INSTALLED: EBAY Civic Half Size Radiator!
#198
Interesting. I have been logging raw coolant temp and tonight doing some tuning pulls logged up to 222.8. However I have a small coolant leak on the back of the head and will be fixing that tomorrow and then reburping the system and do some more logs.
Could you explain why your logging scaled instead of raw?
#205
If you look at this pic, it is of an eclipse. The lower hose looks like it might be the most suitable option. If you close closely, it looks like it takes a 90* angle which would work a bit better for this setup. If it would still rub the lower trans mount, I am not sure
#206
Excellent work. Just a remark though. I was thinking of installing a half radiator from Buschur Racing as well, just to keep my engine bay as neat and empty as possible. I was advised by them NOT to install the radiator if I was planning to daily drive the car. Now I understand that the weather difference between the USA and Qatar is not even worth mentioning due to the massive difference; however, I've been told that our weather is very similar to the weather in Texas.
I have no idea if their advice is based on certain weather conditions or what exactly, but I decided to stick with their advice because of their professional history.
#207
#208
#210
I'm not sure if the g4js and the 4g63 head have the same exact thermostat housings, but I can say for sure that you have enough hose to reach either.
There's still more slack I could cut out if need be.
