Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo General
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Mar 5, 2006, 04:14 PM   #1
Personal Sales Rating: (0)
Garage is empty, add now
forbidden color's Avatar
Drives: EVO
p0117- need help
ok, this time it's my car.
p0117 code is coming up over and over again after I clear it.
Engine Coolant Temperature Circuit Low Input.
I've accidently tapped the wire (yellow pin 83) with a ground wire for the wideband.
Wideband works after we tapped the right ground wire and power source.
Now the car starts up real weak, fan comes up then shuts down.
it's killing me, cause I have no idea how to fix this...
I"m in a different town and the only mechanic in this town is out for a vacation for this whole week.
I can't even have the car start up.
I'm thinking it's something to do with the sensor, but i have no idea...
any help will be great.
Thanks.
Offline
Old Mar 5, 2006, 04:24 PM   #2
Drives: EVO
ttt need some help real fast...
Offline
Old Mar 5, 2006, 04:57 PM   #3
Drives: EVO
anybody????? Evo down! Need a backup!
Offline
Old Mar 5, 2006, 05:13 PM   #4
Personal Sales Rating: (4)
BuLocal's Avatar
Drives: Z06 Vette(SOLD!!!), Civic, Evo VIII(Sold!!!)
Have you tried disconecting your battery or clearing the code? May not be that simple but either way here's a bump for the cause.
__________________
Attn Mitsubishi: Any and all modifications to my vehicle are equal or higher in quality and performance to those that were provided stock. As such under Title 15 Chapter 50 of U.S. Code (aka the Magnusson-Moss Warranty Act of 1975) particularly Section 2302(c) Mitsubishi must honor the warranty as provided with the car. Any refusal of service must be accompanied by absolute proof that an aftermarket component was the cause of any failure in the OEM materials. Failure to adhere to the letter and spirit of the law will result in prompt legal action against Mitsubishi and/or their authorized dealer.
Offline
Old Mar 5, 2006, 05:38 PM   #5
Drives: EVO
yeh, i've cleared it with my code clearer (orange thing) and then after that i've hard reset it by disconnecting the battery and leaving it for 30 minutes, then replug.
Now the car runs, but it's running lean when the foot is off the throttle. Then it tries to shut itself down.
Also the fan is constantly on!
I'm thinking it maybe the coolant temperature sensor... I don't even know where that is.
So I'm gonna go do some research but I need some help on this topic, if anyone has done this or went through this...
Thanks...
So far, online searching came to 0 conclusion, since it's not something that happens often...
Offline
Old Mar 5, 2006, 06:04 PM   #6
Drives: EVO
the wire isn't disconnected or anything. I used the t-connector and just the side rubber housing is opened up...
Offline
Old Mar 5, 2006, 06:47 PM   #7
Drives: EVO
bump on any insight...
Offline
Old Mar 5, 2006, 06:57 PM   #8
Personal Sales Rating: (465)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
Check the coolant temp sensor plug at the tstat.
Offline
Old Mar 5, 2006, 07:33 PM   #9
Drives: EVO
what would happen if i drove my car for about an hour and a half with this cel light on and fan running? do you think it would cause any serious problems?
also does anyone know how much that sensor is?
thanks so much for the help guys.
Offline
Old Mar 6, 2006, 08:43 AM   #10
Drives: EVO
coolant temp sensor plug.
Where is that located? I know you follow the top radiator line all the way to the firewall, but I just can't seem to find it...
Offline
Old Mar 6, 2006, 08:48 AM   #11
8urv8's Avatar
Drives: 06 G35 Black, 2000 Ford F-150
Send a message via AIM to 8urv8
I had something similar with my 04 Mustang. Every time I would start the car, the cooling fan would come on, and just run while the car was on. Only difference was the the car started fine and ran fine. It was still driveable. Any way, the temperature sensor was unplugged. I had unplugged it because the harness was in the way of something else I was working on, and I just forgot to plug it back in. I don't know the exact location of it on the Evo. Check it out, who knows, it might be your issue.
Offline
Old Mar 6, 2006, 09:10 AM   #12
Drives: EVO
Well, i haven't really touched that sensor or anything in the engine bay, except for the spark plugs I've change earlier that day.
I might of really just fried that sensor.
Coolant temperature sensor probably needs to be replaced...
Anyone know where this sensor is?????
Offline
Old Mar 6, 2006, 09:32 AM   #13
Under the cam angle sensor. I figure your next post is "where is the cam angle sensor" though.
Follow the upper radiator line toward the tstat housing and it will be underneith.
Offline
Old Mar 6, 2006, 09:41 AM   #14
Drives: EVO
right on.
I know where cam angle sensor is though. :P
picture will be great though. I'm more of a visual person than anything.
Offline
Old Mar 6, 2006, 10:04 AM   #15
Quote:
Originally Posted by forbidden color
right on.
Click the image to open in full size.
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
2006, circuit, civic, coolant, engine, fan, input, low, mitsubishi, p0117, radiator, replace, sensor, temperature, z06
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
