Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 4, 2009, 05:53 PM   #1
Personal Sales Rating: (0)
AngryEvo8's Avatar
Drives: 2003 Evo VIII
Unhappy Coolent leaking behind crank pulley help!
So what I thought was my power steering pump idler pulley going bad turns out to be a bigger problem then I thought. The car started making a hissing noise coming from the powersteering pump side of the block. Noitced it the idler pulley was wobbly and changed it. The noise is still going strong. So I jacked up the car to try and pinpoint where this noise is coming from and notice that there is coolent coming from behind the crank pulley! Also looks like a little bit is coming from above it to causing it to run down. Here are some pics:
Vid:
Rundown on car: Stock block/head,43k all fluid changes done on time. Basic mods TBE and boost controller, intake.
It just seems like problem after problem. If this keeps up I might just have to sell the car and I really would hate to do that. Any help would be appreciated.
Offline
Old Nov 4, 2009, 05:58 PM   #2
Personal Sales Rating: (3)
ak47po's Avatar
Drives: Evo IX MR Apex Silver
Water pump.
Offline
Old Nov 4, 2009, 05:59 PM   #3
AngryEvo8's Avatar
Going out/toast lol? Wouldn't this cause the temps to skyrocket? Thanks
__________________
<<Strictly Modified>>
~~Thub Tuned~~
Offline
Old Nov 4, 2009, 06:03 PM   #4
Personal Sales Rating: (9)
wevo1985's Avatar
Drives: '03 white evo 8, '93 black eagle talon tsi awd (dd)
Send a message via AIM to wevo1985
looks to me like your waterpump is leaking. i had the same issue and went through 2 pumps in about 10k. dont know why. they both just leaked through the weap hole on the bottom of the pump. i would change it soon because it wont last long.
__________________
br hta37r, br stage 4 boltons, kelford 280 cams,jam lifters, supertech duel valve springs, ti retainers, nit valves, ported and polished runners by me, ported and polished intake and exhaust mani by me, br ported throttle body, , ross custom banodized pistons, manley i-beam rods, 100mm crank
568hp 460tq at 30psi on the stock ecu tuned by ivey!!!
Offline
Old Nov 4, 2009, 06:03 PM   #5
Silver Sponsor
Personal Sales Rating: (10)
Drives: 04 SSL
Quote:
Likely a seal issue.
__________________
-Matt
http://www.SpoolinUp.com
Check out the New DIY section.
Affordable COP Kits - Used Coils in stock!
"Performance without the Price Tag"
Offline
Old Nov 4, 2009, 06:05 PM   #6
AngryEvo8's Avatar
Seals from the side of the block?
__________________
~~Thub Tuned~~
Offline
Old Nov 4, 2009, 06:17 PM   #7
ak47po's Avatar
Offline
Old Nov 4, 2009, 07:21 PM   #8
YogSaahoth's Avatar
Drives: Silver VIII
had the same problem in august. was leaking coolant in small amounts from the exact same spot as you. I replaced my belts at the same time as the water pump but i think you can change out the pump without removing the timing belt at least. MAP has a great price for the whole water pump kit..include o-ring gasket and pump
Offline
Old Nov 4, 2009, 07:27 PM   #9
YogSaahoth's Avatar
Drives: Silver VIII
just noticed your at 43kmi, you might as well change ur timing, serp and balance belts while your in there...i did it all in one day and im no master mechanic
Offline
Old Nov 4, 2009, 10:05 PM   #10
Plat Vendor
Personal Sales Rating: (168)
maperformance's Avatar
Send a message via AIM to maperformance
Water Pump for sure. Time for a new one and YagSaahoth is right, go ahead and do a full timing belt kit while your in there.
Offline
Old Nov 4, 2009, 10:12 PM   #11
AngryEvo8's Avatar
Quote:
Alright thanks for all the great info guys!! Map you got a pm about pricing.
__________________
~~Thub Tuned~~
Offline
Old Nov 5, 2009, 02:20 AM   #12
Personal Sales Rating: (24)
moreryce's Avatar
Drives: Wicked White GSR
Damn... yep.. definelty the water pump..
The water pump has a small hole on the bottom that starts to leak coolant out if the water pump goes bad..
Check this out.. I bought a timing belt kit from them on socalevo.net since they are vendors on there. They have the timing belt kit along with water pump for $180 shipped.
http://cgi.ebay.com/ebaymotors/ws/eB...STRK:MESELX:IT
Worth a shot..
__________________
My car owes me money...
jlbmotorsports.com
aeperformance.com
Offline
Old Nov 5, 2009, 07:18 AM   #13
AngryEvo8's Avatar
Worth a shot..
Your using setup on your car? How does it compair to the oem parts?
__________________
~~Thub Tuned~~
Offline
Old Nov 5, 2009, 07:24 AM   #14
Personal Sales Rating: (27)
2005 Mitsubishi Lancer Evolution
Fast_Freddie's Avatar
Drives: '05 Tarmac Black SSL VIII
I don't know if I would use anything but OEM parts on these vital engine parts... to each their own though...
__________________
FP Red*Greddy ProfecB Spec II*HKS TT*Nesei Short Route IC Piping*Synapse BOV*COMP 272s*Injen Intercooler*AFE Power Dry Filter*R/TErnie Intake*R/TErnie FULL 3" O2 housing with V-band*R/TErnie Modified DCsports 3" Down/Test/Flexpipe with V-Band*Greddy Ti-C Exhaust*255lph*Tein S-Techs*18" Volk LE-28s*Progress 25mm Rear Sway*Project Mu pads*JDM Tails*Cusco Heat Shield*Mishimoto Radiator hoses/Cap*ARC shift knob*Injector Dynamics 1000cc...
Offline
Old Nov 5, 2009, 07:27 AM   #15
Personal Sales Rating: (21)
05blue8's Avatar
Drives: 2005 VIII
Send a message via AIM to 05blue8 Send a message via MSN to 05blue8
Pause, put the brakes on, that isn't the full kit. They're missing a critical component, the hydraulic tensioner, it's another $100 roughly.
__________________
2005 EB VIII with everything except injectors and a bigger turbo!
Thanks to Evolution Dynamics for the great work!
Offline
Tags
changing, coolent leak, crank, evo, pulley
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
