DIY clutch install experiences! lets hear them!
So Im looking to upgrade my clutch and would like to save a little cash by doing the install myself. I have a quote for an install for $600, but would like to hear some install experiences. Is it worth taking this task on, or should I just eat the install cost? All feedback would be appreciated!
just dont strip any bolts.. use 6 points for 6 points and 12 points for 12 points......have all your sockets on evenly before you go twisting things off.. always use torque wrench.
i've done mine twice now...its actually pretty easy with a second pair of hands... if you look at evo moto's writeup, ... do that step by step and you should hav eno issues.... look it over first see if its something you can handle
It's a PITA. I come from hondas and have done over 50+ engine swaps with K's,B's, and D's so I'm experience. When I had my old MR, I had to take the trans out 4 times in a matter of 2 months. The last time I had to take it off, the TOB clip got stuck so I couldn't take the trans off. I tried taking out the pressure plate but one of the bolts got stripped. Ended up sending it to the shop anyways. It was probably the worst time I've had dealing with a car.
I sold that MR after this as I hated the situation so much. I picked up another MR as of late and guess what, trans went bye,bye as well. Well, I sent it straight to the shop as I was not going to screw with it again. Overall, if everything should go like it should then you're fine but if things starts to get stuck or something unusualhappens then you'll regret doing it in the first place. My .02
I just did mine about 3 weeks ago. I followed the evomoto.com write up and it went real smooth. It took about 11 hours to do it. Did it in a weekend no problem. Slide hammer is really the only special tool you need to pull the output shaft out of the tc. Getting the tranny out and in is really the most difficult thing. Its like trying to fit a square block in a round hole. But once you line it up just right it goes right up in there.
slide hammer you can rent from autozone.. i think it was like 50$ to rent. but just return it and u get ur money back..so all is well.
the kind they gave me has like three "fingers" on it.. so what i did was thread a screw into the shaft... and put a bolt with a large washer on it.... gripped the hammer on there best i could and it came off everytie with just one whack
I did mine out of my garage with an engine hoist. Made life much easy when it came time to install the tranny. Also be prepared for your hands and fingers to hurt for the next two weeks.
I have taken my transmission out about three times and have done it on other evos also. First of all, I recommend keeping the car as level as possible when it is on jack stands. I actually had mine leaning towards the front end a little more. The reason for this is so the engine isn't pushed back towards the firewall. When that occurs you have to fandangle the tranny to get it back on. Also, when taking the transmission off, do not pry on it. If you have taken all of the bolts connecting the block and transmission then it should slide off fairly easy. Lastly, I have seen some people use a metal slide hammer to insert the output shaft back in and that deforms all of the grooves resulting in a new shaft that had to be bought. I always use a long piece of 2x2 to insert mine.
Thanks for all the response! I think im gunna go for the DIY on this one. Now, I just need to decide on the clutch I want to use. Any recommendations? My power specs are 380 hp 340 tq... I don't track the car.. I may do a few runs at the local strip to see my times but other then that its my DD with a little spirited driving!! Thanks again EVOM!!!
