Manual boost controller or Electronic/ECU boost control? Which one?
Old Feb 13, 2011, 05:25 PM
TheMadScientist's Avatar
Which one do you recommend/like/use and why?
Old Feb 13, 2011, 05:42 PM
casper980's Avatar
I use the Autronic stand alone in my car for boost control, I am able to hold rock solid boost all the way to the 8700RPM redline. ECU based FTW! As long as your tuner knows how to setup ECU based boost control I don't think there is anything better.
Old Feb 13, 2011, 05:51 PM
binky's Avatar
I personally like a manual boost controller. The Hallman to be exact.
It's easy to use and anyone can adjust it.
-Bink
Old Feb 13, 2011, 06:02 PM
RSMike's Avatar
+1
I'm using a Link Ecu (www.linkecu.com) and i'm using ECU boost control.
100% rock solid and flat boost curve.
It can also reduce your boost levels if your water and/or oil temp is too high for extra safety.
win win win
Old Feb 13, 2011, 06:15 PM
blaze-619's Avatar
-Bink
+1 on the hallman. Very easy to adjust.
Old Feb 13, 2011, 06:20 PM
Pizzamangtr's Avatar
aem trueboost here. Used on stock ecu, stock ecu sd, aem ems now. Holds boost perfect for me. On all logs boost held the the whole way to redline.
Old Feb 13, 2011, 06:23 PM
n2oiroc's Avatar
manual for me. spools faster than any electric controller.
Old Feb 14, 2011, 06:25 AM
dieselmd's Avatar
I wouldn't agree with this statement as I have found the opposite to be true. I used two manual controllers before I switched to an electronic one.
Old Feb 14, 2011, 06:32 AM
cij911's Avatar
That makes no sense to me ... As long as the WG is not getting any boost pressure the spool should be the same for ECU vs MBC controlled boost....Where ECU boost should be better is if you want to control your torque spike, but still hold power up in the higher rpms (e.g. my setup - stock block ).
Additionally, the ECU controlled boost, using Tephra v7, allows you to kill boost should your knock get above a certain level (you define the counts). This to me is the best reason for keeping the ECU controlled boost.
Old Feb 14, 2011, 06:48 AM
Jrah2987's Avatar
Yeah I'd either go ecu or TruBoost.
TruBoost holds boost great, has many settings and features, and lets you change your boost settings on the fly if you live in a state that is hot one day and cold the next. Has a few safety features, but nothing like ecu controlled.
When it comes down to it, get the TruBoost, Hallman, or Ecu controlled and you'll be fine.
Old Feb 14, 2011, 07:09 AM
05VIII's Avatar
use to run a hallman.
simple.
easy.
loved it.
then switched to a grimmspeed and love it even more!
hold boost all the way to redline and it is more constant. spools a little faster as well.
ECU boost control is much better, specially if you do dual maps.
Old Feb 14, 2011, 07:32 AM
Cali 18's Avatar
i agree
Old Feb 14, 2011, 08:11 AM
dastallion951's Avatar
let me add my 0.02 op, ive ran greddy profec b spec 2 ebc, was good a little hard to dial it in, but worked good till it failed on the dyno, swapped to dejon tool mbc which works well but youll get some boost taper in the top end, and when i go back for a retune with map rev 2 intake mani tb, and some kelford cams, swappin out that mbc for a gruppe s 3port so i can hold more boost to redline, personally, get a 3port itll do the best, it can be integrated to work with the stock ecu, and no one can mess with it while the hoods popped haha
Old Feb 14, 2011, 08:14 AM
RunThat's Avatar
Buschur dual-stage manual boost controller FTW!
Old Feb 14, 2011, 02:01 PM
Another benefit I have seen from ecu/electronic boost control is the ability to control boost and control tire spin. I know we're awd but tire spin still happens.
I'm hoping buschur chimes in here as well. He seems very against ecu or electronic boost control and I would like to here his insights.
Quick Reply: Manual boost controller or Electronic/ECU boost control? Which one?
