Feb 5, 2010, 12:36 PM
Personal Sales Rating: ( 19)
Drives: evo 9 , Cutlass DD
2.4L 4G64 Built Short block setup, anyone with their Evo 8/9
I am thinking of 2.4L 4G64 Short block setup for my mivec head...would like 800hp Safely...anyone has similar setup, which internals are good for the build, any recommended shops ? Idea of how much it cost to build one by reputable shop ?
Any info helps !
Offline
Feb 5, 2010, 12:40 PM
Personal Sales Rating: ( 5)
Drives: 2006 Mitsubishi Evolution IX MR
there are a couple of shops who offer this. i know buschur does this as well as maperformance. there are a couple of threads around regarding these 4g63 builds.
Offline
Feb 5, 2010, 12:51 PM
Personal Sales Rating: ( 2)
Drives: 2006 mitsubishi evolution IX SE
BR, 2.4, high hp/high rpm build? here is what id recommend. on page 11 is a link to the build and on the last page of that link the owner does a nice review after driving with the new engine for a couple weeks
__________________
AMS TB, AMS FMIC & LICP, megan 02, AMS fuel rail, Deatchwerks 880's with walbro pump, E85 tune.. stock turbo 352awhp/ 392 awtq on AMS dynojet..... just installed FP Green 73HTA, tuned by mellon
Offline
Feb 5, 2010, 12:54 PM
Silver Sponsor
Personal Sales Rating: ( 22)
Drives: 06 Rally Red MR
We just did one as well with a Black. Change the rods to Turbo Tuffs or an I beam of some other build, add Large turbo, profit.
Offline
Feb 5, 2010, 04:19 PM
Personal Sales Rating: ( 0)
Drives: Black EVO 9 Black '92 Eagle Talon
The 2.4 block rod/stroke ratio isn't particularly rev friendly (8000 is probably about the safe max rev limit). Going with a turbo capable of 800 will put you in a situation where your useable powerband is pretty small.
A long rod 2.4 can help offset the rev limitations some.
John-
__________________
4g64/MIVEC/FPBlack
92 Octane -> 524hp
e85 -> 624hp
Bilt it Myself!
Daily Driven fun
Offline
Feb 5, 2010, 04:23 PM
Drives: 2003 Evolution 8 / 2001 VW GTI / 1993 Lexus SC
I think its more than fine with a good crankshaft, better than a 2.3. Look what the 2.4L K series with 100mm stroke rev to.
Offline
Feb 5, 2010, 04:31 PM
I know SBR is known for building these 2.4L short blocks...but aside from the block, what needs to be modified to work with the mivec head ????
Offline
Feb 5, 2010, 05:34 PM
really only three things that are "odd" with this build:
- Oil supply for the MIVEC head Aaron (JohnBradley) posted some pics of an oil supply line here: (JohnBradley's 2.2 long rod build)
- Water Pump needs modified or an adapter plate used
- Head Gasket choices are slim, the Power Enterprises looks to be the best bet
The only other item of interest is to have the block machined for oil squirters or not. (I went with no squirters on mine)
John-
__________________
4g64/MIVEC/FPBlack
92 Octane -> 524hp
e85 -> 624hp
Bilt it Myself!
Daily Driven fun
Offline
Feb 5, 2010, 06:10 PM
Drives: 1992 Galant VR4 #14/1000, 2.3 Aluminum rod, 10.5:1, APM CNC 1G Head, Kelford 288 cams, Supertech valvetrain, 3586 HTA 1.06
Quote:
The rod ratio of the stroker 2.3 4G63 and rod ratio of the 2.4 4G64 are the same. 100mm stroke with 150mm rods. The rod ratio of the engine really determines RPM. There are ways around it like a lighter rotating assembly,stronger assembly or do a longer rod in the 4G64 which would change the rod ratio. The biggest difference between the 2 builds is cost a 4G64 core is a lot cheaper than an Evo core. This is why you see more people trying the 4G64 block.
Offline
Feb 5, 2010, 06:34 PM
Silver Sponsor
Ryno knows of what he speaks as does Johnny (he is def not a noob to the 4G63/4) I'd like to throw out there that I might know one or two things...not much more.
R/s is a small part of the equation I am starting to think and has been confirmed by a lot of the OGs that know what is going on (4G specific or not). Piston speed is far more critical than I used to think, well fully attribute anyway. Like Ryno says, get the weight out of the reciprocating mass.
Offline
Feb 5, 2010, 06:46 PM
Personal Sales Rating: ( 6)
Drives: TB Evo IX
I would say that Ryno isn't making a fair comparison to say that the R/S ratio for the 100mm 4g63 would be the same as the 100mm 4g64.
Given the same compression height of the pistons (which is really what you want to keep constant...NOT rod length when you have a taller deck) You end up with a 6mm longer rod...making the R/S ratio better. There is a benefit to a taller deck and that is the R/S ratio...which means you'll be applying a much smaller load to the con rod @ BDC. The higher you rev the larger this load is and the harder it is to keep bearings in your engine.
Run a longer rod in a 4g64 block with the 100mm crank... it will live longer given the same rev's and loads.
__________________
R/TErnie Race Engineering
2020 Motorsports
English Racing
Mitsubishiparts.net
Extreme Turbo Systems
Girodisc Brakes
JE Pistons
Magnus Motorsports
Offline
Feb 5, 2010, 08:19 PM
Drives: 2006 Mitsubishi EVO IX
Offline
Feb 5, 2010, 08:37 PM
I was just comparing the standard 2.3 stroker kit to a standard 4G64. Yes as i mentioned there are ways around the "bad" rod ratio of both set ups. You would need custom pistons and rods which are available to build a longer rod version of the 4G64. The standard 4G63 2.3 L and standard 4G64 share the same 1.5 rod ratio and even with custom pistons and rods you get a very minimal increase to 1.56 still not very good. I would rather see something around 1.7 + like the stock 4G63 or the 2.2 or 2.1 versions of the 4G64. For me personally the 2.3 and 2.4 are great street engines(torque) and even in long rod for should stay around 8500RPM max which is perfect for 95% of the Evos out there anyway. Shooting for 800 whp without spinning it up may prove to be difficult but i myself am actually trying it with a 2.3 lightweight crank,aluminum rod ,custom piston stroker on an earlier 6 bolt 4G63 for my Galant
Offline
Feb 5, 2010, 09:05 PM
what abt these ingredients:
2.4L EVO VIII race block
OEM 100 MM crank
Manley I beam rods
Wiseco 8.8:1 .020"
ACL race bearings
Offline
Feb 5, 2010, 09:14 PM
Personal Sales Rating: ( 156)
Drives: 2005 Evo RS.. 1st Street Evo in the 8's!!
OEM 100 MM crank
Manley I beam rods
Wiseco 8.8:1 .020"
ACL race bearings
8.8:1 compression IMO was for sometime long ago before good tuning and fuel was available.. 10:1 minimum is the only way i would be build an 800hp car today..
Below is a link to our 2.4L Mivec Evo.. Tomorrow we tune on FP BLACK..
AWD Motorsports " Bastard " Evo 8.5 makes 552whp/552tq on BBK Full!!!!
__________________
Tel. 954-753-6006
AIM= mikeatawd
www.AwdMotorsports.com
- 2003 Black Evo GSR - 8.75@163mph (US Quickest 4g63 Evo )
- World's Quickest Evo 8 Street Car - 8.98@156mph
- World's Quickest / Fastest Stock Ecu - 8.99@163mph
- World's Quickest / Fastest Drag Radial Evo 8/9- 9.05@160mph
- World's Quickest / Fastest Mivec Evo - 8.99@163mph
- World's Quickest Stock Frame FP Black - 9.33@146mph
- World's Quickest / Fastest Stock Turbo Evo - 10.21@133mph ( Most-Wanted )
Offline
Tags
20l, 24, 24l, 4g64, block, build, built, engine, evo, evolution, fast, ix, shortblock, stock, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
