Transmission/ clutch problems
Old Apr 7, 2011, 11:50 AM
Braden71790's Avatar
So I got a new car and the transmission doesn't like to go into second sometimes when shifting up and will never go into second on a downshift unless I start to put it in first and then pop it in second. Reverse doesn't like to go in and grinds sometimes and I usually just start it in reverse. Then 5th gear grinds. The other thing is when the clutch is in all the way to the floor if the car is in reverse it will move on it's own without me even giving it gas. The dealership is buying me a new jacks transmission but I was wondering if this was a clutch issue too. Like maybe it was installed wrong. I have already bled the clutch to get any air out and that didn't do anything. The clutch is an exedy cerametallic twin disk. Any ideas? Thanks, Braden
Old Apr 7, 2011, 12:03 PM
kangzta's Avatar
Have you tried adjusting you clutch pedal?
kangzta's Avatar
It sounds like the CMC isn't adjusted right, so even with full pedal engagement, the clutch isn't disnegaging.
Old Apr 7, 2011, 12:04 PM
kangzta's Avatar
wait, you're getting the dealer to buy you a new tranny even with an aftermarket clutch?
Old Apr 7, 2011, 12:19 PM
Yes, I bought the car with all these parts and was told it ran perfect. Thats why theyvare paying for a new one. What do you mean the cmc isn't adjusted right? What is the cmc?
Old Apr 7, 2011, 12:48 PM
javicracer's Avatar
you need to adjust your clutch pedal.
Old Apr 7, 2011, 12:51 PM
Would that cause it to grind? I thought that would only effect the car not going into gear.
kusk8
Dec 29, 2016 01:36 PM
Juke
Feb 16, 2016 08:11 AM
deegaw11
12
Mar 19, 2011 01:50 PM
Braden71790
33
Dec 13, 2010 10:46 AM
GinNBoost
Apr 10, 2008 01:44 AM
Quick Reply: Transmission/ clutch problems
