Jan 30, 2010, 10:26 AM
Personal Sales Rating: ( 0)
Drives: wrx
Trying to install oil pressure gauge.
Hello,
I'm trying to install a oil pressure gauge , but the oil pressure sending unit is located
above the transfer case , from the look of it , is gonna be a PITA to get access to
it, not only that it needs a special tool to remove the sender.
Is their a way to install the aftermarket sender unit without touching the oem oil sender
unit?.
thanks.
Offline
Jan 30, 2010, 10:28 AM
Personal Sales Rating: ( 5)
Drives: 2003 evo, 07 acura tl-s,o5 tahoe z71
dont know where its at on wrx but on an evo you attach it to the oil filter housing or use an adapter kit.
__________________
injen upper and lower i/c pipes, invidia dp, hallman mbc@28psi, map external dump o2, gt spec manifold, 80mm ported fp red, buschur 780 inj, hks carbon ti exhaust, ur cat delete, 255 walbro, ams licp, act hdss clutch, kelford 272 cams w/hks cam gears, ets 3.5 fmic, aps bov, spoolinup cop, map rev2 im, mil spec 65mm tb
DLL HP-434 TQ-413 93oct
Tuned by Mellon
Offline
Jan 30, 2010, 10:39 AM
Drives: wrx
Quote:
It is on a 2003 evo 8 , oil sender unit /sensor is located on the back of the block
above the transercase .
I'll take a picture soon.
Offline
Jan 30, 2010, 10:46 AM
Personal Sales Rating: ( 23)
Drives: 05 Evo, Discovery II, 07 cbr1000rr
Tap it off the oil filter housing. Use a AMS stainless line to isolate vibrations.
__________________
05 RR SSL- TTR Built 2.1, GRP Aluminum Rods, Wiseco HD Pistons, AMS oil pan, Full-Race twinscroll t4 HTA gt3586r, TTR fuel and ignition system, Magnus intake.
597whp/480 ft-lbs pump gas @ 28 psi
Offline
Jan 30, 2010, 10:52 AM
Drives: wrx
tap off the filter housing?,
which one?
the one with a hex head that require the allen key or the one that looks like a oil pressure sender?.
Offline
Jan 30, 2010, 10:53 AM
Drives: 03 TB GSR
^ +1 to the ams stainless line. You can tap in for the line on the filter housing you'll have to remove your filter to make it easier..
__________________
""Were not meant to enter the grave in a well preserved body but rather skidn in sideways totally worn out shoutn "holy **** what a ride".""
Offline
Personal Sales Rating: ( 37)
Drives: NO LONGER in between EVO's
lol... either does the trick. That is where the stock sender is though i believe, but a lot of the units call for you to tap the hex head place or there is another spot on the right side of the engine just below the intake cam
__________________
Spec-Ops Motorsports
Proudly supporting a company that proudly supports the military
Offline
Jan 30, 2010, 11:12 AM
Drives: wrx
Any one knows a link to the write ups?.
Offline
Jan 30, 2010, 11:17 AM
Personal Sales Rating: ( 3)
Drives: Evo IX MR Apex Silver
Offline
Jan 30, 2010, 11:26 AM
Personal Sales Rating: ( 13)
Drives: 06 GG MR, 08 Acura TL type-s, 03 CBR 954rr
You may want to look into this for the oil filter housing. I tried local places, and the threads just wouldn't work. Even though they said 1/8npt it still wouldn't thread in. This worked perfectly for me.
http://store.42draftdesigns.com/Lanc...ptor_p_53.html
Offline
Jan 30, 2010, 11:50 AM
Personal Sales Rating: ( 1)
Drives: 2003 Evo VIII
There is an allen keyed plug in the oil filter housing that can be removed and used as a tap in to the oil system.
I have a picture which, I'll upload later tonight.
__________________
03 Evo VIII Blue By You: E85 : 407hp @ 25psi or 451hp @ 31psi
Works Exhast, Brakes, Clutch, Flywheel, Short Shift, FP Green + O2, AMS FMIC + Pipes, AEM EMS,
RC 1200s, Walbro 255 FP, HKS 272s, Halman MBC, Shep Trans & Case...plus little stuff.
Next up: Suspension or widebody first?
Offline
Jan 30, 2010, 12:16 PM
Personal Sales Rating: ( 17)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO8, 05 R6
Def use a remote hose or your sensor will probably die pretty quickly.
Offline
Jan 30, 2010, 01:37 PM
Drives: wrx
Quote:
Originally Posted by Psquared
I was thinking about that , thanks for the link for the adapter.
although right now i'm having trouble removing the damn hex screw , I'm heading over
to fleetfarm to get a pipe to use as a breaker bar.
Offline
Jan 30, 2010, 02:16 PM
Drives: *9 MR SE* ivey tuned & 08 cbr 600rr.........sold: k7 gixxer 600, 03 350z stock, 04 evo8 cbe, 05 evo8 cbe, 06 sti cobb stg2 300whp
wow cool, where can i get the oil line and gauge from?
__________________
PERRIN TBE W/TEST >< BUSCHUR INTAKE CONE FILTER >< ETS INTERCOOLER KIT 3.5" IC? >< HALLMAN PRO MBC >< WALBRO 255 PUMP >< KELFORD 272's >< FP BEEHIVE SPRINGS >< INVIDIA 02 HOUSING >< HDSS W/ACT STREETLITE FLYWHEEL >< FLUIDAMPR CRANK PULLEY >< ARP HEAD STUDS >< STIFF SHIFTER BUSHINGS >< SS CLUTCH LINE >< DUNLOP TIRES >< AEM WIDEBAND >< AUTOMETER BOOST GAUGE >< KOYO RAD >< KEVLAR BELTS >< FP-RED PORTED W/80mm COVER >< FP 3" INTAKE PIPE >< BR FUEL RAIL >< PTE 880's >< IVEY TUNED 407whp/382wtq
Offline
Jan 30, 2010, 08:00 PM
Personal Sales Rating: ( 2)
Drives: 2006 Evo/94 mr2 w/ 98 beams swap/91 mr2 turbo
I just went to napa and bought a 3/8 bspt to 1/8 npt plug and put in place of the 8mm allen plug on the oil filter housing. Doesnt get much easier than that.
Offline
Tags
03, aftermarket, cbr1000rr, easy, evo, evolution, exhaust, gauge, guage, install, lancer, mitsubishi, oil, press, pressure  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
