Low Compression on all 4 cylinders
Old Feb 3, 2012, 02:41 PM
My03evo's Avatar
Are you holding the pedal down while cranking? All other plugs out and a charger on the battery? I saw a difference in my psi numbers without a charger but I do have a mini battery.
I got my motor apart n foumd ALL 4 top piston rings came out in pieces and I had 160psi in all cylinders with S2's
Old Feb 3, 2012, 05:22 PM
graphitegrey9's Avatar
Yep I followed the manual to a T when doing the compression test. I also did a cylinder leak down on all of the cylinders and they were all within 10% or so. I have read. With larger cams the over lap will cause this. It's just me being paranoid
Old Feb 3, 2012, 10:14 PM
project_skyline's Avatar
If your leakdown was 10% I wouldn't worry about the compression test, it could just be your motor's static compression and your cams.
roni4g63
17
May 23, 2016 04:38 PM
mrm95
Feb 9, 2015 07:14 PM
Poopy
Mar 16, 2014 03:31 PM
Pssst
Mar 8, 2012 12:26 PM
WcEVO2
Sep 30, 2007 11:12 PM
Quick Reply: Low Compression on all 4 cylinders
