Nov 3, 2009, 09:38 PM
Personal Sales Rating: ( 7)
Drives: Evo IX
Modding a car that has been previously tuned
So I been buying some parts and just want to know if Im safe.
My car was tuned on stock boost, with a full TBE and high flow cat, and a drop in k and n filter and it was tuned to max out with no knock. (STU spec)
What I did/will do:
I took out the highflow cat (and swapped from a perrin exhaust to a hks) and replaced it with a testpipe and have not really noticed a difference in afr's (around 11.5-11.7 according to my aem wideband)... Dont know about knock as i haven't logged the car yet... is it something to be concerned about?
I'm about to put on a Perrin intake and want to know if it will be safe... will it cause knock? supposedly it doesn't mess with afr's but it does raise the boost.
i later plan on getting a licp, uicp, boost controller(@22-23 psi) and a front mount. at that point i will be getting tuned though
I just want to make sure im not going to cause any damage.
Thanks in advance
Offline
Nov 3, 2009, 10:10 PM
Personal Sales Rating: ( 16)
Drives: Audi S4
Just keep an eye of your a/f after you install the intake, it will most likely mess with your A/F.
__________________
02 s4
04 Evo VIII
04 Sti
89 CRX RIP
Building another Honda Real soon
"If your in control, you're not going fast enough"
Offline
Nov 4, 2009, 05:55 AM
Drives: Evo IX
what about knock though? supposedly according to perrin there is no change in afr
Offline
Nov 4, 2009, 06:08 AM
Personal Sales Rating: ( 12)
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
swaping intakes without at least taking some logs is not something i would advise. I always tell people to do all the mods they can before a tune, obviously, but to take it easy until the tune. No drag racing or road racing. If you have the ability i would always say take some logs and see where the car is at.
Also, before a tune, you should always do a boost leak test and compression test.
Offline
Nov 4, 2009, 11:15 AM
Drives: Evo IX
thanks for the advice. when i log though, what should i pay particular attention to?
Offline
Nov 4, 2009, 11:27 AM
Knock sum and AFRs.
Offline
Nov 4, 2009, 01:18 PM
Drives: Evo IX
Thanks, im going to check it out asap.
Right now my afr's are around 11.5-11.7 at wot and stock boost (18psi). last time i logged it i had little to no knock.
what would be safe specs for 93 octane and stock boost as far as afr and knock? I know 0 knock is ideal but just incase and does it matter where i get it in the power band. im going to do more research just to educate myself some more.
Offline
Nov 4, 2009, 07:52 PM
Personal Sales Rating: ( 3)
Drives: Silver VIII
i was in the same boat a while back. from a tune with tbe w/ hfc, cone filter, fuel pump @ 23psi, i changed to testpipe, maf pipe, ported ex mani, ss o2 housing, 3" fmic and full piping. untuned we logged 7 counts knock. i had driven it like that for a month...you should be ok just dont drive like a maniac haha..good luck
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
