Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 6, 2009, 07:46 PM   #1
Personal Sales Rating: (3)
Drives: VW R32 WW 06 Evo IX MR
Idle Surge
Ok just noticed this. I have an Evo IX MR with the Works T340 kit. So it has 269cams. Car idles like stock. When I am up to temp and stopped at a light the idle will rise to about 1100 rpms then will dip back down to 800 then up to 950. sometimes the rpms will rise to 1300.
I don't feel like I have a boost leak car runs normal and strong. The works tune is very conservative so IDK any thoughts on where I can look?
Offline
Old Nov 6, 2009, 09:12 PM   #2
Bump Anyone.
Offline
Old Nov 6, 2009, 09:17 PM   #3
Personal Sales Rating: (9)
Cal City Evo's Avatar
Drives: 03 Evo 8
Mine did this for a while. I found that reducing the gap on the plugs helped to make it far less than it was. Believe I set them at 25 or some such maybe a bit less. If you plugs are old it helps to just replace them, check the gap though.
I think it's the cams that cause it because mine didn't do it until I installed mine. I have the mild 264/272 HKS FWIW.
Offline
Old Nov 7, 2009, 02:43 PM   #4
I am going to try and change the plugs tomorrow and see if it helps a bit. Probably due for a change anyway.
Offline
Old Nov 11, 2009, 09:02 PM   #5
kpr
Personal Sales Rating: (0)
Drives: 03 evo
How are you tuning the car, You can adjust the Accel Enrichment and this will help. Also with those cams base idle will need to be increase or the car kinda searches for the right idle speed.
Offline
Tags
04, idle, lancer, surge
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
