Transmission guru's chime in please.
evo can shift through all the gears fine..car idles fine.
put it in neutral and try to push the car.. it doesnt move. feels like when i put it in 1st gear.
try to move the car forward or in reverse the car will stall due to something holding the evo back.. not allowing it to move.
i have an exedy tripple disk, i press in the clutch i hear chatter of the disk, i release it it goes away. TOB seems to disengauge fine..
what do u guys think is the problem?
Could be:
1) Busted Front differential (car should still push through it, but it will make horrendous crunching sounds)
2) Locked transfer case (probably it ) ring gear, pinion gear, etc. (the car will bounce back from clutch application like there is a "lock pin" in the gear--kind of like trying to push an automatic car in "park")
3) Maybe bad rear diff (never had this issue myself though)
4) Stuck e-brake (less likely)
