garrett gtx3576r or EFR 7670 What turbo should i buy
I'm looking for a upgrade turbo for my s2000 and I have decided between the garrett gtx3576r with a t3 .63 hotside or the borg warner efr 7670 with the t3 .83 hotside. Which one should I go with. I have always been a fan of garrett turbos but I have read that the boost response/ transit response and spool is amazing and superior because of the titanium turbine wheel from the EFR.
I just want to know if both turbo are of equal size and equal power potential which turbo will be better. A garrett GTX or a borg warrner EFR? Does the titanium turbine wheel of the EFR really make it respool and respond that much better. I have asked in a lot of otherforumes and i'm getting a lot of mixed opinions. Some people sware by the new erf turbos saing nothing will come close to the spool ad transit response and other people say the garrett's GTX lie is the best money can buy.
Here is a pic of my current setup. I'm currently using a garrett ball bearing 50trim turbo
Here is my current dyno. 395whp on 91 octane 11psi and 501whp on e85 17 psi
Well there is only one 3576 in use on this board that I am aware of and I havent been able to find the VDR sheet for it in Twin Scroll thread. 240Z Twinturbo owns that one. The Ti wheel in the 7670 is literally half the mass of a coventional wheel which is going to be big for initial spool as well as transient response.
3576-
https://www.evolutionm.net/forums/ev...eriment-9.html
He switched it sometime near the end of the thread but I havent seen the test data, or I keep staring at it and not realising what it is PM him and he can supply it I am sure.
3576-
Thanks Aaron...
I believe the GTX3576R is the closest in size to the EFR 7670 based on physical dimensions of the wheels. As far as which is better, hard to say from what I have seen and depends on what you are seeking. I have yet to see hard data to say transient response is better and I have not seen one on a 2L that spools as well as my GTX3576r, but that is also a function of my manifold and TS setup.
Here are a few links for reference data...
https://www.evolutionm.net/forums/ev...0hp-375tq.html
https://www.evolutionm.net/forums/ev...-gtx3576r.html
2.2l 4g64 block, tubular exhaust manifold with magnus intake and S3s correct? That spool looks amazing. You going to an 8374?
Makes me want to do a 7670 with 2.3l and "Revhard" type exhaust manifold with stock intake manifold. Ugh. The cost for all that is not in the books for a long time though... engine + turbo + piping ~
powerman00
Jan 21, 2015 10:35 AM
