Nov 2, 2009, 01:20 PM
Personal Sales Rating: ( 0)
Drives: 2005 Evo VIII
Another ACD thread...Sorry guys.
So here's a little back story for everyone.....I drove 3 hours to pick up an 05 Evo SSL for 14K. I though wow...what a motha effin deal. Anyways, I get there, and as soon as I drive the car, the 3 lights are on, but the car drove absolutely fine.
So...I talked to the seller, he said I just need to bleed the system and change some kind of banger bolt that is "on top of the transfer case/behind the motor." He reasons 99% of Evos with ACD problems have that specific leak.
What I need to know--
1. Does anyone know if that really is a common leaking problem....or was he just trying to get rid of his car?
2. How do I check the ACD oil level?
3. If it's the sensor...is there a way of knowing without diagnostics at Mitsu?
4. If it's the pump...is there a way of knowing without diagnostics at Mitsu?
5. Do I have to diagnose at Mitsu, or any mechanic will do?
Guys and gals...any help will be greatly appreciated. I still love my Evo...but I just want to get her nice and healthy without breaking the bank, ya know. Thanks in advance.
Offline
Nov 2, 2009, 02:14 PM
Personal Sales Rating: ( 91)
Drives: ix mr
excerpt from acd sticky at the top of this forum which you should have read before posting
D. ACD unit fault – 3 solid lights
When your ACD unit has all three lights on at the same time (other than at startup), this means your car is reporting back to Mitsubishi headquarters that your warranty should be voided… Just kidding. As stated in your owners manual, this denotes some kind of error in the unit and it needs to be serviced. To service the ACD you need a very special, and very expensive tool from Mitsubishi. This tool is used to engage the ACD pump to bleed the lines. You may run into this issue if you are changing out your transfercase. (6)
what this means to you: you can't bleed the system yourself
Offline
Nov 2, 2009, 03:08 PM
Any past experiences?
Offline
Nov 2, 2009, 03:10 PM
Yea...I did that. My buddy has a shop, I just talked to him, and he can bleed it with me...however, I don't want to bleed that system if it's not the problem. I just wanted to know if anyone can point me in the right direction in order to isolate the problem.
Offline
Nov 3, 2009, 05:36 PM
Drives: evo 8
acd lights
I had the same problem, i did bleed the system and the lights still came on. I took it to the dealer and they said that they had to bleed the system before they do anything else. They told me if that works ill have to pay $150 but if it doesnt that they will replace the pump under warranty.
Offline
Nov 3, 2009, 05:50 PM
Personal Sales Rating: ( 1)
Drives: 2006 Evolution MR/SE
I reset my battery and it went away, never came back
__________________
2006 Mitsubishi Lancer Evolution IX
MR SE Apex Silver
GReddy Ti-C competition TBE, Buschur intake, Hallman RX Pro MBC, Injen LICP, Erkel Tune, ACT street clutch, Stage 4 driver mod. Top Level Built/E-spec tuned FTW "get the most for your combo!"
6th Annual Evo vs. WRX/STI Day @ Etown. Stock Appearing Heads Up, 2nd place !!! 12.1 @ 113
Offline
Nov 4, 2009, 01:07 PM
Quote:
First and foremost....I"ll try the battery trick. Hopefully, that will work.
Second--so what happened..was it your pump?
Third--Thanks guys.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
