Nov 5, 2009, 07:21 AM
Personal Sales Rating: ( 2)
Drives: 06 IX SE Apex Silver
MBC users thoughts?
After talking to a fellow friend last night about how much he loves his MBC I am rethinking the whole EBC thing. Anyone care to chime in on why they love their MBC and overall feelings.
__________________
Spoolinup COP
www.spoolinup.com
Offline
Nov 5, 2009, 07:22 AM
Personal Sales Rating: ( 12)
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
do you already own an EBC?
Online
Nov 5, 2009, 07:23 AM
Personal Sales Rating: ( 15)
Drives: Wicked White Evo IX GSR
Easier, cheaper, smoother boost curve
__________________
*formerly S2kracka*
Offline
Nov 5, 2009, 07:29 AM
Personal Sales Rating: ( 4)
Drives: 2006 EVO IX, 95 Talon TSi AWD
wait a sec, if you already have an ebc you would be a moron to switch to a mbc. mbc are great for the price and they are simple to install. they work very well otherwise no one on here would ever of had one. an ebc is simply the best. it holds your boost 10x better than any mbc ever could. but if your looking to buy a mbc or ebc then it is all up to you. what kind of power are you looking to make? what are your future goals? do you have the money for an ebc?
all those questions you have to answer yourself. i personally am still using a mbc. (i dont plan on switching to a ebc until i switch to a AEM EMS) in facts its the SAME exact mbc i have had and been pushing over 20 psi for over 6 years on my DD's. like i said mbc work very well, but they just dont have some of the advantages ebc have.
good luck with your choice
Offline
Nov 5, 2009, 07:34 AM
have a 3 port and a mbc neither are on the car but one will be very soon. seems like a lot of work to get the 3 port dialed in and Ive heard its not that consistant.
__________________
Spoolinup COP
www.spoolinup.com
Offline
Nov 5, 2009, 07:36 AM
Quote:
I beg to differ. I had a MBC on my Evo, switched to a GM BCS, then eventually went back to a MBC and couldn't be happier.
__________________
*formerly S2kracka*
Offline
Nov 5, 2009, 07:38 AM
EBC should yield slightly faster spool and better top end.
Online
Nov 5, 2009, 07:41 AM
Quote:
I noticed the exact opposite on my car. Response is much improved with the MBC back on again and the car also spools faster (the new Tephra v7 should improve upon that a bit though). On my car, remember its a IX, to get the most power with pump gas I was actually having to taper the boost down basically mimicking the taper a MBC has since the car preferred timing over boost in the upper RPM's.
__________________
*formerly S2kracka*
Offline
Nov 5, 2009, 07:49 AM
I have always seen 1-200 rpm quicker spool going from MBC to gm 3-port. I think GST has a bunch of data posted somewhere. Logically it makes sense, you are keeping the WG completely clamped instead of progressively opening like on a MBC.
Online
Nov 5, 2009, 07:50 AM
Personal Sales Rating: ( 1)
Drives: TB IX MR SE, 07 R6
Quote:
You sure it isnt just the way you have your boost control set up on your rom? Also I kinda hate how the colder it gets the more boost it will make on a MBC. I do know why, I just wonder if moving the MBC closer to the block will make more consistent boost versus varying outside temps. hmm...
__________________
E85
Quote:
Found a driedout gerbil carcass at the bottom of the box—AND it had been shaved.
Online
Nov 5, 2009, 08:01 AM
My GM BCS was properly setup and I tried it both load-based and with a JDM 3.3-bar MAP sensor.
GST's data is what convinced me to try it in the first place, I just saw none of the benefits but all of the drawbacks on my car. I gave it a good long chance, had it on my car for about a year, and did everything imaginable to get it tuned in properly but was just never happy with it.
__________________
*formerly S2kracka*
Offline
Nov 5, 2009, 08:10 AM
i totally understand your frustration, esp come winter time. I am very much looking forward to getting on v7 mainly for weather correction. It is tough, as someone who is constantly tuning their car i don't really mind but typically recommend a MBC for those who don't want the hassle.
Online
Nov 5, 2009, 10:35 AM
So how difficult is it to do ecu controlled boost? I've been tuning my car by myself and after a few weeks of messing around, its gotten pretty damn easy.
__________________
E85
Online
Nov 5, 2009, 10:45 AM
thats the first time i have ever heard of that
Offline
Nov 5, 2009, 11:10 AM
Drives: IX SE
Quote:
Much of the cold weather spiking is due to the spring inside the MBC changing its response as the metal gets colder. My MBC is mounted to the radiator. As the rad comes up to temp, so does the MBC. As such, I see little variance in boost levels - ~.5PSI from 30F-90F according to my logs. FWIW, I can't take credit for the idea. Em, from STM, installed it in that location for this very reason and he was right.
__________________
VDR5.6 EvoM Comparator - 347/321
STM Mustang Dyno - 320/302
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
