View Poll Results: What should I buy?
Cams (kelford 272's or GSC S2's)
8 |
36.36% |
Meth kit of some kind
1 |
4.55% |
E-85 (1250cc or so injectors)
11 |
50.00% |
Evo 9 turbo
2 |
9.09% |
Other combination??? Please specify.
0 |
0% |
Feb 1, 2010, 12:14 PM
Personal Sales Rating: ( 7)
Drives: TB 2003 Evo V///
Spending around $900. Meth, e-85, cams or turbo?
Alright, it's decision time. I'll be spending about 900$ on the car in the near future and need to decide the biggest bang for the buck mod that will put more further down my path.
The final goal with my car is to make in the neighborhood of 500-550whp. I plan to get a red or black most likely to achieve this goal, so I know i need a few things to make that happen, like more fuel and/or meth, bigger cams, bigger turbo.
So....I will basically have enough money for a mod or two plus a new tune, figuring the tune is 400$. So we're really working with 500$ here. Let your opinion be heard! Mods are in the sig.
Edit: I have been waffling on going e-85 for a while since I really don't want to deal with the drop to e-70 in the winter or having to drive up to chicago again to get tuned when winter rolls around with the lower octane gas. That is why I have re-opened my options to using a 50/50 meth/water mixture as my octane additive.
__________________
2003 TB Evo VIII
Built 2.0L by Ron @ Axis
Tuned by Mellon
CP Pistons // Pauter Rods // Cosworth Main and Rod Bearings // AMS BSE kit // Supertech Dual-Spring kit // Mild Valve Job // BC 272s // ACT XTSS // Blox Lower Mount // Walbro GSS 342 // PTE 1200s // Evo IX Turbo // Meghan O2+Ebay TBE // Hallman Pro RX MBC // Forge RS BOV // AMS LICP // AMS FMIC
Offline
Feb 1, 2010, 12:19 PM
Silver Sponsor
Personal Sales Rating: ( 8)
Drives: 03 Evo
A set of Kelford cams will help you now and in the long run but E85 will give you the biggest gains and the fun factor of driving your car right now, when you switch you'll never want to go back to pump. Just pick up a set of injectors and a good tune and you're good to go.
__________________
We have lots of parts in stock!!!
ASAP Performance
pm or email us!!!!
We've gone 10's, 9's, and 8's are coming up shortly!!!!
Click here for our FPBlack + more turbo sale!!!!
Click here for our EvoX sale!!!!
Tuning is available for Evo VIII/IX and X's.
Check out our website!!!
www.asaperformanceparts.com
Email:
asapperformance@gmail.com
Some Of the Fastest Evos Built/Driven By Me
Offline
Feb 1, 2010, 12:21 PM
Quote:
Check my edit above. Is it certain that there is actually a drop to e-70 in the winter? I was at an e-85 gas station yesterday and the pump did specify that there was a minimum of 85% ethanol so that would lead me to believe that they carry e-85 year round, or is that their mislabeling?
__________________
2003 TB Evo VIII
Tuned by Mellon
Offline
Feb 1, 2010, 12:23 PM
Personal Sales Rating: ( 0)
Drives: evo 9
Quote:
Meth kit aquiamist with a flip map ..
Offline
Feb 1, 2010, 12:24 PM
Silver Sponsor
Drives: 03 Evo
I think its mislabeling on their part, Im pretty sure they all have to lower the ethanol content because of the weather/temperatures. Im not a big fan of meth but if you can find someone to install it and tune it properly that's also a good option.
__________________
ASAP Performance
pm or email us!!!!
Email:
Offline
Feb 1, 2010, 12:25 PM
Personal Sales Rating: ( 17)
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
Why would you want to go meth when E-85 is readily available in his area? E-85 is safer and cheaper than conventional meth systems.
__________________
84mm FP Green 73HTA
BuschurRacing 2.1L w/Stage 3 Head
Shep 5-speed w/ Exedy Twin HD
Injector Dynamics 2000cc
Full Blown Double Pumper
Robispec/ / / KW3 Custom Clubsports
E-85 Ethanol
For Sale List
Offline
Feb 1, 2010, 12:26 PM
Personal Sales Rating: ( 156)
Drives: 2005 Evo RS.. 1st Street Evo in the 8's!!
I would do the 9 turbo + E85.. that should fit your budget close..
Mike
__________________
Tel. 954-753-6006
AIM= mikeatawd
www.AwdMotorsports.com
- 2003 Black Evo GSR - 8.75@163mph (US Quickest 4g63 Evo )
- World's Quickest Evo 8 Street Car - 8.98@156mph
- World's Quickest / Fastest Stock Ecu - 8.99@163mph
- World's Quickest / Fastest Drag Radial Evo 8/9- 9.05@160mph
- World's Quickest / Fastest Mivec Evo - 8.99@163mph
- World's Quickest Stock Frame FP Black - 9.33@146mph
- World's Quickest / Fastest Stock Turbo Evo - 10.21@133mph ( Most-Wanted )
Offline
Drives: evo 9
Good point install is very important but if u cant hookup the new hfs 3 then your dumb Aquamist's new HFS-3 for 2010, replacing the HFS-1
Offline
Feb 1, 2010, 12:29 PM
Drives: evo 9
Quote:
traveling plus cold start issues also been hearing u should run a gauge now to se how pure the e 85 is????Im not gonna lie if i can run e*5 around my area i would but for now meth will do.
Offline
Feb 1, 2010, 12:32 PM
Quote:
Mike
Think that will be a bit out of range considering injectors are at least 400ish and a turbo is more like 450-500. If i didn't need a tune afterwords then I would be doing that.
About e-85, like i said, it will be an ultimate PITA to try and get two tunes, one for winter e-70 and one for real e-85. I guess I could just get an e-70 tune but that leaves a lot of power on the table. It's much easier to get a 93 octane and a meth tune and then hook up my fail safe to do a map switch.
I would prefer to use e-85 personally, but unless I am missing something it seems like I'll be paying double to get tuned at worst.
__________________
2003 TB Evo VIII
Tuned by Mellon
Offline
Feb 1, 2010, 01:12 PM
Personal Sales Rating: ( 13)
2004 Mitsubishi Lancer Evolution
Drives: 04 Evo RS
go e-85 and injector wise get FIC 2150's so you wont have to worry about running out of fuel.
__________________
(back under the knife for a cage)
Fastest FP Red Powered Stock Block EVO VIII and First Stock Block VIII/IX in the 9's
9.99 @ 140.75
Thanks To My Sponsors: Street Tuned Motorsports( www.stmtuned.com), Buschur Racing( www.buschurracing.com), FIC for some bad a$$ injectors(ordered from STM)
Haters gonna hate, then marry a hater Bi@&h and have hater kids
Offline
Feb 1, 2010, 01:16 PM
Quote:
You have to adjust maybe two tables to fix the cold start issues with E-85, that is if you have any at all. I got my car tuned on E-85 in the summer and haven't had a problem on E-70 this winter at all.
I did purchase the gauge just as some insurance, but it really isn't needed. Just something that is a nice reminder and failsafe. However you can do some neat things with the gauge. I have wired up a simple circuit to the output of the E% gauge and anything below 40% ethanol the car automatically switches to my Pump gas map (93 oct) and anything above uses the E-85 map. Painless, idiot proof, and I never have to mess with the tune on the car, ever. Granted, I play here and there with some fuel and timing maps every now and then, but that is just for education.
__________________
84mm FP Green 73HTA
E-85 Ethanol
For Sale List
Offline
Feb 1, 2010, 01:19 PM
Personal Sales Rating: ( 63)
Drives: Nissan 350z eclipse spyder eclipse hardtop 08 lancer 03 lancer evolution
lol to be honest you should just save it and build up like 2500 then get a real turbo and injectors and tune.
__________________
At JMS Racing
FP BLACK, ebay 02, Exedy Twin Carbon, Met.Black PPI Intake Manifold, Mike@AwdMotorsports built evo8head, AMS Fuel Line, PTE 1000cc, Innovate WB, JesseB Mona Lisa, Motor-RX 2.4, Aem OilPressure, Fp 4pr , Aem TruBoost, AMS 2.4 HG, GTspec Chrome StrutBar, Weapon R Tanks, Sharkbite Milspec 65mm T/B, Spoolin Up COP
Ordered
FortuneAuto SS boltkit
Video of the new built monster
http://s269.photobucket.com/albums/j...t=MOV09149.mp4
Offline
Feb 1, 2010, 01:22 PM
What kind of gauge are you using for this?
Quote:
Not much of a help. That would be nice, but I want more power now.
__________________
2003 TB Evo VIII
Tuned by Mellon
Offline
Feb 1, 2010, 02:11 PM
http://ttp-engineering.com/catalog/p...roducts_id=432
I had a logic board made at a local shop and it is what switches the map. I have it connected to the ECU via the standard analog map switch.
https://secure.buschurracing.com/cat...4be7c85d15e983
So the board gets the E% from the gauge, if the value is <40% ethanol it uses a digital switch to change the maps. All I had to do with the wiring harness for the part from BR is remove the analog switch and tie it in to the logic board.
I have a true Flex-Fuel vehicle. Heh. I need one of those stickers...
__________________
84mm FP Green 73HTA
E-85 Ethanol
For Sale List
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
