2.1, 2.2, 2.3, 2.4 motors / strokers
#213
Depends on the brand Gergo, some of them are lighter than the standard 150mm rods in use. The current GSC H beam is 607g, the new releases will be lighter yet. The R&R Steel are 588g for the 159mm
Weight list as given by Ted B on some namebrand 150mm rods-
Stock = 695 grams
Aluminum:
GRP = 470 grams
Map = 470-480 grams
Groden = 490 grams
R&R = 500 grams
All other material:
Crower titanium = 410 grams
Carrillo = 520 grams
Engine pro = 557 gram
Manley H beam = 573 grams
Eagle = 575 grams
Oliver = 605 grams
Pauter lightweight = 610 grams
Crower = 612 grams
Scat = 640 grams
Map billet rods = 652 grams
Pauter = 685 grams
Manley I beam = 690 grams
Stock = 695 grams
Aluminum:
GRP = 470 grams
Map = 470-480 grams
Groden = 490 grams
R&R = 500 grams
All other material:
Eagle = 575 grams
Oliver = 605 grams
Crower = 612 grams
Scat = 640 grams
Pauter = 685 grams
#215
Yes, Ron of course you can but stop by so we can talk about it. There are some extra expenses to building this one we have to go over, because of parts costs. Let me know ASAP I think your engine is going together very soon.
AMS's 2.3RR engine I believe is based on the 4g64 block, right? I have no desire to do an engine like that, this one is 4G63 blocked.
#216
Stock = 695 grams
Aluminum:
GRP = 470 grams
Map = 470-480 grams
Groden = 490 grams
R&R = 500 grams
All other material:
Eagle = 575 grams
Oliver = 605 grams
Crower = 612 grams
Scat = 640 grams
Pauter = 685 grams
Stock = 695 grams
Aluminum:
GRP = 470 grams
Map = 470-480 grams
Groden = 490 grams
R&R = 500 grams
All other material:
Eagle = 575 grams
Oliver = 605 grams
Crower = 612 grams
Scat = 640 grams
Pauter = 685 grams
I think that Carrillo weight is for their A-beam design, not their H-beam.
#218
PERSONALLY i am ok w/ only 8-8500 rpms
i think i have my build started and on its path.. with the help or aaron at english racing and some overnight parts from japan
i plan on going ricky bobby fast in the near future
2.4l block at the machine shop getting cleaned up and line honed for the arp main studs and having the cyl. bore checked for wear and see if i can run a 86.5 or go to a 87mm piston
156mm gsc rods
stock balanced crank
cometic h.g.
aem cam gears
acl bearings , x mains and h rods
arp L19 head studs
and a few other goodies very xcite!
shooting for around 600 possibly 700 awhp
156mm gsc rods
cometic h.g.
aem cam gears
arp L19 head studs
#219
156mm gsc rods
cometic h.g.
aem cam gears
arp L19 head studs
156mm gsc rods
cometic h.g.
aem cam gears
arp L19 head studs
wow i get no love in that thank you message fiqures
#221
no issues at all
The car is a true daily driver that I commute to work in! It pretty much gets thrashed on every day! I've pretty much stopped even thinking of engine problems with this build, It has been rock solid!
drivetrain challenges are another matter though!
John-
#223
David's got me pretty stoked about this 2.3, ive always have run 2.0's but since im sticking with stock framed turbo's there is no real need to exceed 8500rpm except the top of 4th gear at the dragstrip wich has been a twice a year thing anyways. This build is more of a real nice street car, we made 481whp and 451tq on Buschurs dyno with the 2.0 and Green spiking 34psi falling to 25, I will be real curious of the new motor overlaying that chart. Cool thing about this 2.3 is it will probably make the same power on pump as the car made on E85 being the 2.3 is more pump gas friendly.
#225
cometics leak now before people say it there are people out there that have these types of hg and they are perfectly fine i would just not use one from all the information i have read
Have heard nothing but positive things about the Power enterprise gasket cost more yes but gets the job done
Dont forget Ams custom hg as well. i along with a couple others have it no issues. great product
if your looking for the budget buy then cosmetic wins
