part numbers II
Old Apr 13, 2005, 01:42 PM
plokivos's Avatar
part numbers II
No chit chat, no bs, just list the part number like this.
2003/2004
EVO GSR
PNC Description Part Number Notes:
Tune-Up 11020
Air Filter MR552951 04150
Oil Filter MZ690116 01521
Drain Plug Gasket MD050317 01512
Drain Plug MD050316 14640
Spark Plugs MD374841
07710
Throttle Body gasket MD180361
Timing Belt 03110
Timing Belt MD326059 03158
Timing Belt Tens.
Pulley MD369999 03178
Timing Belt Adjuster MR984375 03152
Idler Pulley MD156604 14300
Alternator tensioner pulley MD373939 48821Q
Power steering pulley MD327654
Balance Shaft Belt 03620
Balance shaft belt MR984778 03616
Balance belt tensioner MD352473
Maintenance Parts 10040
Alternator and other drive belt MN158794 10110
Thermostat & Gasket MN143463 14630
Plug Wires MD343245 01130
PCV Valve MD152772 01915
PCV valve hose MN158072 10010
Water Pump MD979313 Comes with gaskets 10021
Water pump gasket MN137262 10199
Water pump o-ring MD030764 Engine 01010A
Short Block MN158029 01070
Engine Overhaul Set MD979310 fits prod date upto June of 2003
Engine Overhaul Set 1000A175 fits prod date after July 2003 01080
Head Gasket Set MD979309 fits prod date upto June of 2003
Head Gasket Set 1000A174 fits prod date after July 2003 01090 Mitsubishi
Liquid Gasket MD970389 11700A Intercooler assembly MN153285 04300
Engine oil cooler MR464630 03301
Valve Adjusters MD377054 01110 Valve
Cover Gasket MD340535 11410
Intake manifold gasket MD310447 fits prod date upto 03/11.1 (call)
Intake manifold gasket 1540A109 fits prod date after 03/11.2 01111
Spark Plug Grommets MD186785 02000A
Oil Pump assembly MD366260 02017
Oil Pump Gasket MD322521 04903A
Engine Oil Cap MN163112 comes with gasket 04907
Engine Oil Cap Gasket MD311638 03130
Camshaft Seals MD372536 03070
Crankshaft seal MD343563 04028
Oil pump seal MD365697 03623R
Balance shaft seal MD343565 03080
Engine Rear Main Seal MD359158 2003/2004 EVO GSR PNC Description Engine continued Notes: 03420
Exhaust valves MD184078
03410
Intake valves MD127840
03060
Piston Rings Standard MN155259 03018
Main Bearings MD326349 call selective qyt 5 03048
Thrust Bearing MD351820 03020A Pistons (Standard)
MN183229 fits prod date upto Jan/04 Pistons (Standard) 1110A223 fits prod date after Feb/04 03060
Piston rings MN155259 qty 4 required 03010A
Connecting Rods MN149125
03019
Connecting rod bearings MD326359 qty 4 required 02007P
Upper timing cover MD373108
02007Q
Lower timing cover MN143079
03019
03000
Crankshaft MD357343
01200A
Cylinder head MN155744
03108
Intake camshaft MN143619
03109
Exhaust camshaft MN143620
12510A
Turbocharger sub asm. MN156121
12538
T/C exhaust inlet hole gasket MR404547
12534
T/C exhaust outlet fitting gasket MR299686
12000
Exhaust manifold MN156302
03047
Crankshaft pulley MN149074
03450
Valve spring locks MD016483
03343
Intake rocker arms MD375091 qty 8 03324
Exhaust rocker arms MD375091 qty 8 03490
Exhaust valve seals MD307343 qty 8 03480
Intake valve seals MD306079 qty 8 01221
Cylinder head seals MD372348
04226
Oil sending switch MD138993
21831
Transmission Mount MR491558 02701
Front Engine Mount MR594455 02722A
Rear Engine Mount MR554653 02807
Upper Engine Mount MR554434
Fuel System 07802P
Fuel Injector Insulators MD087060 qty 4 required 07811
Fuel Injector Sheets MD614805 qty 4 required 07892
Fuel Injector Orings MD614813 qty 4 required 07810
Fuel injectors MN153193
07803
Fuel MPI regulator MD320749
Clutch/trans. 21010A Man. Trans. (W5M51-2-X5BB) MN132454 fits prodate upto 12/03
Man. Trans. (W5M51-2-X5BC) MN168658 fits prod date after 01/04 30010A
Transfer assembly MR980934 W5M5 20510
Clutch Disc MN132206 20500A
Pressure Plate MR980846 20430 T/O
Bearing MR145619 20400A
Slave Cylinder MD748617 20410
Slave cylinder repair kit MD977130 20100A
Clutch master cylinder MR491945 2003/2004 EVO GSR Description
Clutch/trans.continu.. Notes: 20110
Clutch master cyl. Repair kit MR403052 03030A Flywheel MD373136 03797
Flywheel bolts MD334117 qty 7 (12 x 15.2) PNC Description Wheel/Brake Notes: 32862
Wheel MN100350 Evo 17 x 8 alum. 32808 Center cap MR133768
32833
Lug nuts MR455707
32502
Wheel studs MB911495 Fits both front. & rear 33307A
Rear wheel hub asm MR403968
51120
Front Pads MR407376
51120
Front Pads MR407376
51150
Front Shims MR475618 51140
Front Clips MR475935 51117
Front Brake Rotors MR370723 52120
Rear Pads MR407391
52150
Rear Shims MR493188 52140
Rear Clips MR475936 52111
Rear Brake Rotors MR370724
Exhaust 12010 Exhaust Manifold Gasket MR323654
Suspension 40041
Front Struts MN101565
41422
Rear Struts MN100475
40621
Front suspension Links MR316368
Left (drivers side) MR316369 Right (passenger side) 32014R
CV Boot kit Right Outer MN156750 Complete w/ clamps & grease 32014L
CV Boot kit Left Outer MN156750 32013R
CV Boot Kit Right Inner MN156751 Complete w/ clamps & grease 32013L
CV Boot kit Left Inner MN156751
Cooling 10273
Upper Radiator Hose MR464621 10272
Lower Radiator Hose MN135593
Electrical 82073
foglamp switch MR190951 82446
intercooler switch MR572674 14932
Crank Angle Sensor MN158261 14925
Oxygen Sensor MN153010 14925Q
Oxygen Sensor MR578532 fits prod date upto 08/03 MN191125 fits pro date after 09/03 14924
Knock Sensor MR578117 07703
Idle speed control motor MD628318 07702
Throttle position sensor MD628074 14610
Ignition Coil MD623072 qty 2 required 14000A Starter M128202D fits prod date upto 02/04 Starter MN137825 fits prod date after 03/04 14200A
Alternator MD366831
2003/2004 EVO GSR Part Number Miscellaneous Notes:
24021 M/T Shift Boot MR646873 24028 M/T
shift knob MN107671 73005
Ashtray MR646881 97150
Nameplate (Evolution) MR154916 Chrome
EVO GSR Part Number Accessories Notes:
Air Dam front corner MZ575550EX
Brake Air Guide MZ555004EX
Lite weight frt strut brace MZ568542EX
Rear Strut brace MZ568499EX
Gold Hyperground cables ALN03FW01
Car cover MZ380267EX Cargo net ALN02CNB01
Tire chains MZ813709EX
Scuff plate cover MZ360061EX
Side window wind deflector MZ562635EX Set of (4) Evolution floor mats ALN03XFB11
Parking brake grip MZ525608EX (Blue/silver)
Parking brake grip MZ525607EX (Silver/carbon fiber)
Install kit for Sports Meter MZ598263EX
Black Shift knob MZ525556EX
Blue Shift knob MZ525554EX
Silver License frame ALN02YCC02
Evolution Sports Meter kit MZ592038EX also need install kit
Nose mask ALN03YMB02 with front license plate
Nose mask ALN03YMB01 without front license plate
Pedal set MZ360063EX manual trans.
Blue Pedal set MZ360062EX manual trans.
Silver Meter cluster surround MZ526953EX
Silver Wheel locks A990WL2C02 Set of (4) Windshield sunshade ALN03XDS02 Evolution
Old Jun 25, 2005, 10:53 PM
USP45's Avatar
Does anyone know where to find a microfische type diagram for the Evo such as the dealer uses?
Old Jun 25, 2005, 10:55 PM
vegasboy301's Avatar
holy willicures... thanks
Old Jun 25, 2005, 11:10 PM
timzcat's Avatar
This thread already exists, what's the point?
Old Jun 25, 2005, 11:13 PM
timz has spoken
Old Jun 27, 2005, 08:09 AM
lancerdealer's Avatar
We have never used a microfiche for an EVO. They just never offered one. The CAPS program we use is supplied by Mitsu. We get quarterly updates by cd.
blonde
Dec 30, 2023 09:10 AM
evolve_VIII
444
Dec 16, 2020 08:11 PM
Raikiri
Nov 25, 2016 05:21 AM
BLKRalliArt04
Mar 23, 2016 10:23 PM
LithiumX
Jan 14, 2010 10:08 PM
Quick Reply: part numbers II
