title says all. What is the differences between and Evo 8 shortblock and a Evo 9 Shortblock. Should i have any problem putting a Evo 9 shortblock into my Evo 8 car
only difference is the oil feed for the mivec on the back of the block. All you need is an adapter to mount the oil pressure sensor there if you want to use an evo 9 block in an evo 8. AMS sells the adapter
only difference is the oil feed for the mivec on the back of the block. All you need is an adapter to mount the oil pressure sensor there if you want to use an evo 9 block in an evo 8. Ams sells the adapter
I have a 9 block in an 8 and just used that port to feed oil to the turbo as the port on the head is damaged. Most likely gets better pressure there as well.
