Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory TSB & Recalls
Search
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Jan 29, 2012, 10:05 PM   #1
Personal Sales Rating: (1)
Garage is empty, add now
Drives: 03 evo 8
one fast evo03
Ticking noise at idle only not lifters
Ok so Im experiencing some ticking noise only at idle you can hear it. It all started after I blew my freeze plugs out when I launched my car at the drag strip with my 2 step. I got all that fixed and fire the car back up and its been ticking ever since. I since then have been around 500 miles in the car beat the hell out of it and still performs the same as before no power loss at all. Ive checked everything under the valve cover and everything was fine. Checked the oil and it was clean as could be. The only thing I can think of is its the timing belt tensioner. I did find that my cam gears were loose on the adjustment screws so we tightened them back up and it still ticks. Does anybody have anymore ideas on what this could be? Any help would be greatly appreciated
__________________
Evo 8 2.0L Fully Built pte 6766 e85 hunting for 9s
6.63 1/8 mile 1.60 110mph
best et:10.94 with a 2.304 60 foot lol
best mph:142.21
6766 822hp @ 40 psi
tuned by mellon
local 1/8 best et 6.47 @ 118
Sponsors:
Shift Fast Motorsports
2376 Faith Caroline Blvd
Rock Hill, SC (803) 327-0014
Beaver Dam Auto Aution
107 Webb Rd
Shelby, NC 28152
(704) 434-8711
Offline
Old Jan 30, 2012, 01:49 PM   #2
Personal Sales Rating: (0)
barneyb's Avatar
Drives: '03 Evo 8, '04 WRX
My engine was ticking untill I ran some Gunk fuel injector cleaner through it. The noise was there from idle up to about 4K rpm. After that engine noise drowned it out I guess. Give this a try, if it doesn't work you are out five bux.
Offline
Old Jan 31, 2012, 05:38 PM   #3
Drives: 03 evo 8
one fast evo03
Ok I'll try that thanks for the advice. I've already sent the injectors in and had them bench flowed and clean do you think this stuff will still help?
Offline
Old Jan 31, 2012, 09:12 PM   #4
barneyb's Avatar
Quote:
I've heard that one bad tank of E-85 can gunk up the injectors. Otherwise, if on gas, since you've done that, never mind. If on E-85 I'd suggest pulling and checking.
Offline
Old Jan 31, 2012, 10:16 PM   #5
1991 Honda CRX
My Garage
awdordie's Avatar
Drives: 2003 evolution 8 and fully built 1990 honda crx
have you checked for exhaust leaks? they can sometimes make a ticking sound
__________________
Quote:
EvoJoeIX
the only use for those, would be to tape them all together forming a long rod, place said rod into a steady base, place contraption onto floor, pull down pants, and sit on them
Drives: 03 evolution 8, fully built b22b-t honda crx
Owned: 99 mitsu eclipse gs
www.mellonracing.com
Tuned by Mellon
Offline
Old Jan 31, 2012, 10:18 PM   #6
Personal Sales Rating: (14)
prowakeskater's Avatar
Drives: pb sss x gsr, tb ix gsr, ww xiii mr (sold), 09 600rr, 03 wr450 motard
what injectors are you running
__________________
X GSR - Stock turbo | K&N | BR UICP LICP FMIC TBE | GSC s2 | BR springs/retainers | 1100hz | ARP | GrimmSpeed | Synapse | Exedy Twin | H&R |
IX GSR - Stock turbo | SD | AMS LICP | XSPower FMIC | FiC 1150 | S2 | AMS TBE | GrimmSpeed | DDM | Bilstein/H&R |
TSCompTuned
Offline
Old Jan 31, 2012, 10:34 PM   #7
Drives: Evo 9 GSR
some injectors tend to tick during normal operation.
__________________
AEM, Alpine, Bushur Racing, Cusco, Defi, ETS, GReddy, GTWorx, JL Audio, K&N, Racing Brake, Road/Race Engineering, RotorPros, TWM, Ultimate Racing, Whiteline, Works
Offline
Old Feb 1, 2012, 06:16 AM   #8
Personal Sales Rating: (9)
C6C6CH3vo's Avatar
Drives: through oil, clutches, and bearings
The cam belt tension-er started to go out on my car at about 90,000 miles. It did not tick at all. The belt would just make alot of racket when engine was cold.
Is the ticking chronic at idle or does it go away at times?
Offline
Old Feb 1, 2012, 09:12 AM   #9
2002 Mitsubishi Airtrek
GregM's Avatar
Drives: Ford Territory
Exhaust leak, check around the manifold.
__________________
1998 Mitsubishi Lancer Evolution 5 - Dedicated Race Car
Offline
Old Feb 1, 2012, 02:59 PM   #10
Drives: 03 evo 8
one fast evo03
Yes I went thru and checked all exhaust no leaks. I'm running id2000 injectors. Yea it's on e85 but the tick just started after I blew my freeze plugs and is constant never goes away
Offline
Old Feb 1, 2012, 10:48 PM   #11
Drives: 03 evo 8
one fast evo03
Anybody got anymore ideas?
Offline
Old Feb 2, 2012, 01:41 AM   #12
^ was or still currently? I would get a screwdriver and try to pinpoint the epicenter
__________________
TSCompTuned
Offline
Old Feb 2, 2012, 11:07 AM   #13
Drives: 03 evo 8
one fast evo03
Ok I'll try the screwdriver method and see if I can get an exact aspect of where but I'm thinking it either the injectors or lifters just from listening to videos. I know I just had the injectors cleaned but I'm sure there was gunk in the fuel tank and lines too so they could be partially stopped up again so ima get some injector cleaner and run through it and see if that helps
Offline
Old Feb 2, 2012, 01:55 PM   #14
Personal Sales Rating: (42)
Blue91lx's Avatar
Drives: Bicycle
My car always ticks, and it's piston slap.
What pistons are in your car? I run JE pistons, and because JEs are a full circle they will get noisier with age as the skirt deforms. The looser your clearances, the louder the noise will be.
__________________
'89 325iX - Daily
'87 325es - V8 Swap
'03 Evo - 2.4L/FP Red
Offline
Old Feb 2, 2012, 07:09 PM   #15
Drives: 03 evo 8
one fast evo03
I run .020 overbore wiseco 1400hd pistons. It doesnt sound like piston slap but if it is I guess oh well. Ima try to run some seafoam thru it tomarrow and see what happens. Thanks guys for all the help
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
2v, 54, drivetrain, engine, evo, ideling, idle, idling, noise, rear, tensioner, tick, ticking, timing belt, turbo, wrx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
