Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 26, 2004, 01:08 PM   #1
Personal Sales Rating: (22)
Drives: AMS Equipped EVO VIII
Send a message via AIM to GTVEVO
Rod Bolt Install.
Anyone have any information, or tips on the install of ARP conrod bolts. I know that there are some consern with the stock bolts getting out of shape when using high boost and even more likley with more rpm. I don't plan on going over 7.5k and always try to not excede but somtimes it is hard to keep under that. But I want to do what is best, I take advantage of cheap insurance and I want to do it before a bigger turbo.
Thanks in advance.
__________________
EVO VIII
Offline
Old Jul 26, 2004, 02:24 PM   #2
Personal Sales Rating: (16)
1.8t's Avatar
Drives: your mom
Send a message via AIM to 1.8t
Just thinking out loud, can you just drop the oil pan and remove/replace the con-rod bolts with the everything still attached to the crank?
Offline
Old Jul 26, 2004, 03:59 PM   #3
Quote:
This is the normal process that I would think but I wansn't for sure so I wanted to ask. Just so I have the correct feeling and not leaving anything out.
__________________
EVO VIII
Offline
Old Nov 8, 2004, 09:42 AM   #4
Personal Sales Rating: (1)
Drives: Apex Silver Evo VIII
Quote:
anyone care to give instructions???
__________________
Mods:
HKS 3037s Kit, BilletDesign Custom TB Exhaust, HKS R/S kit, Hydra Nemesis EMS, HKS EVC 5 boost controller, RPS Carbon-Carbon clutch, Pruven intercooler kit, Monster Sport I/C pipings, Magnus intake manifold, Tomei 280 procams, Tomei cam gears, BJs Stg5 head, Defi gauges(EGT, Boost, Fuel pressure), Integral Knock meter, Wallbro Fuel pump, Aeromotive FPR, Bosch 800cc Injectors.
Offline
Old Nov 8, 2004, 09:44 AM   #5
Silver Sponsor
Personal Sales Rating: (529)
evodave's Avatar
Location: driving the 10 second beast in ohio or running lightmods.net
Drives: Evo X modified, Evo 8 702awhp, Evo 8 2.4L 30r, 350z modified, galant vr4 with tons of mods, B13 Se-r with evo 8 turbo, lowered ls400 with 205k, super modified dakota v8, built crower motor stealth twin turbo, a couple old 4-runner and some cool bikes
Send a message via AIM to evodave
i heard its a pain...i was going to do it but kinda decided to just to $900 worth of rods and pistons at the same time and make it bullet proof
Offline
Old Apr 2, 2008, 07:01 PM   #6
Personal Sales Rating: (2)
brandon1304's Avatar
Drives: 2003 evo 1992 integra
Send a message via AIM to brandon1304
Old thread but bump, does anyone have clear instructions on how to perform this job?
__________________
Mods
A TON of ETS parts
Offline
Old Apr 2, 2008, 08:00 PM   #7
Wow this is an old thread, after allot of research I decided against this and I am very glad I did. When I pulled apart my stock motor (not blown, replaced with ams long block ) at 40k the rod bolts were as close to perfect as you could get, all rod bearings looked great. Basically there was no need to upgrade them from my standpoint and I probably had 20k miles running 500whp on the stock long block with 8k rev limit.
Keep a good tune and rev limit and you shouldn't have to worry about it unless this is a track only car that run high rpms constantly.
__________________
EVO VIII
Offline
Old Apr 3, 2008, 12:59 PM   #8
I was feeling to same way about it... anyone else have any input?
__________________
Mods
A TON of ETS parts
Offline
Old Apr 3, 2008, 01:37 PM   #9
Personal Sales Rating: (4)
evo_8_u's Avatar
Drives: 03 evo
thats VERY rare to see the original poster reply to his thread he started a little over 3 years ago! crazy
Offline
Old Apr 3, 2008, 01:49 PM   #10
Quote:
What can I say; the EVO had me at hello
__________________
EVO VIII
Offline
Old Apr 3, 2008, 02:08 PM   #11
haha didnt even notice this
__________________
Mods
A TON of ETS parts
Offline
Old Apr 21, 2008, 06:16 PM   #12
bump anyone have some sort of detailed instuctions?
__________________
Mods
A TON of ETS parts
Offline
Old Apr 28, 2008, 02:19 PM   #13
bump
__________________
Mods
A TON of ETS parts
Offline
Old Sep 29, 2008, 06:45 PM   #14
bnice01's Avatar
Drives: Meth Injecting 2 Stepping VIII
here is something that should help if you dont have a strecth gauge
http://www.arp-bolts.com/Tech/TechInstall.html
ARP Rod Bolt Installation
__________________
Self Tuner
Est. Power 450whp+
XBL screen name bnice01
“So if we’re to be the gunners, let us make this bet. We’ll be the best damn gunners that’s left this station yet!”
Quote:
Originally Posted by ForcedPerformance View Post
I know you guys have seen your share of 400whp stock turbo dyno runs on meth, crack, heroin and whatnot with the boost cranked to the moon,
Offline
Old Oct 5, 2008, 06:09 PM   #15
bnice01's Avatar
I just read the little instruction paper that come with my ARP rod bolt its says
"If you do not have a strecth gauge, follow these steps using the ARP Moly Assembly lube. After rods are installed into the motor, torque bolts to 37 ft\lbs. Loosen the nuts. Torque to 37 ft\lb again. Loosen the nuts and torque to 37 ft\lbs a third and final time". I know there site says 5 cycles but I am following the paper that came with my rod bolts. Hope that helps
__________________
Self Tuner
Est. Power 450whp+
Offline
Tags
2003, bolt, bolts, defect, evo, evolution, install, intall, mitsubishi, rod
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
