Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Aug 9, 2013, 06:02 AM   #1
Personal Sales Rating: (2)
Garage is empty, add now
EvO8_BT's Avatar
Drives: 03 Evo
Car dies when i push the clutch in!!!
i have read a lot of threads on this but none really have a solution, i have a newly built engine and when i push the clutch in the car dies immediately. the car is having a rough time idling. my thrust washers have a little scaring on them i beliive from this. i want to say that the crank is getting pulled by the tranny or from that direction. i have an exedy twin and was installed on the car before the engine was built. let me know what you guys think/any solutions you may have
Offline
Old Aug 9, 2013, 06:16 AM   #2
Personal Sales Rating: (0)
2005 Mitsubishi Lancer Evolution
X Double Dot's Avatar
Drives: 2005 Evolution VIII
does pulling in the clutch lug the engine and thats what kills it (instead of an electrical issue from the clutch switch)? for example if you gave it some gas when you pulled the clutch in, will it stay running?
if it only dies at idle, then I would say that there is a thrust loading issue. When you push the clutch in, you put a considerable load on the thrust washers. If one of them is scored up, or worse yet, spun, then I could easily see how that would be killing the engine. I would probably be thinking about pulling the oil pan to check it out sooner rather than later. Look for thrust washer material extruding out around the main cap.
Someone else chime in if they think it might be something else
__________________
2005 Evo VIII SSL aka "God's Chariot".
Noteable Mods: Evo 9 turbo @ 24-26 psi, DIY COP w/ BPR7EIX @ 0.026", GM 3-port, Injen UICP and Intake, ETS LICP, 3.75" Intercooler, Megan downpipe, 3" Buschur Exhaust tubing and magnaflow muffler, BC 272's, FIC 950cc injectors. VD puts car @ 365 whp through the ACT HD Street disk clutch. Self Tuned on 93 octane using an AEM analog wideband and the stock ECU
Best 1/4 mile 12.879 @ 107. 1.755 60ft
Offline
Old Aug 9, 2013, 08:41 AM   #3
Silver Sponsor
Personal Sales Rating: (30)
JohnBradley's Avatar
Drives: 06 Rally Red MR
Sounds like crankwalk to me. Is this a motor that you have had to crank for a long period of time with the clutch in before...or frequently still?
__________________
Please direct all tech and sales questions to -
sales@englishracing.net
Jeff Bush runs 7.94@175, best mph of 177
EnglishRacing/ETS GTR runs 7.81@183 / 219.8mph in the 1/2 mile
Myles Kerr runs 187.43 in the 1/2, '94 Integra street car
Lease Locators Racing runs 196.6 in the 1/2 1100whp Evo 8
English Racing offers ACD Tuning - visit our online store at - www.shopenglishracing.com
It's not enough to be good if you have the ability to be better..
Offline
Old Aug 9, 2013, 09:01 AM   #4
EvO8_BT's Avatar
Drives: 03 Evo
when we pulled the oil pan off one of the bearings was worn down compared to the other side, when at idle i had to consistently give the engine gas and as soon as pressed the clutch pedal it stalled the engine immediately. when we put new thrust washers in everything was in spec for clearances. my big question has to be what is causing this? is it installation of the transmission or clutch?
when attempting to start the car it would fire up very quickly but does not want to hold idle
Offline
Old Aug 9, 2013, 11:45 AM   #5
Silver Sponsor
Do you start the car with the clutch in or do you have the clutch start eliminated?
__________________
Offline
Old Aug 10, 2013, 06:42 AM   #6
EvO8_BT's Avatar
Drives: 03 Evo
I start the car without the clutch being pressed in. The car would run if I gave it more gas. I'm going to pop the wavy clip off and attempt to start it an see I I have the same issue
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
car dies, evo 8 crank, fml, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
