’t budge.
Old Jun 1, 2020, 01:50 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
The wave trace are a super tight fit. You have to really get after it with the slide hammer.
Old Jun 1, 2020, 01:51 PM
That’s what shep told me .. My. Next step is to hook a tow strap up to my side by side and pull that way
Old Jun 1, 2020, 02:17 PM
heel2toe's Avatar
Lol make sure to setup the camera before doing that! I still think a good solid whack with the slide hammer should do the trick. Are you using the hook thingies to grab the bolt head? One cool trick I was told was use the attachment for the 2 jaw puller and just slip the bolt head inside that if that makes sense.
The other trick you could do is use a bolt, nut and a spacer. Thread bolt into the half shaft then turn the nut which will move that inward untill it pressed up against the spacer and acts a a means to pull the entire shaft out. Not sure I explained that well but think about it and hopefully it'll make sense.
Old Jun 1, 2020, 03:15 PM
Not working
Old Jun 1, 2020, 03:29 PM
^^^^^^ F this intermediate shaft!!! Finally got it after I took the skirt off and hit it with my purse!
Old Jun 1, 2020, 03:36 PM
heel2toe's Avatar
Hah! You weren't kidding about the tow strap! That slide hammer looks a little small btw. But hey it worked so all good, glad you got it sorted
Old Jun 1, 2020, 04:31 PM
hutch959's Avatar
my slide hammer is 3 times that size.
go bigger next time!
DontStopMe (Jun 2, 2020)
Old Jun 1, 2020, 06:48 PM
It’s not cheap ... it’s double the size of my last one
Old Jun 4, 2020, 05:39 AM
Ozwald's Avatar
Slide hammer for the win!!!!!!!!!!!!!!!!!!!!
BuiltS13
15
Jan 23, 2011 10:15 PM
BuiltS13
Northwest Region
Jan 23, 2011 02:19 AM
Xearo
Jan 15, 2011 09:17 AM
ryanlao
Oct 30, 2008 01:00 PM
insanechief
10
Aug 18, 2008 04:17 PM
Quick Reply: Intermediate shaft stuck in t-case
