Tremendous boost drop?!
Hi guys.
I apologize if there is already a thread on this but anything will help.
I recently changed out my 9.8 hotside with a 10.5 which was a pain in the ***. After getting everything back together and settled in. Went out for a tune,
I wasnt hitting full boost till 4500k. My peak was at 25psi and then drops to 20 at redline. I attempted to turn the boost up but for some reason it didn't budge. Note before I was at 28psi and held all the way.
Any idea what to check or do??
^ Yes the wastegate actuators are identical between the 8 & 9 turbo
What is your method of boost control? Is you're wideband reading leaner than before?
If you're boost leak test came back good check for the following:
- Is the wastegate flapper seated properly when closed
- Check for an exhaust leak from mani to turbo
Already checked the hotside/mani/downpipe etc.
no leaks. Gonna attempt to pre load my wastegate and see if that's any help. According to my tuner my AFR's are on spot. I do not have a wideband
sssr20det510
13
Dec 9, 2014 10:39 AM
