GSC Power-Division releases R2 camshafts
R2 for Evo VIII are now available. Visit Englishracing.net to purchase-
http://www.shopenglishracing.com/-NE...e-Release.html
So after much testing and development, I am happy to announce that the R2 profiles for high power stroker motors will be available starting Tuesday the 12th. Finally being able to source a steady stream of the billets needed to produce the high lift and high duration camshafts known officially as R2 has taken awhile but will be worth the wait.
Initially we will have Evo IX cams available with the VIII cams coming near the end of the month or beginning of March. The R2 is meant for larger motors (2.2+) with large turbos specifically focusing on power below 9,000rpm.
Here are the specs-
Evo IX R2 MIVEC camshaft set
236/236* at 1mm and 274* advertised
12.1mm intake, 11.9mm exhaust
130/115* centerline
5041 spring set highly recommended
Evo VIII R2 camshaft set
12.0mm intake, 12.0mm exhaust
109/115* centerline
Pricing will be standard and in line with the current S series of camshafts, $660MSRP and $561 sale price. These will be added to http://www.power-divsion.com and also the http://www.shopenglishracing.com online store.
Enjoy
Aaron
Here are the specs-
130/115* centerline
109/115* centerline
Enjoy
Aaron
Backorder list-
Evo VIII
1. MT057
2. Aby@MIL.SPEC
3. browningderek
4. craig05evo
5. KPR
6. concept11253
7. DynoTech Tuning
Evo VIII
1. MT057
2. Aby@MIL.SPEC
3. browningderek
4. craig05evo
5. KPR
6. concept11253
7. DynoTech Tuning
Here are the specs-
130/115* centerline
Evo VIII R2 MIVEC camshaft set
109/115* centerline
Aaron
Here are the specs-
130/115* centerline
109/115* centerline
Aaron
Engine Make: Engine Model: Part Number:
Mitsubishi
EVO 8
8-TX288 Camshaft Set
Valve Clearance
Intake:
Set
at the
Exhaust:
Set
at the
Cam Lift: Intake:
6.937
Exhaust:
6.648
Rocker Ratio: Intake:
1.73
Exhaust:
1.73
Nett Valve Lift: Intake:
12.000
Exhaust:
11.500
Advertised Duration @
0.100
Intake:
288
Exhaust:
280
Duration @
VALVE
Intake:
242
Exhaust:
238
Timing @
VALVE
IVO:
16 BTDC
EVO:
56 BBDC
IVC:
46 ABDC
EVC:
2 ATDC
Suggested Centre Lines: Intake:
105 ATDC
Exhaust:
117 BTDC
VALVE
Lift @ TDC Intake:
2.400
Exhaust:
1.320
Less aggressive ramp rate, going to idle more aggressively, less lift on the exhaust. I havent had the 288/280 in here but the 280/280 makes the same power as S2s +/- but idles far more lumpy. Knowing what I do about Kevin's nose profile I think these are less powerful than S3s.
