Alignment required after clutch install?
Old May 18, 2011, 04:22 AM
Craig King's Avatar
I'm getting a new clutch installed soon and one shop told me part of the clutch installation price was a required alignment. Another shop quoted me a price and said an alignment was NOT necessary.
So which is it - is an alignment really needed after installing a clutch?
Thanks
Old May 18, 2011, 04:39 AM
oneofakindracer's Avatar
If this is for an 8/9 depending how they do the install an alignment may be needed.one set of instructions on here says you need to loosen the camber adjustments ot pop the axel out.I did not need to do this but the shop you are going to may be going by their book wich may be doing it this way.
Old May 18, 2011, 06:04 AM
boosted91t's Avatar
Mark the eccentric camber bolts, line up when you reinstall. But you shouldn't have to pull the hubs in the first place, just unbolt the a arm.
Old May 18, 2011, 06:57 PM
Craig King's Avatar
That's interesting - I wonder why this shop told me it was required to get an alignment. When I spoke to them to get a price quote for a clutch install, they also were going to charge me $129 for an alignment.
Old May 18, 2011, 07:11 PM
MitsuJDM's Avatar
Probably being they'll be disconnect the steering rack from the steering column. Chance of lining it back up to exactly the same spline is sometimes difficult and doing an alignment basically just an added level of confidence that the steering wheel will be straight.
Anytime I pulls a trans out, or drop a sub-frame with the steering rack for whatever reason, I do an alignment.
$129 for an alignment is A LOT!
Old May 18, 2011, 07:23 PM
Craig King's Avatar
That's what I was thinking... and that price was from a reputable shop right down the road from you...
Old May 18, 2011, 07:38 PM
project_skyline's Avatar
You don't need to touch the camber bolts or drop the steering rack.
Save yourself the money and do the job without removing bolts from that.
All you gotta do is take off the bolt holding the hub onto the ball joint and pull it off to remove the axle.
As far as pulling the transmission you can put a stap around the motor and ratchet it forward to pull it.
Old May 18, 2011, 07:53 PM
Craig King's Avatar
Thanks for all of the responses.
Old May 18, 2011, 07:56 PM
Gordian79's Avatar
Take it to another shop!i could only imagine what the clutch job is going to cost if aligment is $129.
Old May 19, 2011, 04:37 AM
Craig King's Avatar
They quoted me $695 for labor, $95 for fluids, $129 for the required alignment. So after tax, it was going to cost pretty much $1,000.
Old May 19, 2011, 03:53 PM
Thats ridiculous, most shops around here charge $400-600 flat rate.
Old May 19, 2011, 07:11 PM
bambooi's Avatar
I read that dropping the steering rack makes it a lot easier to reinstall the transmission. To avoid the alignment, you may mark somewhere on the steering to line it back up properly. Does anyone know where that mark is?
joonvang
Feb 24, 2017 08:08 PM
butters149
Jan 29, 2014 07:35 AM
AMF
Mar 25, 2010 04:16 PM
Clipse3GT
12
Jul 25, 2009 01:26 AM
LanEvoNine
Northeast Region
Oct 12, 2006 06:22 PM
Quick Reply: Alignment required after clutch install?
