Nov 1, 2009, 10:14 PM
Personal Sales Rating: ( 0)
Drives: 03 XIII
time to play "name that thing"!
searched throttle body, throttle diagram, mikuni diagram, intake manifold, even googled.
WHAT is the item that is located on the throttle body directly below the TPS?
it has one screw holding it in place/on, you take it off, and it is a flat coil spring wrapped around a plastic shaft, with a little paddle type valve. Does it have something to do with the coolant lines going to the throttle body? it seems so, but what?
__________________
almost full MR exhaust, almost full intake, AMS FMIC, Greddy boost control & gauge, HKS 272's, Full machined head, dual springs and +1mm oversized valves. FP red, new rotors, MR O2, and a Quartermaster Clutch that is unforgiving and angry.
Tuned by KEVIND
Offline
Nov 1, 2009, 10:26 PM
Drives: 05 evo
pretty sure its you idle air control valve
Offline
Nov 1, 2009, 10:35 PM
Personal Sales Rating: ( 2)
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
see it here?
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Nov 1, 2009, 10:39 PM
Drives: 03 XIII
Quote:
Naah, I think the Idle air control valve is the one with the wire plug, three screws, and directly under throttle inlet. if removed, it is a kind of tapered seal against a hole.
Check it;
This thread:
How-To: EGR Removal VIII/IX (and charcoal/EVAP canister)
Picture six:
TPS on the bottom; three screws hold it in.
Directly above that (picture orientation) is the mystery part. Directly to the right is the idle air valve.
And then up above is the EGR valve.
it has a coolant hose entering the throttle body right near it, so.....
Cold weather choke??
__________________
Tuned by KEVIND
Offline
Nov 1, 2009, 10:42 PM
Drives: 03 XIII
BuchnerJ,
Thanks for the pic, but it is not listed!
the location is directly under #1, throttle position sensor, same side.
__________________
Tuned by KEVIND
Offline
Nov 2, 2009, 04:40 AM
Personal Sales Rating: ( 12)
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
Without a picture this thread is useless. The only parts under the TPS are the coolant nipple and ISCV.
Offline
Nov 2, 2009, 08:02 AM
Where do you see it? Circle it and im sure we can figure it out.
__________________
06 Apex Silver MR
HKS 272 Cams
Walbro 255 lph
Injen UICP/LICP
APS TV BOV
Greddy Spec-V FMIC
Megan Radiator
Excedy Twin HD/ Fly
E-85 Ethanol
Offline
Nov 2, 2009, 09:50 AM
Personal Sales Rating: ( 13)
Drives: Evo IX Race Car
Sounds like he's talking about the round disc like part with the phillips head screw in it, attached near the hard line on the middle right side.
__________________
ROBISPEC/// Xtreme Boost Metallurgy
"make yourself faster before you make the car faster, else your car reacts faster then you, thus you spin and die"
robispec.com
xtremeboost.com
Offline
Nov 2, 2009, 02:20 PM
Drives: 03 XIII
Quote:
CORRECT!
I'm at a company computer and prohibited from photobucket and the like, so I can't post a pic.
Yes, the cam shaped cover with the single phillips head screw holding it in.
__________________
Tuned by KEVIND
Offline
Nov 2, 2009, 03:06 PM
Personal Sales Rating: ( 6)
Drives: 2005 Evolution VIII
Quote:
Not true. Early Evo's, 03's and 04's had this little do-hicky in them, the 05's did not. Mikuni made a change to the TB's in 05 and eliminate this thing. If you look at a 03-04's TB it has it, the 05's don't, but still have all the casting marks from the area ready to be machined, but it was never put into them. I know this because I bought a TB from an 03 and it had it, but my 05 did not. I wondered what it was, but eventually decided to keep my 05's TB because it DIDN'T have this part in it. I just modified my 05's instead and put it back on, and eventually sold the 03's. My friends 04 has the same thing on it. Never have seen an 05 or up that has it.
I also never studied it to figure out exactly what it did, but I can imagine it is probably something having to do with the coolant passageways running through the TB because of the location of where it is. It might be a thermostat of some sort due to the spring, or a flow control valve of some sort.
__________________
Thomas..
2005 EVO GSR Charleston, SC
Offline
Nov 2, 2009, 03:20 PM
To the OP why are you asking about this? Is there a problem with your TB or are you simply curious?
__________________
06 Apex Silver MR
HKS 272 Cams
Walbro 255 lph
Injen UICP/LICP
APS TV BOV
Greddy Spec-V FMIC
Megan Radiator
Excedy Twin HD/ Fly
E-85 Ethanol
Offline
Nov 2, 2009, 04:07 PM
Silver Sponsor
Personal Sales Rating: ( 99)
Drives: Dirty EVO VIII
I think your refering to a 03/04 tb, which has this additional flapper valve that is controlled by temperature....imo, this was an attempt to get around a bad designed iac. they did away with the flapper for '05.
did yours fall out or did the flapper get melted by meth or?
Online
Nov 2, 2009, 05:01 PM
Drives: 03 XIII
Aby@MIL.SPEC, That's the mystery part I was wondering about. Thanks for the image.
Quote:
I was curious. I replaced the throttle shaft seals and while I was there, went to clean all the nasty soot and grime the EGR let build up. I cleaned off the IAC, and pulled that thing out, cleaned it, and wondered what the hell it was, since it wasn't mentioned in any of the diagrams.
If it was removed on 05 and up, that would be a good reason.
I'm still fighting with an idle issue, or, more specifically, a return to idle after high rev issue. I was trying to check all possible things.
Thanks for the input!
Now, it can only be inserted and aligned one way, but I still don't like it.
__________________
Tuned by KEVIND
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
