Lots of Uh-Oh noises from rear end
Old Nov 17, 2010, 12:49 PM
Babs's Avatar
OK so this problem just popped up in the last 2 days or so and I'm really upset because if it's what I think it is, I might not be able to take my car to the CenFla Procco meet this Saturday which I've been planning for a few months now .
So there is a loud whining/whirring noise coming from my rear end (definitely rear end) that can basically be heard at any RPM. Under 40, it sounds like loud tire noise. At 55, you can start hearing a sound kinda similar to straight cut gears but not deafening. At 80, it starts to sound like a table saw.
The big thing is that it still does if even when I throw it into neutral so I've definitely ruled the transfer case out. My heart is saying the rear diff but I wasn't sure if throwing the car into neutral would have any effect on it.
Another thing is that I just changed the rear diff fluid again yesterday (AMSoil) and when I pulled the drain plug out, there was minimal metal shavings on the magnet...more like metal dust.
So what do you guys think it is? Rear diff? Something in the axles? Extremely loud tires?
Help me out!!!
Old Nov 17, 2010, 05:26 PM
gotWankelz's Avatar
I would suggest that, even though youy don't think its the t-case, to check the fluid anyway. I had the ring and pinion sheer off on one and it FELT like the issue was in the rear, but it was the vibration traveling down the drive shaft to the rear of the car. And if it does turn out to be the t-case, get it fixed BEFORE the ring and pinion shear off, it gets REAL exspensive when that happens...
Old Nov 17, 2010, 06:11 PM
Babs's Avatar
But the sound is still there when I put it in neutral. That excludes the transfer case from the running list of potential problems.
Thanks for the input though.
Old Nov 17, 2010, 06:24 PM
compscibOi's Avatar
Like this:
http://www.youtube.com/watch?v=Au8fOnZ1uNQ
Old Nov 17, 2010, 08:19 PM
Babs's Avatar
Originally Posted by compscibOi
No that sounds like a very bad transfer case. I'll try to get a vid tomorrow but I'm almost positive it's the rear diff now.
Looks like I'll be calling up TRE soon.
Old Nov 17, 2010, 08:31 PM
sho669's Avatar
Whats the fluid look like in the rear diff?
Old Nov 17, 2010, 08:41 PM
Babs's Avatar
It was pretty damn golden coming out. Just like when I put it in. And there weren't even any shavings on the magnet, just a few specks of metal.
Doesn't make sense to me...
Old Nov 17, 2010, 09:33 PM
still*boostn's Avatar
hmmm,.. well looks like both of us arent going to make it, you rear end and my mivec banjo bolt.
hmmm. if youve check the fluid ouve obviously changed it,.. TRE or Shep it is..
Old Nov 18, 2010, 12:04 PM
barneyb's Avatar
If you are in neutral and rolling the transfer case is turning.
Old Nov 18, 2010, 12:16 PM
Babs's Avatar
Yea I just realized that this morning
Ugh...so much for a cheap rear diff rebuild...
Old Nov 18, 2010, 12:30 PM
Babs's Avatar
What is a surefire way of determining what it is exactly? I'm still not sure if it's the rear diff or transfer case. I haven't launched my car in forever and this just popped up a few days ago.
Old Nov 18, 2010, 02:20 PM
hmmm, how many miles are on it? get someone to sit in the back and when your driving open the door and listen,... buckled up of course,.. what I would do.
Old Nov 18, 2010, 03:22 PM
PATRICK B.'s Avatar
Kind along read but off our local forum if you care to read it just ghoes to show that how you can think it coming from somewhere but isn't
http://evoempire.org/index.php?/topi...ost__p__169673
I would never rule out the TC just by putting it in neutral as noises can and will travel up and down the d/s!
SyncdLancer
Sep 29, 2016 04:39 PM
Treyzian
Dec 14, 2015 05:09 AM
blueprint
Aug 19, 2014 05:17 PM
jrank3792
Feb 4, 2012 11:55 AM
jds433
Lancer Troubleshooting
Apr 19, 2010 06:36 AM
Quick Reply: Lots of Uh-Oh noises from rear end
