HKS 7460 Howling
HKS 7460 Howling
I bought the HKS 7460 turbo/cams combo back in October time frame. The turbo sat in plastic until a couple weeks ago when I had all other parts to install with it. I installed the turbo, new exhaust mani, and switched to speed density along with other minor parts. It was installed with the newly supplied oil/coolant lines. Here we are <1000 miles later and I have noticed this howl only when I begin to boost. I have contacted the vendor and they believe they will have to send it to HKS for warranty claim/etc if it comes to that.
Does anyone have any suggestions that I could cause this noise, or any advice for this situation?
I tried to attach a audio file but it wont upload to photobucket or youtube.
Thanks in advance
Travis
Thanks in advance
Travis
The noise is not consistent with rpm or speed. It only happens when I begin to boost. Therefore I'm leaning towards the turbo itself or something pressurized.
Thanks
Travis
I had an Evo 9 turbo that made this noise. It was blown and I replaced it with the HKS turbo. Any oil leaks?
I also once had a 35R with a few thousand miles just die on me and I had to buy a new one because it was over a year old. Contact the vendor.
I checked the turbo for shaft play last night. Being that its ball bearing, I understand it should have play, but I'm unsure of whether its too much for BB. The howl is at partial or full throttle, but timed right when boost begins till I lift throttle. I will do another boost leak test this weekend or sooner if I can get off work before dark. Thanks for everyone's help thus far.
Travis
Travis
Travis
Travis
Thanks
+1 on blades contacting housing, however it could be the bearings not getting enough oil. I had a brand new turbo do this b/c the shop that installed it on my honda used teflon tape on the oil line and it dissolved and blocked up the oil passages. It sounded like a ghost wailing and soon after well....
The turbo is still on the car. Its been sitting. Havent had the chance to remove it. However, there are not signs of the blades touching the housing and I really hope its not a oil starvation item considering bb turbos dont need that much oil to begin with anyways.
I am swapping parts out tomorrow starting with the FMIC. A lot of parts went on at the same time as the turbo so its time to eliminate some. I will let everyone know how it goes.
Travis
Travis
possible reasons include over spinning turbo, turbo out of balance, trash in oil, or oil quality not high enough. Blouch will likely blame you and not warranty turbo. Even when it may have been turbo builders fault. This is where FP shines. no questions asked warranty first failure.
