Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Nov 17, 2010, 03:02 PM   #1
Personal Sales Rating: (12)
Garage is empty, add now
Drives: 2006 IX GSR SE
Points: 2,961, Level: 33
Points: 2,961, Level: 33 Points: 2,961, Level: 33 Points: 2,961, Level: 33
Daily Activity: 38.5%
Daily Activity: 38.5% Daily Activity: 38.5% Daily Activity: 38.5%
metal vs. silicone intake tubes?
ive been reading around for like two hours now, and i cannot find and concrete reasons why one may be better than the other.
i have already read through all the filter test stuff, and my car came with an amsoil filter on it utilizing the stock intake pipe. obviously i am looking to upgrade that since it can be worth 10-15hp from what ive gathered.
so does anyone have any concrete evidence as to if/why one material is better than the other? i like the perrin setup and the new release is about to be released, but i cant use it if i upgrade turbos in the future. the ets is nice and i do like their products and it even sounds like there are no idle issues with the new version.
i have searched plenty of threads on both intakes, but i can only find concrete evidence on the filters and not the pipes.
__________________
Cobb cat back//Megan dp//BERK hi flow//DW301//ETS 3.5in//ETS LICP//Perrin intake//Sparktech//Whiteline sways//Ohlins//Torque solutions//Racing Brake//340ish whp//320ish wtq.
Offline
Old Nov 17, 2010, 03:14 PM   #2
Personal Sales Rating: (0)
MatosEvo's Avatar
Drives: Evo VIII
Points: 344, Level: 6
Points: 344, Level: 6 Points: 344, Level: 6 Points: 344, Level: 6
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Metal vs Silicone? Hmm, if both intakes are of the same design and have the same inner diameter and the same filter on them, there should really be no difference. The material of the pipe itself won't hinder or benefit the flow unless the surface roughness is different, ie one being rough and one smooth. However, both will most likely be smooth on the inside and the difference, if any, should be negligible as far as I can tell. Someone might argue that they
1. have different heat transfer properties
2. that the silicon could potentially bend or get kinked and reduce the flow area
but
1. the intake air goes into the turbo and gets heated anyway, so this difference is negligible.
2. the silicon product is not very likely to get kinked and cause a problem unless you applied a force to it in order to cause this.
__________________
Otters are really stupid animals.
Offline
Old Nov 17, 2010, 03:33 PM   #3
Personal Sales Rating: (22)
Drives: 04 evo 8
Points: 19,121, Level: 87
Points: 19,121, Level: 87 Points: 19,121, Level: 87 Points: 19,121, Level: 87
Daily Activity: 0%
people/Tom-Swingler-III/100000520629937
Send a message via AIM to tscompusa2 Send a message via MSN to tscompusa2 Send a message via Yahoo to tscompusa2
silicone works way better if you're still on mass airflow sensor. the metal intake pipes create vibrations that mess with the maf reading.
Offline
Old Nov 17, 2010, 05:30 PM   #4
Quote:
thats in interesting piece of info. but how are vibrations messing with the maf reading? and how much of an influence is it?
some reading seems to point to the new ets metal pipe working quite well since it was designed around a stock car. but i cant get a tune any time soon, so i dont want to wind up with a crappy idle..
__________________
Offline
Old Nov 17, 2010, 05:40 PM   #5
Personal Sales Rating: (108)
2003 Mitsubishi Lancer Evolution
AF-Evo8's Avatar
Drives: The Mistress is Back
Points: 7,719, Level: 58
Points: 7,719, Level: 58 Points: 7,719, Level: 58 Points: 7,719, Level: 58
Daily Activity: 2.0%
Daily Activity: 2.0% Daily Activity: 2.0% Daily Activity: 2.0%
because evos use a karman vortex mass air flow sensor, it reads the air passing over/by the sensor so vibrations in the air can cause it to read incorrectly thus causing rich/lean spots
__________________
Check out my F/S Thread - Updated 23 Feb 2013
Parts F/S, Precision 46mm Wastegate, T67 P-Trim DBB, Weld-on AN Fittings, Prosport Tach, Turbosmart dual stage boost controller, and many oem parts... etc etc
http://forums.evolutionm.net/sale-en...b-etc-etc.html
Offline
Old Nov 17, 2010, 05:59 PM   #6
thanks for that, didnt know it was such a specific maf, im used to just a straight through GM style hot wire maf setup on my other car.
so i guess the question is then has ETS really made the new intake any better?
the damn samco pipe alone is quite pricey. i like the perrin intake but that too is quite pricey and who knows what the availability will be after re-release.
__________________
Offline
Old Nov 17, 2010, 06:43 PM   #7
GHOSTN's Avatar
Points: 4,582, Level: 43
Points: 4,582, Level: 43 Points: 4,582, Level: 43 Points: 4,582, Level: 43
Daily Activity: 0%
Is perrin re-designing their intake? When is it set to be re-released?
Offline
Old Nov 17, 2010, 06:59 PM   #8
Personal Sales Rating: (14)
xmaciek82x's Avatar
Drives: Evo IX
Points: 10,052, Level: 67
Points: 10,052, Level: 67 Points: 10,052, Level: 67 Points: 10,052, Level: 67
Daily Activity: 0%
You can pick up a perrin or samco pipe here used for well under $100 if you look around.
I think I paid around $60 shipped for my perrin one. I use it for both MAF setup with no issues and when I run SD with a much larger filter. Also perrin one has a nice transition from the 3" maf opening to the stock 2.5" turbo inlet. Most metal intakes use a coupler by the turbo for this transition. If want to be picky, you can argue that this causes turbulence.
__________________
Make it idiot proof and someone will make a better idiot.
When blind people go crazy do they think the voices in their head are real people in the room?
Offline
Old Nov 18, 2010, 02:42 AM   #9
FJF
Personal Sales Rating: (18)
FJF's Avatar
Drives: IX SE
Points: 21,577, Level: 92
Points: 21,577, Level: 92 Points: 21,577, Level: 92 Points: 21,577, Level: 92
Daily Activity: 0.4%
Daily Activity: 0.4% Daily Activity: 0.4% Daily Activity: 0.4%
...obviously i am looking to upgrade that since it can be worth 10-15hp from what ive gathered.
If this were so, every Evo here would have an aftermarket intake pipe. Clearly, that is not the case.
Offline
Old Nov 18, 2010, 03:05 AM   #10
Personal Sales Rating: (20)
Evoardo IX's Avatar
Drives: '06 Evo IX RS, '06 Montero SWB
Points: 5,570, Level: 48
Points: 5,570, Level: 48 Points: 5,570, Level: 48 Points: 5,570, Level: 48
Daily Activity: 7.2%
Daily Activity: 7.2% Daily Activity: 7.2% Daily Activity: 7.2%
I've read that changing the intake filter does reflect in gains or loses for the evo, but I haven't heard anything on the intake tube itself. Only gain on a metal intake is the sound of the DV, I have the ralliart intake BTW, it sound cool.
__________________
AMSOIL dry cone filter, Samco intake hose, Buschur V-Band 3" TBE, Nisei full IC pipes, GM 3-port BCS, ported Ex Mani, hotside and O2 housing, Walbro 255 pump, RALLIART spark plug wires, Bilstein PSS9 coilovers, Hotchkis rear swaybar, WORKS full trunk cage and WORKS front strut bar, Girodisc CUSTOM 2-piece rotors, Girodisc SS brake lines, DS2500 pads
TSCOMP tuned
Offline
Old Nov 18, 2010, 03:07 AM   #11
Personal Sales Rating: (8)
MR. EVO MR's Avatar
Points: 11,400, Level: 70
Points: 11,400, Level: 70 Points: 11,400, Level: 70 Points: 11,400, Level: 70
Daily Activity: 2.3%
Daily Activity: 2.3% Daily Activity: 2.3% Daily Activity: 2.3%
the silicone couplers should stop the vibration in the metal ones.
Offline
Old Nov 18, 2010, 10:51 AM   #12
Drives: 04 evo 8
Daily Activity: 0%
If I put the stock air box back on my car id lose around 30whp guaranteed. yes the stock airbox sucks and is EXTREMELY restrictive!
Offline
Old Nov 18, 2010, 10:55 AM   #13
Drives: 04 evo 8
Daily Activity: 0%
Quote:
You would think. But ive never seen a metal intake that didnt require maf scaling to make the car work to the best of its ability, where as a silicone intake requires no scaling because there are no interruptions between the maf and intake.
The only thing bad I can say about the silicone intakes is this; They are a pain in the *** to take off and on because they are so tight its so hard to fit them over the turbo inlet. You pretty much need to remove it from the maf first to get it over the turbo then you gotta fit the maf back and in order for me to do this i use a screw driver to wedge it back on like a small shoe fitting a big foot.. yes its annoying and when they are new they are even harder to fit over
Offline
Old Nov 18, 2010, 11:08 AM   #14
FJF
FJF's Avatar
Drives: IX SE
Sure, when you're running a 2.3 with a Black on a double-pumper. On a stock-ish car...
Offline
Old Nov 18, 2010, 11:38 AM   #15
Drives: 04 evo 8
Daily Activity: 0%
Quote:
stock evo about 8-10whp depending on airflow being pushed.
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
air, box, cobb, evo, evolution, intake, make, metal, samco, silicone, tube, tubes, tune, turbo, turbocharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
