Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo General
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old May 28, 2005, 03:17 PM   #1
Personal Sales Rating: (15)
Garage is empty, add now
rcheung's Avatar
Drives: 2011 X GSR
How do I reset the SRS light ?
I was changing out the my AC condensor today and had to disconnect the two yellow plugs for the airbag sensor. When I put everything back together, the SRS is on and won't go off. Unplugging the battery and replugging wont do the trick. I believe the SRS has its own ECU and needs to be reset. Does anyone know how to do it without going to the dealer and having them use the scan tool?
Offline
Old May 28, 2005, 03:38 PM   #2
Personal Sales Rating: (31)
2013 Chevrolet Camaro
My Garage
evo 8 ya's Avatar
Drives: Grey 2013 Camaro 2SS 1LE, Galant VR4 #807/2000 "Sold", Black 05 Evo GSR "Sold"
EV0ZER0
with air bag codes you need to take it the dealer.
__________________
LMS
XBOX G.Tag: EV0ZER0
PMKMS AKaholic
Offline
Old May 28, 2005, 06:51 PM   #3
Personal Sales Rating: (30)
cut the wire to the light
Offline
Old May 28, 2005, 08:02 PM   #4
Personal Sales Rating: (5)
Dr. Fob's Avatar
Drives: Black R171, Silver EK
Send a message via ICQ to Dr. Fob Send a message via MSN to Dr. Fob
Actually, the aforementioned solutions are about all you can choose from. Typical OBD-II scanner cannot clear SRS lights. The dealership may clear it for you for free under warranty. Otherwise, they may try to investigate the cause of this light and charge you a lot for labor.
Or you can simply disassemble the instrument cluster and locate the little bulb for the SRS warning light. Remove, break, or cut the light and it'll never bother you again.
__________________
Fob Motorsports - Home of the best overpriced used cars.
Offline
Old May 29, 2005, 09:13 AM   #5
Personal Sales Rating: (1)
FLAEVO's Avatar
Drives: 03 MAXIMA 03 EVO
Take to the dealer they will probably charge you to clear the code. (Next time please
disconect the battery first.) If you disconect the battery before disconect the yellow
wires it will not set a code.(Disconect battery wait 1 to2 min. air bags hold charge
for 1 min in case battery gets destroyed in accident.)
Offline
Old May 29, 2005, 09:16 AM   #6
Drives: Ducati 1198s, Ducati 916, KTM 520mxc and an Apex Silver Evo
You have to run into something solid at a speed greater than 12mph
Offline
Old May 29, 2005, 10:16 AM   #7
Personal Sales Rating: (3)
GreedMOTO's Avatar
I have experienced this personally.
I forgot to disconnect my battery and I umplugged my airbag sensor by the headlight when I tried to install my Kansai airbox. I threw the SRS lite and code.
A OBD-II scanner will not clear the code. It is a seperate computer system and requires a different computer to clear the code.
I took my car to the dealer and here is the gist of it.
-They charged me roughly $50 for a half hour of labor to diagnose the problem, even though I told them everything was fine.
-You cannot purchase the computer tools to reset the SRS lite. The tech stated it is a seperate computer system that runs diagnostics that cost $5000!!! I did see the computer on a cart.
-I did try to play stupid about the lite and get it fixed under warranty, but they knew I did it when the lines on the plug did not line up properly, so they f'd me on labor.
soooooooo, bite the bullet and pay the cost, or just pull the bulb to make the lite go away.
__________________
I'm always one part away from being done.
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
2002, 3000gt, airbag, battery, clear, disconnect, evo, galant, lancer, light, mitsubishi, on, r171, reset, srs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
