Very low compression! Help!
I did a compression test today after I took my son to school (15 mile drive each way). Car fully warmed up. Battery is 3 months old. Cranked over 15 times. It came out to (cylinders 1-4):
100, 105, 110, 110
after putting some oil in the cylinder:
110, 105, 112, 110
Mods: GSC S2, Perrin Intake, ETS LICP, Perrin DP, MAP O2.
Mods waiting to put on: SpoolinUP COP, FB 70mm TB, IX Turbo, UICP, etc.
Is it rebuild time (110k miles)? Car seems to drive fine. I'm at 360 hp/tq on E85. That's with a massive boost leak at the TB shaft seals. I'm fixing that soon. I also noticed my coolant overflow was overflowing. Bled the cooling system and it seems ok, but keeping an eye on it. Head gasket? WTF is going on?
Also, I always thought when it came time to rebuild then I would have a motor built, but I DD and from what I've read, people with built motors are happy to get 30K miles out of theirs. That would last me a year and a half . I'd like to be at 450+ hp/tq. 2.3 and 2.4L sound good, but I'd like to get another 100K miles.
I plan to DD and maybe AutoX a little this summer. I'm looking for great driveability, low to mid range torque.
What do you all recommend?
100, 105, 110, 110
110, 105, 112, 110
There's no reason why a properly built "built" motor shouldn't last you. Yes, there is more stress on parts at a higher power level, however, if the clearances in your built motor are good you shouldn't have any problem making it last. I'll have a built 10:1 2.0L up for sale here in a few weeks as I'm changing setups
Good luck with whatever you choose!
I would definitely go 2.3rr/rpm (i.e. light weight rotating assembly) if you have a good core. If not go with a 2.4.
As far as longevity, it depends on a lot of things. Some motors last 30k miles at 800whp some last 5-10k. Depends on the driver, tune, mods, and a ton of other factors. Being that you aren't going buck wild, I think you would be more than fine.
From what I learned about this test is that even if the gauge is reading low, they are pretty close from cylinder to cylinder, means that's good.
