Evo 8 Top Speed?
Guest
Evo 8 Top Speed?
How is the top speed regulated for a stock evo? Drag limited? Or is it cutoff at a certain rpm? What is the topspeed of a stock evo? I have an evo 8 with 400whp. What is the top speed of it assuming I redline it at 7,500 rpm in 5th gear?
Guest
Just take a drive. If you hit rev limit easily in top gear yur gear limited. This is the case with my X. If your rpms hit a brick wall in the middle of your power band then it's governor. If you can't figure this out because you run out of road then you are power/aero limited or just not really trying.
Guest
sorry meant 165mph on the EVO 9.
could be gearing or tire diameter or even speedo error as they are rarely accurate and they almost always read at a higher speed.
the mph/rpm chart is listed at several websites and i took the info straight from the chart.
I've had mine over 175, unless I have different gearing this is incorrect.
FS[South]: WTB: evo 8 5 speed top transmission mount
sterlinge
Nov 14, 2016 08:10 AM
Fourdoor
72
Jul 24, 2011 12:31 PM
