494.4whp 400ft.lbs at 24psi
Old Feb 13, 2004, 02:50 PM
  #61
nonmature's Avatar
I dont need to go all the way to 9500 that is just what it able to reach the valvetrain upgrade will let you rev between 9500 and 10000
-non
If you want then answer this question @ what RPM will the HP start to fall with the gt30r???
Old Feb 13, 2004, 03:05 PM
  #62
robertrinaustin's Avatar
Location: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Good question. Hopefully someone can answer this. They may have trouble because not many people are running those kind of rpms and they haven't done any testing.
Old Feb 13, 2004, 03:08 PM
  #63
Guack007's Avatar
Isn't that what they invented the twin turbo setup for?
I know an audi RS-6 can make huge amounts of turbo power throughout one of the widest power bands I have ever seen. here are the stats on an RS-6:
Aluminum 4.2 liter V8 biturbo, 40 valve engine with 450 hp and 415 lb/ft of torque
Displacement: 4.2 liters (255 cu. in.)
Bore: 3.32 in.
Stroke: 3.66 in.
Compression ratio: 9.8:1
Horsepower (SAE): 450 @ 5700 - 6400 rpm
Torque: 415 lb/ft @ 1950 — 5600 rpm
* Volkswagen Oil Standard 505 01 (5W-40 Synthetic Motor Oil) required
Then again sometimes theres just no replacement for displacement.
My 2k cents
Old Feb 15, 2004, 11:45 AM
  #64
Evo8Master's Avatar
rmr
How does the car idle with 272 cams??? Any cold start issues while using the autronic??? What are your thoughts after using the autronic??? I know Aem ems seems to take a while to start up.
Old Feb 15, 2004, 02:18 PM
  #65
Re: rmr
FWIW I had cold start issues both before and after installing my Power FC. Idle is good, but stalls on cold start.
Old Feb 15, 2004, 06:00 PM
  #66
nonmature's Avatar
-non
did we ever get an answer on this???
-non
Old Feb 15, 2004, 09:07 PM
  #67
ItsStockOfficer's Avatar
Bore: 3.32 in.
Stroke: 3.66 in.
My 2k cents
How the hell is that broad? A stock evo has 4x as much space between peak torque and peak hp....
Old Feb 16, 2004, 12:03 AM
  #68
umiami80's Avatar
... I want to be arround 375-400 whp and have a wide usable power band, but a civil one that I can use on the street as well... I wont ever get to 9500 on the street I probably wont get above 5000 unless I am racing hehe... anywyas what hp will the gt30r suppot at 9K as I said before an educated guess is all I want...
This can be done on the
Pump 93 Octane
Stock Turbo
Stock Injectors
Stock IC Piping
I want damn near 500WHP on pump gas.
What is the CFM rating on th eGT 30 an dthe 35?
I know the BIG 16G has 550CFM's
so what are the 30? My guess is 750-800
What is the spoolup on the 30?
Old Feb 16, 2004, 09:41 AM
  #69
Pump 93 Octane
Stock Turbo
Stock Injectors
Stock IC Piping
CFM rating is not a good convention for rating turbo potency. Its always done at 1 ATM, and not many of us run 14.7 psi. Larger turbos make larger difference's at higher RPMS.
For what its worth though, a 20G is about 650, a 50 trim is a bit over 700 and a 25g is about 850 CFM. I think we all know the 50 trim is considered a contemporary of the gt30, and the 25g MIGHT be considered a contemporary of the 25G. The 25G flows as much as the gt35R at 14.7 psi Im sure....at higher boost level it favors the 35R I am sure.
I think asking Lb/min and max effciency is a bit more useful. That tells maximum power output. But looking at the maps is always best.
Old Feb 16, 2004, 10:53 AM
  #70
Guack007's Avatar
1950-6400RPM. That's 4450 RPM's
3500-6500. That's 3000RPM's
Right?
Old Feb 16, 2004, 10:57 AM
  #71
Right?
Ah yess, you definitley win. I was looking at the peak numbers only, I did not ntice they gave a range.
Old Feb 17, 2004, 12:34 PM
  #72
RnR Racing's Avatar
If you don't want the lag then go with the GT30R. It just won't support the same power, but it will hit full boost uner 4000rpm.
I am unsure if the GT30R will hold the power until 9500rpm. We have test it that high yet.
Old Feb 17, 2004, 01:59 PM
  #73
evosevengsr's Avatar
hey rnr..
what autronic system are you guys using?
the SMC or SM2 model?
or is it a PNP board?
could you give me some details of the autronic?if you cant I would understand.You can pm it to me if you like.
Also, did you have to purchase anything other than the ecu to make it work?
thanks in advance!!
Old Feb 17, 2004, 02:00 PM
  #74
RnR Racing's Avatar
We used the PnP board. It worked out great for us. I am still trying to decide what I am going to use on my car.
Old Feb 17, 2004, 02:43 PM
  #75
Wadzii's Avatar
how far do the rpms fall when you shift?
when making big power thats all you should be conserned about. if you have power for the rpms your at when you're racing then whats the big deal.. downshift... most hondas only need 2500-3500rpms of power cause the rpms dont fall much when you hit the gears....
low end power is for grama
Quick Reply: 494.4whp 400ft.lbs at 24psi
