Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo General
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Mar 20, 2006, 01:00 PM   #1
Personal Sales Rating: (5)
Garage is empty, add now
Drives: 05 Evo
Points: 6,778, Level: 54
Points: 6,778, Level: 54 Points: 6,778, Level: 54 Points: 6,778, Level: 54
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Weird scraping noise from Engine or under the car(?) HELP~
During slow speeds or coming to stop I can hear some kind of scraping sound near by engine(?) or under the car. Noise only occurs when decelerating, when I step on the gas VERY lightly at around 2000-3000rpm. It sounds like something is loose or rub against other metal. I checked under the car and suspension but all seems fine. I even replaced my high-flow cat to factory OEM cat, guessing that might be the problem, well it wasn't.
Has anyone heard similar noises coming from the engine area when decelerating?
Could it be BOV? or Throttle body?
My current mods are: Forge MBC, MR BOV, Upper inter cooler pipe, K&N drop-in filter, HKS down pipe, Fujitsub cat back.
Offline
Old Mar 20, 2006, 01:18 PM   #2
Personal Sales Rating: (10)
Lancematic's Avatar
Drives: 05 Evo VIII
Points: 6,157, Level: 51
Points: 6,157, Level: 51 Points: 6,157, Level: 51 Points: 6,157, Level: 51
Daily Activity: 0%
Maybe your downpipe is loose on your o2 housing? Just another thing to check....
__________________
05' Blue VIII
AEM EMS, QTP E-cutout w/ stock exhaust, HKS 272's, Custom Intake, Megan Racing Turbo Manifold, Tubular O2 Housing, Buschur Deluxe FMIC, ARP head studs, AEM EBC
Currently 371whp, 333 Torque
11.782 @ 116.39
Offline
Old Mar 20, 2006, 01:19 PM   #3
Personal Sales Rating: (0)
Points: 6,255, Level: 51
Points: 6,255, Level: 51 Points: 6,255, Level: 51 Points: 6,255, Level: 51
Daily Activity: 0%
dude... its an evo... unless my car breaks down im not worried about noises...
Offline
Old Mar 20, 2006, 01:24 PM   #4
Personal Sales Rating: (2)
el producto's Avatar
Drives: a big boosted 4 banger
Points: 6,370, Level: 52
Points: 6,370, Level: 52 Points: 6,370, Level: 52 Points: 6,370, Level: 52
Daily Activity: 0%
yea I've got a weird sound going slow in that RPM range but its more of a knocking noise, im not too worried because the car still runs perfect.
__________________
HKS272s.Walbro.UNOS.ACTHD6PKSPRNG.UICP.LICP.TBE.Parlez vous, francais, mi amor, merci, oui oui, bon bons
and all that good stuff
Offline
Old Mar 20, 2006, 01:25 PM   #5
djscoto's Avatar
Drives: a quiet IX GSR of the Apex Silver variety
Points: 8,285, Level: 61
Points: 8,285, Level: 61 Points: 8,285, Level: 61 Points: 8,285, Level: 61
Daily Activity: 0%
Send a message via AIM to djscoto Send a message via Yahoo to djscoto
I heard the same kind of noise on my IX when I had about 100 miles on her. It sounded like a stick was stuck under the car and scraping on the ground. It went away and to this day I cannot replicate it. I will just blame it on rust on the rear brake rotors... But this is just an assumption to make me feel better.
__________________
[insert some clever statement here]
///Alpine || Perrin || Corbeau || GSC || CompuStar
My Corbeau Harnesses
If you like electronic music... TechnoMF.com
Offline
Old Mar 20, 2006, 01:33 PM   #6
Daily Activity: 0%
Quote:
hehe
Offline
Old Mar 20, 2006, 01:44 PM   #7
Rod Munch's Avatar
Drives: Phoenix Red SSL IX
Points: 7,664, Level: 58
Points: 7,664, Level: 58 Points: 7,664, Level: 58 Points: 7,664, Level: 58
Daily Activity: 0%
Or it could be something caught in your brakes. You could try raising each corner and rotating each wheel by hand, one by one.
Offline
Old Mar 20, 2006, 01:51 PM   #8
djscoto's Avatar
Daily Activity: 0%
Quote:
Very good suggestion
__________________
Offline
Old Mar 20, 2006, 01:55 PM   #9
Personal Sales Rating: (6)
twinscrewed's Avatar
Drives: 08 Ram 2500 Diesel, 08 Harley Rocker C, 03 Cobra
Points: 5,808, Level: 49
Points: 5,808, Level: 49 Points: 5,808, Level: 49 Points: 5,808, Level: 49
Daily Activity: 0%
My car is making the same sound. Metal on metal scraping, most audible when decelerating, coming from under car, etc. The sound goes away when i push in the clutch. I don't want to say its your t-case for sure, but be prepared. When i described the sound to Shepherd he said the ring & pinion are shot.
Offline
Old Mar 20, 2006, 02:55 PM   #10
Drives: 05 Evo
Daily Activity: 0%
wow, looks like I'm not the only one!
I'm not really sure if it's anything to do with ring & pinion cuz it only makes noise in between 2000-3000rpm when decelerating.
I'm gonna check the brake tonight and will post the result.
Offline
Old Mar 20, 2006, 03:08 PM   #11
Daily Activity: 0%
While accelerating and decelerating, I can only hear the noise at lower rpms. Mainly because at higher rpms the engine is louder and drowns it out. But its there. Does the sound go away when you push in the clutch pedal? How about when braking? Does it get louder, quieter, no change at all?
Offline
Old Mar 20, 2006, 03:19 PM   #12
Drives: 05 Evo
Daily Activity: 0%
Quote:
On mine, noise is not heard when accelerating, it occurs only when decelerating only at certain RPM range (2000 - 3000rpm)
When I push in the clutch pedal or when I brake, the noise seems go away because that will get me out of 2000-3000rpm range in most cases. When gear is neutral, there's no noise even at 2000-3000rpm range.
This noise drives me crazy....
Offline
Old Mar 20, 2006, 03:26 PM   #13
Personal Sales Rating: (25)
Drives: 05 GG Evo VIII MR
Points: 5,796, Level: 49
Points: 5,796, Level: 49 Points: 5,796, Level: 49 Points: 5,796, Level: 49
Daily Activity: 0%
is it when you barely have your foot on the gas?
Offline
Old Mar 20, 2006, 03:28 PM   #14
Rod Munch's Avatar
Daily Activity: 0%
It's not your brakes if putting it in neutral makes the noise disappear.
__________________
OK, call it "Cali" if you must.
Offline
Old Mar 20, 2006, 03:35 PM   #15
Daily Activity: 0%
I know what you mean. I hate it too. Makes me cringe. Next time you go out get the car into 5th and bring it to around 2800-3000 rpms. Let off the throttle, but do not brake. If you hear the noise, push in the clutch and see if it goes away. Like yours, mine will not make the sound at all with the clutch disengaged or if I put it in neutral while coasting.
If it turns out not being your brakes, give Shepherd or TRE a call and explain whats happening. You should get a more definitive answer from them then you will get on here.
If I go out tonight i'm going to try to make a recording of the sound. My camera should pick it up.
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
accelerating, brake, brakes, car, engine, making, metal, noise, rpms, scraping, scrapping, sound, sounds, underneath, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
