Mar 11, 2009, 11:50 AM
Personal Sales Rating: ( 5)
Drives: GG IX MR
Sweet write up man  I was just about to start searching for all of this stuff, perfect timing hahah
Don
Offline
Mar 16, 2009, 11:53 PM
Personal Sales Rating: ( 0)
Drives: 2005 Evo & 2008 Lancer GTS
good looking guys... this is good stuff!
Offline
Apr 15, 2009, 07:20 PM
Drives: 2006 GG Evo IX MR
If any one would like to know its 6.3 qts for Radiator fluid.
__________________
Tein MonoFlex w/EDFC-Techna Fit SS Clutch Line w/Pill Delete-Tanabe Medallion Concept G Blue TBE-StopTech SS Brake Lines-Seibon CF Fenders, Hood, Trunk-Rotora Rotors/Pads-Ralliart Rad Cap/Shroud-Progress 27mm Rear Sway-Mishimoto Rad-K&N Filter/MAF Adapter-JDM IX Rear Bumper-Helix o2 Housing/Test Pipe-Greddy Oil Catch Can-Dejon Tool MBC-Competition Clutch-Apexi Turbo Timer
Quote:
Originally Posted by el producto
After 60k if you drove your Evo how it was suppose to, you either totaled it or blew the motor..
Offline
May 21, 2009, 02:51 PM
Personal Sales Rating: ( 6)
Drives: 2006 Mitsubishi Evolution IX
where can I get oem coolant for an evo 9?
Offline
May 30, 2009, 08:36 AM
Drives: White ix MR
Very nice post
__________________
2006 White MR
Offline
May 31, 2009, 10:51 PM
Personal Sales Rating: ( 4)
Drives: Modded RS
do our stock brembo's use the regular mitsubishi brake fluid pictured here?
__________________
2004 Rally Red EVO 8 RS
AEM EMS, Speed-Density Conversion, Buschur Open Intake Filter, Hallman Evolution MBC, AMS I/C, AMS Race Battery Kit, Buschur Upper I/C Pipe, Fighter's Garage Lower I/C Pipe, Walbro Fuel Pump, HKS 280 I/E Cams, HKS BOV, Helix 3-Inch Turbo-Back Race Exhaust, AMS Front Motor Mount
Offline
Jun 4, 2009, 06:44 AM
Drives: 09 RG Ralliart "Myra"
is this the same for the 09RA?
__________________
"Myra"
Tuned by AMS
13.5
Offline
Jun 16, 2009, 09:44 PM
Drives: Evo 8
water pump
anyone knows when ya have to change the water pump?
Offline
Jun 28, 2009, 10:18 AM
Personal Sales Rating: ( 10)
Drives: 06 TB IX
I want to say 60k. But don't quote me on it.
Offline
Jun 28, 2009, 01:40 PM
Personal Sales Rating: ( 37)
Drives: a ~500 AWHP 05 LY EVO 8 like a grandma
Thanks for this thread!
Offline
Jul 21, 2009, 08:29 AM
Personal Sales Rating: ( 2)
Drives: Mirage
Coolant ratio
I purchased the gallon of coolant from RussellM. What are you using as the ratio of coolant to distilled water?
I'm assuming the Mitsu Coolant is straight coolant and not pre-mixed. I believe the capacity of the radiator is 6.3 qt. (a little over 1.5 gallons). I have 1 gallon of coolant (1qt. = 0.25 gallons or there are 4 qt. to1 gallon). I was thinking of putting in 3/4 of the coolant container which would equal to about 3 quarts. The rest would be topped off with distilled water which would give me a ratio of about 48% coolant vs 63% if I used the entire gallon.
So when I do this do I first fill up the coolant reservoir with coolant and then put the rest in the radiator; topping the radiator off with the water?
Offline
Jul 28, 2009, 09:23 AM
Drives: 2006 evo IX mr carbon fiber hood and a 8 front bumper
when do you have to change your rear diff fluids?
__________________
2006 evo IX mr
3'Magnaflow exhaust
Resonated test pipe
3" downpipe
aem wideband O2
Defi gauges
Buschur MBC
Aem Short Ram intake
Offline
Jul 29, 2009, 08:29 AM
bump
__________________
2006 evo IX mr
3'Magnaflow exhaust
Resonated test pipe
3" downpipe
aem wideband O2
Defi gauges
Buschur MBC
Offline
Aug 4, 2009, 06:41 PM
Personal Sales Rating: ( 23)
Drives: 06 Evo MR
^30k. Thanks for the writeup, chaotix! Any part #'s on the belts before I dig them up on my own?
Offline
Aug 5, 2009, 02:41 PM
Personal Sales Rating: ( 91)
Drives: ix mr
link to timing belt kits
Timing Belt Kits w/ Gates Belts
for individual belts...pm russellm
Online
Tags
2009, atf, capacity, diamond, differential, evo, evolution, fluid, ix, lancer, limited, maintenance, mitsubishi, mr, oil, ps, scheduled, slip  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
