Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 4, 2009, 09:06 PM   #1
Personal Sales Rating: (2)
bbyevo8u's Avatar
Drives: *9 MR SE* ivey tuned.........sold: k7 gixxer 600, 03 350z stock, 04 evo8 cbe, 05 evo8 cbe, 06 sti cobb stg2 300whp
3" vs 3.5" IC and fp-red
i think i'm going with the fp-red 80mm cover and injectors, i have a 3" ets core should i really sell it for a 3.5" or will i be ok?
how much will it hurt me if i use a 3" ic core?
__________________
PERRIN TBE W/TEST >< BUSCHUR CONE FILTER >< ETS INTERCOOLER KIT >< HALLMAN PRO MBC >< WALBRO 255 PUMP >< KELFORD 272's >< BEEHIVE SPRINGS >< INVIDIA EXHAUST MANIFOLD >< INVIDIA 02 HOUSING >< HDSS W/ACT STREETLITE FLYWHEEL >< FLUIDAMPR CRANK PULLEY >< ARP HEAD STUDS >< STIFF SHIFTER BUSHINGS >< SS CLUTCH LINE >< DUNLOP TIRES >< AEM WIDEBAND >< AUTOMETER BOOST GAUGE >< KOYO RAD >< KEVLAR BELTS >< ///IVEY TUNED - 350whp 352whq///
Offline
Old Nov 4, 2009, 09:13 PM   #2
Personal Sales Rating: (11)
freshsrt-4's Avatar
Drives: 05 ssl evo 8
if your goin to go bigger, might as well go 4" instead of 3.5". you'll see a nice improvement with higher boost levels by goin bigger. Meaning your intake temps will be lower.
__________________
11.63@119.14 mph------>stock 9 turbo w/gsc 272's, self tuned on 114 oct.
http://www.paradigmperformance.net
Offline
Old Nov 4, 2009, 09:19 PM   #3
bbyevo8u's Avatar
^^ ok thanks, but i want to know if i should sell my 3" ets core or will i be fine with it?
__________________
Offline
Old Nov 5, 2009, 02:07 AM   #4
Personal Sales Rating: (0)
Drives: 450bph saab 9-5
Quote:
got any data to back this one up?
Offline
Old Nov 5, 2009, 06:15 AM   #5
Personal Sales Rating: (1)
92gsxbaltimore's Avatar
All other things being equal: the thicker your core is, the less prone it is to heat soak. So I would say run what you already have, and if you notice irregular logs back to back, then upgrade. How much boost are you planning on running, and do you plan on keeping it on the street?
Offline
Old Nov 5, 2009, 06:30 AM   #6
EvoM Moderator
Personal Sales Rating: (12)
MR Turco's Avatar
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
It really depends on the core. I would think ETS can best recommend a size to suit your needs.
__________________
-Mike
The Rules - love them
TephraMOD V7 - now serving 25x30 fuel and timing maps and Gear Dependent Boost Control
Quote:
Originally Posted by beavis820 View Post
turco is a damn fine mechanic without me
Offline
Old Nov 5, 2009, 09:27 AM   #7
Plat Vendor
Personal Sales Rating: (40)
ETS Michael's Avatar
Drives: Operation Damaged Goods - 03 Yellow Evo
Send a message via AIM to ETS Michael
You can run the 3.0" version, but to get all the power on the Red 450+ I would recommend going with the 3.5" version which will max out reds capabilities.
Thanks!
Michael
__________________
Michael
Site: Extreme Turbo Systems
Pho: 360-263-3748
AIM: ETS MichaelR
Evo X Stock Block/Stock Head - World Record - 681whp (ETS 3586 Turbo Kit)
Evo X ETS Built Motor - 2.0L World Record - 718whp (ETS 3586 Turbo Kit)
1117whp Evolution 8 (ETS 42R Turbo Kit)
ETS 6.0" Intercooler - ETS 45R Turbo Kit - ETS Exhaust - English Racing Motor - English Racing Tune
ETS Holiday Specials On Our Website!! 20% Off ETS Products!!
Offline
Old Nov 5, 2009, 11:53 AM   #8
sparky's Avatar
Drives: 2004 RS
Michael: What is the thickest Garrett core available that you can use in an Evo FMIC application? I think that Buschur's 4.5" IC uses a Garrett core. But, can you source a 5", or 6", Garrett core? Finally, is your 6" thick core a Garrett unit?
__________________
Vishnu XEDE & camgears-Greddy 720's-ported Green-HKS 280/272-Forge WGA-AMS LICP-DC DP-Magnaflow Ti-Ralliart TS-Tomei Thermokiller - SSAC O2 - BR8ES-Nissei IC--SS clutch line-Endless(f) /Hawk(r) - WALBRO 255-ITG filter-Motul-KOYO radiator-SAMCO intake hose-UEGO-Autometer-Kartboys-Authority SS-MR DV.
DLL: 389WHP/25PSI on 93( non-corrected@3300' altitude). (No dynos in the jungle! Fortunately, there are carnivorous toads that feed on bats).
Offline
Old Nov 5, 2009, 12:05 PM   #9
A 6" core is way overkill and will give you a lot of pressure drop.
Offline
Old Nov 5, 2009, 12:28 PM   #10
sparky's Avatar
Drives: 2004 RS
I'll just turnup the boost
__________________
Offline
Old Nov 5, 2009, 12:36 PM   #11
BLKCarbonEVO's Avatar
Drives: 2006 EVO IXMR
Send a message via MSN to BLKCarbonEVO
Quote:
Garrett makes all sorts of cores. All Michael has to do is order one if he doesn't have one and I'm sure he would make you custom end tanks for it.
Quote:
Sparky was not reccomending the OP to get a 6" core first off. OP don't get an ETS 4" core! Call Michael at ETS and grab yourself a ETS Garrett 3.8" core! These things are dope! I have one and I can't heat soak it It will be fine to 600+hp easy with minimal pressure drop. I like to have a large intercooler so in the spring when I build my motor I may up to a 4.5" Garrett. The Garrett cores cool so much better then normal cores. David B uses the Garrett cores in his race FMICs too and so does CBRD but ETS is cheaper by $100+. Do some research. I have seen people pick up over 20+ on switch from a 3.5" normal "Chinese" cores to the Garrett 3.8".
Mikey
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Old Nov 5, 2009, 02:54 PM   #12
Plat Vendor
The largest Garrett I would recommend is 3.8", I have three on the shelf. I also have 10 of the ETS Evolution X 4.0" core on the shelfs as well. I recommend our core for a few reasons, but we can discuss that in PM or on the phone.
Thanks,
Michael
__________________
Michael
Pho: 360-263-3748
AIM: ETS MichaelR
Offline
Old Nov 6, 2009, 04:31 AM   #13
I'd say your 3" IC is good enough for the red, if the core face size is large enough.
here is some actual measurement data on 3" 530x300mm core size IC on 2.3l application with around 500hp
http://www.stcf.net/viggen/IC_vs1.gif
the red line is the cheapo 100eur china bar&plate IC the stock IC is on the top.
boost: http://www.stcf.net/viggen/IC1.gif
and airmass: http://www.stcf.net/viggen/IC2.gif
you can pretty much calculate the efficiency from that if you want.
I'd like to see the same data from 4" IC as comparison.
IC is one of those components that usually is sold without any measurement data, just some random like hp rantings, what does good for 1300hp actually stand for? How much is the IC efficiency aftear heat-soak on the airflows required for those HP figures ?
Offline
Old Nov 7, 2009, 08:28 AM   #14
bbyevo8u's Avatar
Quote:
Thanks!
Michael
how much could i gain from the 3.5" over the 3"?
thanks
__________________
Offline
Old Nov 7, 2009, 09:29 AM   #15
Personal Sales Rating: (26)
gsrboi80's Avatar
Drives: 03 TB VIII
35r varient here w/ ETS 3.5in core. Pull after pull, log after log, DLL after DLL no sign of heatsoaking it, enducing knock, pulled timing or power loss PERIOD
I'm sorry I don't believe the Garrett hype
__________________
4WS TUNED VIII
Quote:
Originally Posted by Evoryder View Post
Its' the turbo punching out for the day
Offline
Tags
exhaust, invidia, lancer, manifold, register
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
