Nov 5, 2009, 11:12 AM
Personal Sales Rating: ( 15)
Drives: Wicked White Evo IX GSR
Quote:
Originally Posted by Ginglingston11
thats the first time i have ever heard of that
Search around, its been discussed many times over in the ECUFlash section of the board.
__________________
*formerly S2kracka*
Offline
Nov 5, 2009, 11:21 AM
Personal Sales Rating: ( 1)
Drives: 03 lancer evolution 8
I love my ebc. I can quickly adjust boost from sunday drive to kill. I also have a fail safe for my meth kit tied in that drops boost to wastegate on low/no flow. I find that it holds boost very well.
__________________
3" tbe, GSC S1's, Aquamist hfs-1 100% meth, Greddy cam gears, Injen IC hard pipes & intake, ACT hdss clutch w/ Prolight flywheel, Walbro 255 lph, Greddy Profec B Spec 2 ebc, Fp Red 80mm, Syncronic BPV, ETS 3.5" IC
Offline
Nov 5, 2009, 11:28 AM
Personal Sales Rating: ( 22)
Drives: 06' WW MR, 99' Eclipse GS w/turbo
Mbc is a cheap effective way to go. I'm switching over to GM 3 port ecu controlled. Remember you get what you pay for. I'd rather have something constantly monitoring and controlling my boost for me based on the parameters I setup rather than relying on some spring to do it's job.
__________________
Evolution IX MR Wicked White
old #'s 322whp/310wtq
new #'s coming soon...[/center]
1999 Eclipse GS Anniversary Monarch Green Pearl
Built by me ;)
269.4 whp @10psi (has more boost and powered by PTE 50trim BB no numbers though :(
06' GSXR 1000 K6
Yosh jap shorty, BMC, PCIII
"Faster than your mom on a saturday night!"
Offline
Nov 5, 2009, 11:35 AM
Personal Sales Rating: ( 3)
Drives: 2008 Evo X GSR
Never owned an EBC, but I absolutely love my AMS MBC.
__________________
MASE'D EvoX GSR
12.83 @ 106.70
Offline
Nov 5, 2009, 11:37 AM
Drives: TB IX MR SE, 07 R6
Quote:
Originally Posted by FJF
Much of the cold weather spiking is due to the spring inside the MBC changing its response as the metal gets colder. My MBC is mounted to the radiator. As the rad comes up to temp, so does the MBC. As such, I see little variance in boost levels - ~.5PSI from 30F-90F according to my logs. FWIW, I can't take credit for the idea. Em, from STM, installed it in that location for this very reason and he was right.
Yeah mine is mounted right on top of the right side of my radiator. I guess I should just stay out of boost for a little longer till my engine bay gets even hotter.
__________________
E85
Quote:
Found a driedout gerbil carcass at the bottom of the box—AND it had been shaved.
Offline
Nov 5, 2009, 11:39 AM
Personal Sales Rating: ( 12)
Drives: IX SE
Quote:
I stay out of boost until the oil is up to temp.
__________________
VDR5.6 EvoM Comparator - 347/321
STM Mustang Dyno - 320/302
Offline
Nov 5, 2009, 12:41 PM
Drives: 2006 EVO IXMR
If you have a 3port call Bryan at GST and say "give me the smarts"  Ecu controlled Boost is great with v7. It has a larger map and gear based boost control
Mikey
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Nov 5, 2009, 01:25 PM
Yea I'll just wait more now because its getting colder. Heck I don't even move the car for at least a minute and then after that I baby it big time.
__________________
E85
Offline
Nov 5, 2009, 01:29 PM
Drives: IX GG MR
Easy peasy lemon squeezy. Oh and cheap too.
Offline
Nov 5, 2009, 06:59 PM
Personal Sales Rating: ( 0)
Drives: 1997 Nissan Maxima
ive never had either. but i would say a mbc is sufficient.
Offline
Nov 6, 2009, 10:19 AM
Personal Sales Rating: ( 2)
Drives: EB IX
I have MBC mounted to the radiator. Just don't go ape on it right at startup... hell you shouldn't do that to any car!!
It's working great for me.
Why the hate on the little spring!? Even solenoid valves have a spring keeping it shut! You just have a bunch of copper and some spiffy electrons to pull it open instead of pressure hehe
__________________
'06 EB IX - Perrin/Hallman/ECS Tuned: 300WHP
Thanks to the USPS for purchasing my mods by hitting me with your truck!
Offline
Nov 6, 2009, 10:23 AM
Drives: 2006 Evolution
Step 1. Buy an MBC
Step 2. If don't have an EBC continue to step 5.
Step 3. Remove EBC and install MBC.
Step 4. Smash EBC with a hammer.
Step 5. Install MBC.
Step 6. Enjoy you're car running correctly under load and WOT.
Offline
Nov 6, 2009, 10:40 AM
Drives: GG 9 MR, hennarot e30 M3, both sold. WW IX RS.
__________________
new - bbk, fp4r, etc.
beatrush undertray + vishnu rear diffuser.
suggested reading:
http://www.m3post.com/goodiesforyou/evo.pdf
the moral of the story: the sum of slower + older + harsher + less perfect = more fun. and more fun is why i'm back in an evo.
tuning c/o bear
Offline
Nov 6, 2009, 11:13 AM
Personal Sales Rating: ( 5)
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Drives: 05 Apex Silver Version 8, 2001 GSX-R 1000
Interesting debate I must say. - MBC is great for those on a budget and if you wish to raise boost. Not really great when the weather changes like in the Northeast.
- EBC like blitz, HKS, and Greddy use a 2 port bleed solenoid which is basically similar to MBC. You pay more for them but you have more control over your boost and you generally don't go over your desired boost level.
- The OEM 2 port Bleed Solenoid and Boost pill works well but not only do you have to tune the ECU but you also have to play with restrictor pills.
- 3 port Solenoid my new favorite. Having a good tuner and the ECU control boost is the way to go. 3 port solenoids work on an interrupt mode which basically block boost from the wastegate solenoid until the ECU basically tells it to cut boost. You will get a much quicker spool up and with a mean setup you can hold boost all the way to redline with no taper if you choose. You have 2 ways of doing this via Load or Direct boost control. Load would be they way the car was tuned to boost when the car was stock using the MAF readings to reach desired boost load. Direct Boost control would be using a JDM or EVO X map sensor or larger aftermarket one which basically you requesting a desired boost level and you got it. They is some tuning involved in it but if you or your tuner know what your doing then you will have a monster.
I will be selling my Blitz SBC-ID EBC and installing my GrimmSpeed EBCS and Omni 4 bar Map sensor in the new year with Tephra V7 patch
__________________
Stock Block and Head
FP Red 80mm
Kelford 272's
Beehive Springs
Precision 1k injectors
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
PPI Extreme Ported Hotside, Exhaust Mani, Intake Mani, and TB
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
322.7 whp 320tq 21.5 psi on 93 oct
355.8 whp 430tq 25 psi on c16
Offline
Nov 7, 2009, 12:04 PM
Personal Sales Rating: ( 4)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
Quote:
Originally Posted by Kracka
I noticed the exact opposite on my car.
That can be the case if one has his EBC programmed such that it is active prematurely. The idea in programming an EBC is to keep the solenoid closed until just before the point where boost needs to be controlled. If it is clicking along in unboosted regions, this will delay spool to some degree, especially where an unecessarily weak WG spring is used.
The limitation in the solenoid duty vs. rpm table is the onset of boost vs. rpm is different in different gears. This is where either load limiting or pressure limiting boost control strategies prove their worth.
__________________
Ted B. Spec JAM Long Rod 2.0L - Headway Performance CNC Head & Valvetrain - DI Intake Manifold - 75mm Hypertune TB - HTA3582R Twin Scroll T4 - Machined 12mm lift Billet Cams - MPFab twinscroll T4 Manifold, TBE, UICP, LICP - MPFab Race FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Graphite Dual Disc
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
