Evo Engine / Turbo / DrivetrainEverything from engine management to the best clutch and flywheel.
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Hi guys, just wondering if anyone runs a turbo blanket on their evo and does it affect under bonnet temps at all?
We have similar weather to socal here, 40 degrees celsius in summer etc and the car gets pretty hot.. currently have a full race manifold and although it's wrapped, it does get the temps up a bit, especially when stuck in traffic etc..
Would adding a turbo blanket help to keep heat away from the radiator and the rest of the engine bay or is it more of a gimmick than a real use?
Sorry if it's been discussed before but did search and couldn't find anything.. cheers
I have also been looking at those turbo blankets. That info in the Buschur thread was useful. Anyone else have any experience using one of these in more of a DD application?
The DEI turbo blanket works VERY well.
I do ceramic coating for a living and have seen first hand that the blanket will stay cool to the touch even after a WOT pull. They work very well at holding heat inside the turbine housing where it belongs.......
The blanket I'm referring to is what Buschur sells.
I have had parts coated before. Ceramic is great for looks and corrosion resistance but its nowhere near as good as a turbo blanket or wrap. How about a $1,000 bet? I hold my hand on my turbo blanket after a 1/4 mile run and you hold your hand over a ceramic coated turbine after a 1/4 mile run and whoever can keep their hand on The longest gets the money.
Drives: 2006 EVO IX, Built RB26DET with no home, 1991 Acura NSX
Points: 6,530, Level: 52
Daily Activity: 8.9%
Quote:
I am with you as I think the coating is over rated for the money and cannot compete with a good solid insulated cover. With that said, if I had the money I would do both as the coating improves the bling factor. The pic below is of my buddies GT42R powered 280Z. Even with the coating you could not hold your hand over the turbine housing after hard runs, but with the ATP inconel cover it was not an issue. The difference in the ability of a turbo blanket to reduce radiant heat vs. coatings is night and day. I also used the inconel covers from ATP on the exhaust manifolds and turbine housing for a twinturbo ZR1 project I did many years back. It was amazing the ability of those covers to reduce under hood temps. I will try to dig up some pics and post.
__________________
1991 Acura NSX
RB26ET with no home
2006 EVO IX
240Z Twin Turbo, i have seen a similar types of material to what you yused on your intake used to cover exhasut manifolds of WRC cars. They also use Inconel coated Ti manifolds i think! lol
How thick are the inconel turbo blankets?? they look really thin. just thinking if you could run coated housings with one of the inconel blankets and then a normal turbo blanket as well. That surley would be the untimate way to keep the heat in! lol
Quote:
Chris.
The construction consists of a high temp fabric based material sandwiched between two layers of waffled inconel. I cannot remember the exact thickness, but I would guess ~3/16".
__________________
1991 Acura NSX
RB26ET with no home
2006 EVO IX
I know inconel is used in all types of industries where high temperatures are an issue. It is usually the best metal for these applications but is very expensive. I cant say from experience but I would imagine a Inconel blanket with a fabric insulator is quite effective.
