can you mess up the clutch by jacking the car up in the wrong place?
Old Dec 27, 2004, 03:47 PM
alex_alex's Avatar
my car was jacked up by the splash gaurd underneath, as i was told that there was a crossmember above it that would support the weight of the car.
needless to say this completely mangled the splash gaurd itself and the screw that held it in.
a day later, i went to the track and my car was not shifting into 4th very well. The car would grind unless i was super slow with the shift, and after a while, it wouldn't not go into gear at all unless i double clutched it.
the question is: can jacking up the car at the wrong point mess up the clutch / tranny in a way that can induce grinding / general transmission failure, etc?
I had the dealer put in a stock clutch, and now the problem seems to have gone away, the gears do not grind anymore although they are still a bit difficult to get into gear.
opinions ? suggestsion?
Old Dec 27, 2004, 04:15 PM
MYEVO8U's Avatar
Yeah one suggestion.
the idiot that told you to jack it up in that position.
Old Dec 27, 2004, 04:20 PM
EVO_JOE's Avatar
Man i think it's your syncro's. I had the same problem. shifting into 4th and 5th gear. I took mine to union Mitsubishi in Korea town last week and they are changing the 3rd, 4th, and 5th gear syncros. I get it back tomarrow. Give there service department a call tomarrow, I'm positive they will change them for you under warrenty. there number is 213-368-1900 ask for Gerome.
Old Dec 27, 2004, 05:15 PM
alex_alex's Avatar
were they easy to deal with?
i don't remember a gerome working there, only this older asian fellow and a hispanic guy.
how long was the turnaround time?
What mods did you have when you brought it in?
Old Dec 27, 2004, 05:16 PM
alex_alex's Avatar
Yeah, my first reaction was that this was definately a synchro problem.
However, i'm not sure why replacing a clutch would get rid of the problem, but it has (for now, knock on wood).
Old Dec 27, 2004, 06:19 PM
Registered User
metaphysical's Avatar
There is a hook underneath to Jack it up from the front if you need to do that.
Old Dec 27, 2004, 09:34 PM
EVO_JOE's Avatar
Yea the older asian guy is Gerome.
There pretty cool about mod as long a the mod you have does not directly effect the problem your having.
It's worth giving them a call
Old Dec 27, 2004, 11:52 PM
Frank Dux's Avatar
Thats not an asian name you hear every day.
Old Dec 28, 2004, 12:11 AM
alex_alex's Avatar
thats what i was thinking
Old Dec 28, 2004, 12:35 AM
EVO_JOE's Avatar
I don't know, I thought the same when I first met him. He's Korean if that makes a difference.
Old Dec 28, 2004, 01:28 AM
evo81's Avatar
this thread
Old Dec 28, 2004, 01:50 AM
alex_alex's Avatar
Don't you work at Union Mitsu Clue?sion? OR are you affiliated with it in another way?
Old Dec 28, 2004, 05:59 AM
SuperHatch's Avatar
If your stock clutch was burnt to the point of being warped, the tolerances would be out of whack. When you disengage a clutch with a heat warped pressure plate, there can be spots where the warped pressure plate never fully disengages from the clutch disk. This results in the clutch still grabbing a minute amount causeing the car to grind when you shift gears. So yes, a bad clutch can cause grinding problems.
Old Dec 28, 2004, 08:46 AM
chrisw's Avatar
Originally Posted by evo81
this thread
werd
Randal
20
Dec 7, 2012 12:54 PM
scottatyamaha
Mar 21, 2012 06:33 PM
pb91
Jun 8, 2011 02:44 PM
Braden71790
Apr 7, 2011 12:51 PM
Walkingchaos
Apr 5, 2006 08:13 PM
Quick Reply: can you mess up the clutch by jacking the car up in the wrong place?
