Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 6, 2009, 06:55 AM   #1
Personal Sales Rating: (0)
marylandevo8's Avatar
Drives: 05 Pearl White Evo VIII
Send a message via AIM to marylandevo8
Exclamation RPM's acting weird at idle....?
Hey guys,
So I was driving my EVO to school yesterday and noticed at a red light, with the car in 1st, I was looking at my RPM's. I noticed it mainly stays around 800-1000. Sometimes it will spike to 1,300 or so but then it would come back to normal after a couple seconds.
This was not the case yesterday. While at the red light, the RPM's were jumping from 800 to 500 back to 800 then down to 250 then 500 then 800 and so on, to the point the car was about to shut off even while the clutch was pressed in because I was in 1st gear. I guess it's also important to note when the car was sitting at idle, and the RPM's were jumping from 250-500-800, I noticed the car was running lean...
My question to you guys is....Why is this happening? I have an 05' EVO III with the following mods:
Megan Racing TBE
Injen Upper/Lower IC Piping
Injen Intake
TurboSmart BOV -- (I bought the car with this already on it)
My guess it could have something to do with my BOV...Please note, the car does NOT have a tune yet....
Im sort of strapped for funds right now...I'd like to pay off my $1,300 credit card before spending $350 on a tune but after judging how my car is running....I may want to get the tune now....
Have you guys had this similar problem? Let me know what you think, regardless.
Thanks,
Randy
Offline
Old Nov 6, 2009, 06:56 AM   #2
Sorry guys....please disregard EVO III....I meant EVO VIII. lol.
Offline
Old Nov 6, 2009, 07:00 AM   #3
Personal Sales Rating: (27)
2005 Mitsubishi Lancer Evolution
Fast_Freddie's Avatar
Drives: '05 Tarmac Black SSL VIII
You may wanna pop the BOV apart and clean/lubricate it... sounds like it may be sticking open...
__________________
FP Red*Greddy ProfecB Spec II*HKS TT*Nesei Short Route IC Piping*Synapse BOV*COMP 272s*Injen Intercooler*AFE Power Dry Filter*R/TErnie Intake*R/TErnie FULL 3" O2 housing with V-band*R/TErnie Modified DCsports 3" Down/Test/Flexpipe with V-Band*Greddy Ti-C Exhaust*255lph*Tein S-Techs*18" Volk LE-28s*Progress 25mm Rear Sway*Project Mu pads*JDM Tails*Cusco Heat Shield*Mishimoto Radiator hoses/Cap*ARC shift knob*Injector Dynamics 1000cc...
Offline
Old Nov 6, 2009, 07:08 AM   #4
EvoM Moderator
Personal Sales Rating: (12)
MR Turco's Avatar
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
i would check the BOV also. You may also want to do a boost leak test. Now that the temp is dropping it can cause boost leaks to get worse. You may also need new TB seals which i have seen cause this issue as well.
__________________
-Mike
The Rules - love them
TephraMOD V7 - now serving 25x30 fuel and timing maps and Gear Dependent Boost Control
Quote:
Originally Posted by beavis820 View Post
turco is a damn fine mechanic without me
Offline
Old Nov 6, 2009, 08:29 AM   #5
bostonhatcher's Avatar
Drives: 2000 Mitsubishi Eclipse GSX
Does it do this in neutral or just in gear? If it's just when it's in gear your clutch might not be fully disengaged causing the motor to bog down.
Aftermarket intakes cause ****ty idle. The maf needs to be rescaled. A tune would help some but the stock maf's don't really like aftermarket intakes. This is most likely the culprit.
Could be a boost leak. Any air that gets sucked in after the maf will cause the motor to run lean.
Offline
Old Nov 7, 2009, 10:51 AM   #6
09Ralli's Avatar
Drives: 2006 Evolution 9 Special Edition
how do u like that megan tbe? im about to buy one, is it smooth and not too loud? noticable gain?
Offline
Old Nov 7, 2009, 11:01 AM   #7
Personal Sales Rating: (15)
2003 Mitsubishi Lancer Evolution
red03evo's Avatar
Drives: 2003 evolution, 2009 335i
Send a message via AIM to red03evo Send a message via Yahoo to red03evo
Personally when I had the turbosmart dual port, I had idle issues. Once I swapped to my 1g diverter valve, it was a lot better.
Good luck.
__________________
Built and Tuned by Buschur Racing
Offline
Tags
2000, dropping, evo, idle, idles, jump, jumping, light, lower, mitsubishi, problem, red, rpm, rpms, weird
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
