Cleaning out a Cusco catch can
Hey everyone i was given a Cusco catch can for my 9 and i figured i might as well install it. The only problem is it came off another car so it has some old oil left in it. I wanted to clean it out before installing on my car but the catch can itself is sealed and doesn't open in any way. i was going to take all the fittings out and maybe soak the entire thing in de-greaser or something like that. Any other ideas? Thanks
Drill a hole in the bottom of it, tap it with a designated size, then use a bolt to seal it back up. Then you can clean it out/drain it anytime in the future by just removing the drainage bolt.
bbbwrx
Oct 25, 2004 11:09 PM
