Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Jan 6, 2010, 05:49 PM   #1
Personal Sales Rating: (3)
Garage is empty, add now
sktng22's Avatar
Drives: Evo 8, Cbr1000rr
Points: 5,619, Level: 48
Points: 5,619, Level: 48 Points: 5,619, Level: 48 Points: 5,619, Level: 48
Daily Activity: 2.4%
Daily Activity: 2.4% Daily Activity: 2.4% Daily Activity: 2.4%
+1mm oversized valves any good?
could someone tell me if there is an actual big gain from getting the head done and putting +1mm valves in it? how exactly does this give u a gain and what kind of gain is it? is it a faster turbo spool up or what?
Offline
Old Jan 6, 2010, 05:50 PM   #2
Points: 2,022, Level: 27
Points: 2,022, Level: 27 Points: 2,022, Level: 27 Points: 2,022, Level: 27
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Until your making big boy power, stock sized valves will work out better for you.
Offline
Old Jan 6, 2010, 05:54 PM   #3
Silver Sponsor
Personal Sales Rating: (153)
Aby@MIL.SPEC's Avatar
Drives: Dirty EVO VIII
Points: 16,762, Level: 82
Points: 16,762, Level: 82 Points: 16,762, Level: 82 Points: 16,762, Level: 82
Daily Activity: 3.1%
Daily Activity: 3.1% Daily Activity: 3.1% Daily Activity: 3.1%
imo, the exhaust valves are too big on our engines.....
so going bigger on the intake will be good, keep the oem ex valves.
fwiw, the evo x has larger intake valves & smaller exhaust valves than the evo 8/9.
__________________
Throttle Body Rebuilds by MIL.SPEC! OEM or 65mm
http://forums.evolutionm.net/vendor-...-services.html
FIX your boost leak NOW with MIL.SPEC HIGH PRESSURE TB Shaft Seals!
http://forums.evolutionm.net/showthread.php?t=364108]
MAPERFORMANCE PLYMOUTH, MN
CBRD YORK, PA
ENGLISH RACING CAMAS, WA
Offline
Old Jan 6, 2010, 05:59 PM   #4
Personal Sales Rating: (1)
Planglie's Avatar
Drives: 2006 TB IX SE, 1970 Camaro drag car, 2001 Ford Super Duty tow vehicle
Points: 4,830, Level: 44
Points: 4,830, Level: 44 Points: 4,830, Level: 44 Points: 4,830, Level: 44
Daily Activity: 0%
Based on the port sizes, choke area, and valve area, my porting friend says stay w/the stock size valves. IIRC the #'s show the stock sizes good for 8200 rpm on a 2.0 and 7800 on a 2.3???? Only need larger if you are turning big RPM. More of a sales gimmick IMHO.
Paul
Offline
Old Jan 6, 2010, 06:47 PM   #5
Personal Sales Rating: (6)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
Points: 15,974, Level: 81
Points: 15,974, Level: 81 Points: 15,974, Level: 81 Points: 15,974, Level: 81
Quote:
Bigger valves alone don't equate to bigger flow. In fact, larger diameter valves can reduce flow in an otherwise stock head by choking a small port.
A ported head that is demonstrated with a flowbench to benefit from oversized valve is a different situation.
__________________
Ted B. Spec JAM LR 2.0L - Headway Perf CNC Head - DI Int Man - 75mm Hypertune TB - HTA3582 TS 1.06 A/R T4 - Crane 272-280 - MPFab TS T4 Manifold, TBE, UICP, LICP - MPFab FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1450cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Super Twin P-Trim Clutch
93 oct - 595whp
Offline
Old Jan 6, 2010, 08:16 PM   #6
sktng22's Avatar
Well I'm going with an 850r setup already have everything for it. I'm just geting the head done very soon and am going to be putting down about 700awhp at iveys. So with that kind of power wat do u think about the +1mm valves??
Offline
Old Jan 6, 2010, 08:26 PM   #7
It doesn't matter if it's 400whp or 800whp. It's not about power, it's about the port.
Factory ports? Stock valve sizes.
__________________
93 oct - 595whp
Offline
Old Jan 6, 2010, 08:29 PM   #8
forc3 f3d's Avatar
Drives: IX
Points: 2,627, Level: 31
Points: 2,627, Level: 31 Points: 2,627, Level: 31 Points: 2,627, Level: 31
Daily Activity: 0.9%
Daily Activity: 0.9% Daily Activity: 0.9% Daily Activity: 0.9%
i would say that if you need to be asking this, than you really have no business getting into the 700hp club aka big boy club...
Online
Old Jan 6, 2010, 09:50 PM   #9
Personal Sales Rating: (7)
Drives: 2006 Mitsubishi EVO IX
Points: 5,886, Level: 49
Points: 5,886, Level: 49 Points: 5,886, Level: 49 Points: 5,886, Level: 49
Daily Activity: 3.2%
Daily Activity: 3.2% Daily Activity: 3.2% Daily Activity: 3.2%
It's actually a good question.
Yes, in some applications where more airflow is required than the stock valve size (and ports) can provide, larger valves are necessary. This is only after the ports have been developed to their potential, then a larger valve is the next step towards more flow.
Velocity is another important part of cylinder head performance that can often be sacrificed by unnecessarily large ports or valves.
Check out the issue of Import Tuner hitting the stands any day now. It has part 2 of my 4G64 MIVEC build and details the cylinder head. I explain why the stock valves were retained on my 2.4L 4G64. The current issue has the shortblock build.
Offline
Old Jan 6, 2010, 10:44 PM   #10
RSMike's Avatar
Drives: Evo Powered Mirage
Points: 6,396, Level: 52
Points: 6,396, Level: 52 Points: 6,396, Level: 52 Points: 6,396, Level: 52
Daily Activity: 5.1%
Daily Activity: 5.1% Daily Activity: 5.1% Daily Activity: 5.1%
i dont get import tuner over here in NZ.
could you please let me know what you're explanation is?
i'm going 2.3 with some head porting and i'm wanting to know if i should go +1mm oversize too.
Cheers, Mike
__________________
2.3 + Mivec Powered Mitsi Mirage
11.22 @ 121mph, 1.62 60ft
Stock turbo @ 24psi = 380whp, max boost @ 2800rpm.
www.prosportauto.co.nz
NZ Agent for ENDLESS Brakes
Offline
Old Jan 6, 2010, 11:37 PM   #11
sktng22's Avatar
well the reason I'm asking this is because I see all these big name brand heads coming with +1mm valves. I wana get the head ported regardless. I was just wondering why there all going +1mm on there heads instead of just porting the stock size??
Offline
Old Jan 7, 2010, 03:47 AM   #12
Personal Sales Rating: (0)
crcain's Avatar
Drives: vi rs
Points: 15,582, Level: 80
Points: 15,582, Level: 80 Points: 15,582, Level: 80 Points: 15,582, Level: 80
Daily Activity: 0%
I run stock size valves in my ported head for my 4G64.... my tuner in England doesn't think oversize valves make sense under 700 hp, so I went with that. Been running it for 3 years now. I have no idea whether bigger valves would have made the motor better. Doubt it.
There has not been a conclusive test done so it's all guess work.
__________________
10.7 granny shifting - http://www.youtube.com/watch?v=sOEL7uGJIuc
Autronic, 2.4l, MAD spec piper cams, AMS kit, FP HTA 35R, RC 3" exhaust, AIM Dash, Kansai inlet, q45 TB, Buschur COP
Tuned by Mark Shead
Offline
Old Jan 7, 2010, 07:19 AM   #13
Personal Sales Rating: (109)
Points: 15,391, Level: 80
Points: 15,391, Level: 80 Points: 15,391, Level: 80 Points: 15,391, Level: 80
Daily Activity: 4.3%
Daily Activity: 4.3% Daily Activity: 4.3% Daily Activity: 4.3%
I agree with this. larger intakes can make it easier for air to get in if the chamber is deshrouded correctly. making the exhaust bigger is not a good idea. the piston pushes air directly at head trying to push it out. making the head bigger hinders exiting flow.
stock 4g63 sixe is 34mm/30.5mm
I believe evo X is 35mm/29mm
__________________
early evo nut rockin
evo1 and evo 4
"torque=fun"
the faster you can make torque the more fun your car will be. lag is a dull boy.
"if the solution is simple, God is answering"
Offline
Old Jan 7, 2010, 08:13 AM   #14
Silver Sponsor
Personal Sales Rating: (4)
APM Racing's Avatar
Drives: 06 Evo9 MR
Points: 5,672, Level: 48
Points: 5,672, Level: 48 Points: 5,672, Level: 48 Points: 5,672, Level: 48
Daily Activity: 3.7%
Daily Activity: 3.7% Daily Activity: 3.7% Daily Activity: 3.7%
http://www.facebook.com/pages/APM-Racing/133390940162
Send a message via AIM to APM Racing
On a set up like your i would suggest a 1mm larger intake valve and either a stock or +.5mm exhaust valve. After some testing on our CNC head it was determined the 1mm oversized exhaust valve was a little on the large side and really did not help out flow much on the exhaust side.
__________________
..::APM RACING::..
867 N. Addison Ave. Elmhurst, IL 60126.
WE ARE DEALERS FOR AMSOIL-QUARTERMASTER-VIPEC-COMPTURBO-KELFORD&MORE
visit us at apmtuned.com
1 (630) 833-8911.
Like us here...FACEBOOK
Follow us here...Twitter
Offline
Old Jan 25, 2010, 12:36 PM   #15
Personal Sales Rating: (31)
rodent's Avatar
Drives: 2005 WW Evo VIII
Points: 7,651, Level: 58
Points: 7,651, Level: 58 Points: 7,651, Level: 58 Points: 7,651, Level: 58
Daily Activity: 0%
Great info! 2.0 here with 640whp but I want to get the head ported and enlarge the valves. Looks like I'll just do the intake side unless someone here has proven data to stick with stock size. I'd like to see 750 at the wheels with an HTA3586 turbo.
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
1mm, 20, benifit, bigger, evo, head, long, mm, motor, na, oversize, oversized, rod, stock, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
