Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo General
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 9, 2005, 12:25 AM   #1
Gold Sponsor
Personal Sales Rating: (67)
Evasive EVO's Avatar
Drives: Evolution IX
Exclamation Project EVO 9 begins.. Updated! 12-12-05
*** Few new pictures from past time attack at cal speed way 2/11/07:
UPDATED** 12/15/05 Tear down begins on the 9, OS Giken Twin Plate clutch arrived.
UPDATED** 12/12/05 Baseline Dyno and 9vs8 comparison.
UPDATED** 12/30/05 New Parts installed, awaiting FCON VPRO harness.
UPDATED** 1/20/06 Final stages, currently waiting for FCON + tuning!
UPDATED** 2/15/06 FCON Harness, new interior pictures, tuning soon!
UPDATED** 3/10/06 Dyno results - 414hp/375tq
We finally got the car tuned and here are the results.... check the last page for impressions and conditions of the dyno, etc...
Finally we have all the parts sorted out, now its time to begin on this White EVO 9 RS. Thanks goes out to SP Engineering, HKS usa and Enkei for helping out with this project. We will be updating this thread every few days to keep you guys up to date on how it turns out. Baseline Dyno sheets will be posted soon.
Some of the parts that will be used and tested on the IX:
HKS 3037 Turbo kit
HKS Intercooler
HKS F-CON VPro (modification of harness required)
HKS Carbon Ti Exhaust
HKS DP
HKS EVC
HKS Twin Power
HKS misc electronics
HKS RS Kit
HKS SSQV
HKS Hipermax RS
DEFI gauges/display
Koyo Radiator
Enkei 18x9.5 +27 NT03
etc..
wheels being used.. Enkei NT03 18x9.5 +27
the japanese mel gibson
more pictures can be found here..
http://www.evasivemotorsports.com/projects_evo.html
thanks for looking!
new update 12-12-05 Baseline Dyno and 9vs8 dyno
-Dyno'd the car today at Injen, baseline dyno run.
Baseline EVO9 Dyno - Bone stock
Here is a comparison of our stock 9 vs a stock 8 that was dyno there earlier.
The buildup will start in a few days, We will update this thread as soon as we get more pictures.
New Update 12-15-05
Tear down of the 9 begins..
Mivec Motor - getting ready for new headgasket and studs.
turbo assembly
factory 9 turbo - 2000 miles only
Clutch also arrived today.. OS Giken Twin Plate
Project EVO IX Update 12/21/05
We had time to swing by SP Engineering today after work and we were able to snap these pictures. Many thanks to the genius mad scientist Hiro who is doing all the nitty gritty work.
Here we have the turbo mounted and the wastegate on. We haven't bolted everything down just yet, we're doing some test fitting. What isn't pictured here is that we have welded the wastegate reroute up on the downpipe elbow. Also, we have installed the HKS Metal Headgasket installed already.
Intercooler, lift, and stencil.
Different angle.
Hipermax RS with adjustable camber plates. It has different sets of holes for the camber screws on the plates that allow you to set the camber in further than others. (I am still new with EVO suspension so if anyone has information to correct me, please feel free to do so. )
It looks like its crooked but thats cause the hangers aren't on and its not 100% bolted up yet.
Closer shot of the turbo mounted.
Here is a picture of the new clutch system. We installed a OS Giken Twin Plate and it came with this conversion from a push type to a pull type system.
Lastly, this is a picture of the 9 JDM rear bumper that we just got in today.
12-30-05 Project EVO IX Update!!
Starting to look like an engine bay once again.
A closer look.
The Sard Fuel Pressure Regulator setup with the Defi fuel pressure sensor hookup.
Just wanted to show the piping underneath the car. Fitment is perfect.
Helix test pipe fits perfectly.
Artsy fartsy.
Radiator overflow & HKS Twin Power Ignition Amplifier
Some custom work that JDM Mel Gibson did. We welded the flap shut on the wastegate reroute piping and made this custom dump tube.
Another view.
Just wanted to show the clearance of the under body braces in relation to the HKS downpipe. (This downpipe is specific for the turbo kit.)
Everything is almost buttoned up.
SOOOOOOOOOOOOOOOOO.........
We learned that to fit 1000cc injectors on the stock rail you will need to file down the spacers.
The Oil drain tube needs to be repositioned 1-1.25" to the left on the oil pan side to meet up with the drain tube coming off the turbo.
The standard HKS Racing Suction kit will not work with the OS Giken clutch kit due to the push/pull conversion. A custom intake will be fabricated.
The DLI II we used is the same as the Evo VIII, it is a direct plug and play device.
The Koyo radiator requires us to use a slim fan on the battery side.
The VIII's FCON VPRO harness plugs are not close at all to the IX's configuration.
The HKS R Type Intercooler bolts on proplery with all the brackets. There are no issues with fitment of the intercooler. As far as the piping to the turbo, that had to be modified a little. This is specifically for the turbo kit; I don't have info on the stock IX turbo + HKS R-Type piping setup. It might fit perfect for the stock IX turbo. though. Some of the under body splash guard had to be trimmed.
Anything else I will keep you guys updated. It's late and I think I'm forgetting some things but I'll let you know as it comes to mind.
Project EVO IX Update 1/20/06
Completed Engine Bay
Very tight fit, we had to get a slim fan...
The heart of it all...
We had to remove the grill, crash beam, and cut the bumper for this monster to fit!
The cockpit, please excuse the mess...
Another view...
Close up
Project EVO IX Update 2/15/06
Here is a small update, nothing much to see except for the light show inside the cabin hahaa. The car was fired up for the first time today and it purred! There was no hesitation thanks to the FCON! Dyno time should be this week sometime... we're getting very close to the end!
Here are some pictures of the FCON Harness that HKS sent over. The EVO8 FCON harness plugs right into the EVO9.
Enjoy!
Ed @ Evasive
__________________
EVASIVE Motorsports Race Setup & Preparation
VOLTEX official import distributor
"Largest STOCKING dealer in the US!"
Phone: 626.336.3400
Contact: Dennis
AIM: EvasiveMtrsprts
Web: http://www.EvasiveMotorsports.com
Blog: Evasive Motorsports Blog
Email: Sales@EvasiveMotorsports.com
-Super Street SuperLap Finals 1st Place Finish Limited Class AWD 11/12/08 - record time 1:50.003 Buttonwillow CW13
Offline
Old Dec 9, 2005, 12:26 AM   #2
Personal Sales Rating: (1)
fusionchicken's Avatar
Drives: Evo X GSR, 07 Civic Si
Send a message via AIM to fusionchicken
wow, can't wait to see how the IX will respond to those mods......
Offline
Old Dec 9, 2005, 12:27 AM   #3
Personal Sales Rating: (-3)
Dasneak MR's Avatar
Drives: 06 Evolution IX graphite grey
Send a message via MSN to Dasneak MR
OMG i can't wait, I will also be upgrading my turbo etc.
__________________
Graphite grey pearl 06 Evolution IX
Offline
Old Dec 9, 2005, 12:29 AM   #4
Personal Sales Rating: (24)
PHILLY EVO's Avatar
Drives: 03 RR Evo VIII 1/2
Looks like it's going to be fun and good luck....
Offline
Old Dec 9, 2005, 12:31 AM   #5
Personal Sales Rating: (122)
Ultimate CC's Avatar
Drives: 1983 Chevrolet K10 Stepside Pickup
Send a message via AIM to Ultimate CC
can't wait for more pics and some dyno numbers
Offline
Old Dec 9, 2005, 12:32 AM   #6
Personal Sales Rating: (3)
Steiner's Avatar
Drives: '05 Evo VIII RS
Out of curiosity, how did you come to choose the 3037 over the 3076 or 3071?
__________________
http://img181.imageshack.us/img181/2...thread1ie3.jpg
Quote:
A momentum limit would be much cooler than a speed limit.
- Dave Coleman, SCC Magazine
Some helpful turbo airflow numbers...
Small 16g = 36 lbs/min
Big 16g = 38-39 lbs/min
EVO3 16G = 42-43 lbs/min
EVO8 16g = 42-43 lbs/min
6H-20g = 49 lbs/min
50 trim = 50 lbs/min
60-1 = 62-63 lbs/min
35R comp = 64-65 lbs/min
Offline
Old Dec 9, 2005, 12:33 AM   #7
Personal Sales Rating: (0)
EvoJutsu's Avatar
Drives: 08 Evo X MR
gulps.. all HKS parts< high quality stuff. That IX is gonna be a beast
Offline
Old Dec 9, 2005, 12:44 AM   #8
Personal Sales Rating: (56)
Jakeg97's Avatar
subscribed
Offline
Old Dec 9, 2005, 12:45 AM   #9
xepyt's Avatar
Drives: your mom
Send a message via AIM to xepyt
Quote:
not to bad mouth HKS, I know they have great stuff, but JDM is way overrated
__________________
alskdfj;aksjf;lsakdfjskdfalksjf;laskjdflaksdjflaks djfalskfakjf;laskjflaks
Offline
Old Dec 9, 2005, 12:53 AM   #10
Personal Sales Rating: (5)
Lancer EVO IX's Avatar
Drives: Electric Blue Pearl IX
Quote:
Uhhh....no, JDM for life!
Offline
Old Dec 9, 2005, 01:00 AM   #11
Personal Sales Rating: (4)
2003 Mitsubishi Lancer
Hotshot940's Avatar
Drives: 2003 Lancer OZ Turbo, BBYBruno's "Race Gas Only" Evo
Send a message via AIM to Hotshot940
Quote:
Originally Posted by burningmoney97
subscribed
+1
__________________
Powered By
Road///Race Motorsports
Offline
Old Dec 9, 2005, 01:00 AM   #12
xepyt's Avatar
Drives: your mom
Quote:
whatever floats yerr boat
__________________
Offline
Old Dec 9, 2005, 01:13 AM   #13
Dark Evo's Avatar
Drives: 2000 GT Eclipse
Looks very promising!
__________________
The ultimate skill is to take up a position where you are formless...
...If you are formless, the most penetrating spies will not be able to discern you, nor the wisest counsels be able to do calculations against you...
...Therefore, your strategy for victories in battle is not repetitious, and your formations in response to the enemy are endless...
Those who are able to adapt and change in accord with the enemy and achieve victory are called divine...
-Sun Tzu
Offline
Old Dec 9, 2005, 01:16 AM   #14
Personal Sales Rating: (63)
wilson1's Avatar
Drives: EVO 8, EVO8 MR, EVO9 GSR-SE , EVO X
Send a message via AIM to wilson1
looking good!
Offline
Old Dec 9, 2005, 01:53 AM   #15
Drives: 01 VW GTi
good luck with it. it's goin to be a monster once its done.
Offline
Tags
evo, fan, guards, hks, install, intercooler, ix, magazine, motor, project, radiator, rear, rs, splash, taking, tubes, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
