Mar 9, 2004, 09:25 AM
Personal Sales Rating: ( 5)
Drives: 04 Evo 10.4 @ 145mph
A Listing of All ECU Error Codes (OBD-II)
Alot of people have got questions about what certain codes are, so here is a list. Mods please make this a STICKY.
DTC P0090: Fuel Pressure Solenoid Circuit
DTC P0101: Volume Airflow Circuit Range/Performance Problem
DTC P0102: Volume Airflow Circuit Low Input
DTC P0106: Barometric Pressure Circuit Range/Performance Pro
DTC P0107: Barometric Pressure Circuit Low Input
DTC P0108: Barometric Pressure Circuit High Input
DTC P0111: Intake Air Temperature Circuit Range/Performance
DTC P0112: Intake Air Temperature Circuit Low Input
DTC P0113: Intake Air Temperature Circuit High Input
DTC P0116: Engine Coolant Temperature Circuit Range/Performa
DTC P0117: Engine Coolant Temperature Circuit Low Input
DTC P0118: Engine Coolant Temperature Circuit High Input
DTC P0121: Throttle Position Circuit Range/Performance Probl
DTC P0122: Throttle Position Circuit Low Input
DTC P0123: Throttle Position Circuit High Input
DTC P0125: Insufficient Coolant Temperature for Closed Loop
DTC P0128: Coolant Thermostat (Coolant Temperature Below The
DTC P0130: Heated Oxygen Sensor Circuit [SEMSOR 1]
DTC P0131: Heated Oxygen Sensor Circuit Low Voltage [SEMSOR
DTC P0132: Heated Oxygen Sensor Circuit High Voltage [SEMSOR
DTC P0133: Heated Oxygen Sensor Circuit Slow Response [SEMSO
DTC P0134: Heated Oxygen Sensor No Activity Detected [SEMSOR
DTC P0135: Heated Oxygen Sensor Heater Circuit [SEMSOR 1]
DTC P0136: Heated Oxygen Sensor Circuit [SEMSOR 2]
DTC P0137: Heated Oxygen Sensor Circuit Low Voltage [SEMSOR
DTC P0138: Heated Oxygen Sensor Circuit High Voltage [SEMSOR
DTC P0139: Heated Oxygen Sensor Circuit Slow Response [SEMSO
DTC P0141: Heated Oxygen Sensor Heater Circuit [SEMSOR 2]
DTC P0171: System too Lean
DTC P0172: System too Rich
DTC P0181: Fuel Tank Temperature Sensor Circuit Range/Perfor
DTC P0182: Fuel Tank Temperature Sensor Circuit Low Input
DTC P0183: Fuel Tank Temperature Sensor Circuit High Input
DTC P0201: Injector Circuit-Cylinder 1, DTC P0202: Injector
DTC P0234: Turbocharger Wastegate System Malfunction
DTC P0243: Turbocharger Wastegate Solenoid Circuit
DTC P0300: Random/Multiple Cylinder Misfire Detected
DTC P0301: Cylinder 1 Misfire Detected, DTC P0302: Cylinder
DTC P0325: Knock Sensor Circuit
DTC P0335: Crankshaft Position Sensor Circuit
DTC P0340: Camshaft Position Sensor Circuit
DTC P0401: EGR Flow Insufficient Detected
DTC P0403: EGR Control Circuit
DTC P0420: Catalyst Efficiency Below Threshold
DTC P0441: Evaporative Emission Control System Incorrect Pur
DTC P0442: Evaporative Emission System Leak Detected (Small
DTC P0443: Evaporative Emission Control System Purge Control
DTC P0446: Evaporative Emission Control System Vent Control
DTC P0451: Evaporative Emission System Pressure Sensor Range
DTC P0452: Evaporative Emission System Pressure Sensor Low I
DTC P0453: Evaporative Emission System Pressure Sensor High
DTC P0455: Evaporative Emission System Leak Detected (Gross
DTC P0456: Evaporative Emission System Leak Detected (Very S
DTC P0461: Fuel Level Sensor Circuit Range/Performance [SUB]
DTC P0500: Vehicle Speed Sensor Malfunction
DTC P0506: Idle Control System RPM Lower Than Expected
DTC P0507: Idle Control System RPM Higher Than Expected
DTC P0513: Immobilizer Malfunction
DTC P0551: Power Steering Pressure Switch Circuit Range/Perf
DTC P0554: Power Steering Pressure Switch Circuit Intermitte
DTC P0622: Generator FR Terminal Circuit Malfunction
DTC P0830: Clutch Pedal Position Switch Circuit Range/Perfor
DTC P1400: Manifold Differential Pressure Sensor Circuit Mal
DTC P1603: Battery Backup Circuit Malfunction
DTC P2066: Fuel Level Sensor Circuit Range/Performance
DTC P2263: Intake Charge System Malfunction
If anyone would like more info on a certain code feel free to PM me.
__________________
Doug W.
TopSpeed STILL building the fastest Evo's in GA, Results not hype
2008 Summit Point RLTA Grand Champion
2008 Nashville Redline TA Grand Champion
2008 Gateway Redline TA Grand Champion
Miller GTlive 3rd Unlimited AWD
2006 Onelap of America 1st in class
2008, 2007, 2006 Import Showdown winner yet to be beat in Georgia.
Offline
Mar 16, 2004, 10:32 AM
Personal Sales Rating: ( 2)
Drives: 61 Austin Mini...but no more Evo!
Good stuff! This thread has been stickied. I also closed it since there is nothing that can be added to the post to add to it's content.
SC~
Offline
Aug 22, 2008, 03:10 PM
Personal Sales Rating: ( 1)
Drives: 2004 Evo RS
ODBII error codes sticky
I know there is already one in the drivetrain / turbo forum but its incomplete.
I have a giant list of all odbii codes ever if you guys want to update it.
Amusingly its about 4 posts worth of data so i have it attached as a text file
__________________
Car: 2004 Evo RS on E85 with Speed Density ECU mod
Buschur Parts:
Cone filter , IC pipes, Race Intercooler
Other parts:
Zeitronix WB,Tial Sport Q, Walbro 255lph, ACT 6 Puck with prolite flywheel ,GSC S1 cams, 1200cc injectors, Cobb catbac, Helix downpipe & O2 Outlet, 100 cell cat, 3 Port , FP Red, Stock ECU, Stock block/head/intake/tb
Offline
Aug 23, 2008, 08:40 AM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Moved the above post here so you all can see the attachment.
Offline
Tags
80, circuit, code, coolant, dtc, engine, error, evo, high, input, install, odb2, p0106, p0335, p0513, temperature  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
