Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 1, 2009, 11:49 PM   #91
Personal Sales Rating: (10)
2003 Mitsubishi Lancer Evolution
huevosrancheros's Avatar
Drives: 03 Banana EVO VIII
Quote:
Originally Posted by ZFRED10 View Post
Thanks for your support. However. Could I put it on my mechanic? Sh** like this isn't just supposed to happen. Something had to be installed wrong or not correctly. I mean, I literally just got it out about two weeks ago. He was the last person to touch my transmission/clutch and flywheel.
Well, that depends entirely if the shop warranties their work. Yes, you are correct he was the last person who touched your car. The fault can be due to improper workmanship and or a faulty clutch.
I would personally tow the car to the shop were you had it serviced and let them deal with it. If they refuse or say that the clutch was at fault then you should contact SPEC and explain your case. Either way, I would sue. Its not that difficult to go out and retain an attorney. I would ask for some documentation from your mechanic stating, whether or not they warranty their work. I would also gather documentation from SPEC, stating whether they will cover it or not.
DO NOT JUST SIT ON YOUR AZZ!!! Dont let them push you around. Someone is at fault and if it SPEC then you have a good lawsuit on your hand. If shrapnel from that explosion would have made its way into the cabin your could have been seriously maimed or killed.
just remeber get as much documentation as possible and do not threaten anyone with an attorney. Do not even mention that you would seek legal counsel. In the end the element of suprise is your best tactic.
Good luck
__________________
PS3 ID: Kinikuchunks, Add ME for some Call of Duty Modernwarfare2.
KUNiiiZZZEEE Dial-IN
Offline
Old Nov 2, 2009, 12:23 AM   #92
Personal Sales Rating: (0)
hks-gst's Avatar
Drives: 98 Eclipse gsx 03 Evo VIII
Glad the owner is ok.
Could the clutch have been draging causing the flywheel to overheat and let go?
__________________
-1998 MG Eclipse GSX: built motor/head 6262hp shep stg 4 trans aem ems driven innovations IM ect..
-2003 RR Evolution: daily BP
Offline
Old Nov 2, 2009, 01:21 PM   #93
Personal Sales Rating: (86)
Jrod@Buschur's Avatar
Drives: off the road at random and hits stuff.
Good grief! Sorry to hear about the misfortune but glad to know you're ok. That definitely could have went very BAD very quickly.
Offline
Old Nov 2, 2009, 01:38 PM   #94
Silver Sponsor
Personal Sales Rating: (17)
JohnBradley's Avatar
Drives: 06 Rally Red MR
I would think if it was slipping or dragging it would have been noticeable in the break in period. Looking at it closer I am very certain it was just a stock flywheel. What did you get charged for?
__________________
SparkTech The ignition of EnglishRacing
Extreme Turbo Systems Parts to go fast with
EnglishRacing contact us-sales@englishracing.net
Home of the 522whp stock turbo/no nitrous and 1117whp 2.0L turbo record.
Old numbers- 574whp@29psi stock block, 92 octane, ETS/FP3586...New Build.
Retailer of AMR Engineering Coilovers
MAGNUS Motorsport Cast Manifolds, $1000 with ETS Magnus pipe, dual rail available also.
We choose GSC cams
FIC Master Distributor
OmniPower Dealer
Offline
Old Nov 2, 2009, 01:40 PM   #95
Personal Sales Rating: (23)
High_PSI's Avatar
Drives: 2006 GG EVOLUTION IX MR
You are lucky your car didn't burn to the ground, or maybe not cuz insurance would cover it?
__________________
EVOLUTION IX MR
Consciousness is not a bi-product of our biology; consciousness expresses itself through our biology.
Quote:
Originally Posted by KOEvo View Post
Brilliant
From what i understand, High_PSI wakes up and pisses excellence every morning.
Online
Old Nov 2, 2009, 03:11 PM   #96
Personal Sales Rating: (12)
WickedWhtMR's Avatar
Drives: 05 EVO MR
Well... here is my .02
Every clutch company has their horror stories. If he purchased a clutch kit from Spec and left it up to the mechanic to choose the flywheel for him... then I'm going to say the mechanic is at fault here.
The obvious point of failure is the flywheel. The disk is still intact. The pressure plate looks intact as well... except for the parts that were attached to the flywheel. It looks to me like the flywheel was improperly machined and simply broke apart.
You can't really point the finger at Spec. They didnt machine or sell the OP the flywheel.
As far as what I think happened goes something like this:
OP buys clutch kit. Takes it to mechanic to install. OP wants to install flywheel as well. Leaves it up to mechanic to decide what flywheel is going to be installed. Mechanic decides to go cheap so he can make the most money on the flywheel. Flywheel poops the bed.. taking a good size chunk of the car with it.
To the OP:
Im very sorry that this happened to you. I wouldnt wish this on someone I didnt like. Your lucky to be in on piece. Good Luck.. next time... pick your own flywheel.
__________________
HKS:Rs Intake/Hi Power Exhaust/272 Cams/Gears
4WS Engineering:Exhaust CutOut
4WS Tuning:Re-Flash
RevMotto:Mani Port/Exhaust housing port
Jegs:Electric CutOut Valve
Blitz:SUS Filter
Greddy:Informeter/TT
Hallman:RX Pro
MeGan:Dp
AWD Motorsports:Motor Mount kit
ACT:Pressure Plate/Flywheel/6 Puck
EBay:FMIC/O2 Housing
Zeitronix:Wideband/Egt/Boost/Meth Failsafe
SpoolinUp:Coil on Plug
Labonte: Meth Injection
Synapse:BOV
JDM Evo 9:Rear Bumper/Turbo
MUSE:LICP/UICP
Mitsu:5 Speed Conv.
Online
Old Nov 2, 2009, 07:12 PM   #97
Personal Sales Rating: (47)
CO_VR4's Avatar
Drives: 2003 Evo VIII
Looking at thost pictures makes me wonder why anyone would modify a Evo and not have a Three Speed Scattershield. Won't keep it from happening, but could save your life...
Offline
Old Nov 2, 2009, 07:15 PM   #98
Personal Sales Rating: (1)
Drives: WW Evo IX
Good luck
Why bother sueing? Its not worth it. Hes going to spend a large amount of money, just for 2 different guys to point fingers and say "no, its his fault!". With something like this, the mechanic will say its spec, spec will laugh and say it was the install. You are better off mentioning it to your mechanic, and then calling your insurance company. They should take care of it, and most likely total it.
Best of luck. Thats REALLY bad and be happy you wernt hurt. You can always get another Evo.
-Alex
__________________
BBK Full
CBRD Speedfactory FTW.
Offline
Old Nov 2, 2009, 08:32 PM   #99
Personal Sales Rating: (4)
Piro Fyre's Avatar
Drives: 2003 Evolution - Yellow
Quote:
Originally Posted by JohnDoe1984 View Post
It is probably a spec stage 3+.
I'm still skeptical about that disc. A stage 3 is 6 puck and a stage 3+ is full face carbon-metallic. What's in OP's picture looks like an organic clutch. Even though it might not be the main problem, the mechanic might have stolen your stage 3 clutch.
Offline
Old Nov 3, 2009, 09:01 AM   #100
Drives: 2003 EVO VIII
To the OP:
That is indeed very close to what happened, however, My mechanic even bought my clutch kit also. I didn't buy anything and then give it to him.
Offline
Old Nov 3, 2009, 09:04 AM   #101
Drives: 05 EVO MR
Ok..here is my next question...
Have you located the pressure plate and does it say spec on it...
Also ... if im not mistaken the disk should have an identification number... check that as well... you might find that you didnt get any of what you paid for.
__________________
4WS Tuning:Re-Flash
Blitz:SUS Filter
Hallman:RX Pro
MeGan:Dp
Synapse:BOV
MUSE:LICP/UICP
Mitsu:5 Speed Conv.
Online
Old Nov 3, 2009, 10:31 AM   #102
cmj
I'm not saying this is SPEC's fault, but I have seen this before on a Mustang. The Spec clutch and flywheel scattered send pieces up and out the hood/windshield, it took out the windshield wipers too.
Offline
Old Nov 3, 2009, 11:18 AM   #103
hotrod2448's Avatar
Drives: E92 335, E65 750
First, Glad you are alright. You are damn lucky a hunk of flywheel didn't come through the firewall at you and your passengers.
Second, it sounds like your mechanic is shady. Whether this is his fault or not to have something similar happen a few previous times is pretty messed up. The fact that it doesn't look like the clutch you asked for doesn't help his cause either. So, who is to say he wouldn't throw your old out of spec flywheel on there while billing you for a new one to make a little extra jingle.
Next, since it may or may not actually be a Spec clutch I think people should lay off them a bit or at least until it's certain it was their part actually in the car and failed. The OP needs to find out exactly what he was billed for and then find out what was really replaced especially regarding the flywheel.
Ask the mechanic if he still has your old parts laying around. Ask him for receipts from the new parts. Find out if the other stories of exploding clutches are BS or what. If they aren't this guy doesn't need to be wrenching on peoples cars. He's likely to kill someone at this rate.
I generally don't advise suing as a first option and you very well may get screwed by the parties involved finger pointing (mechanic, clutch and flywheel manufacturer) but, it doesn't hurt to know your rights. Good luck.
__________________
Born to lose and destined to fail
Offline
Old Nov 3, 2009, 01:58 PM   #104
Personal Sales Rating: (2)
buchnerj's Avatar
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
Yes, Look at the pressure plate and see if there is a serial number, or if it even says SPEC on it anywhere. This does not look like a Spec stage 3 clutch to me, but I only saw pieces, but it definitely isn't a SPEC flywheel, to me it looks like a resurfaced stocker, which could have been the problem if the machine shop didn't know what they were doing.
http://www.specclutch.com/products
See how your disc has gaps in the metal center, below the friction material and this one (spec site for 3+) does not... Ask the mechanic for the receipt or invoice from the parts he purchased. It would also be handy to have the receipt from when you paid him the money for the job. Something smells fishy with the mechanic for 1: the clutch doesn't look right and 2: it has happened to him before. If he can't provide the invoice form when he ordered the parts, ask him what site or where he ordered them from, and then call that company and ask if there was ever an order placed from him. I am really sorry to hear that this happened to you, but it seems like it could have easily been prevented if either the mechanic or machine shop weren't incompetent.
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Old Nov 3, 2009, 02:17 PM   #105
Piro Fyre's Avatar
Yeah, the shop and mechanic just ripped you off big time. That for sure isn't a Spec pressure plate nor is that even a stage 3 clutch. Even showed a friend and he can confirm that that's an organic clutch. I don't know about the flywheel but he prolly stole yours so he could sell and gave you a worn out one.
If it happened to 9 previous ppl, WHY are ppl still going to them? I would tell the community to be aware of this shop and how shady it is.
Not only would I sue them to pay for every single repair (or even the whole car for that matter), I would report them to the Better Business Bureau. They love to screw with businesses.
Offline
Tags
06, beet, clutch, dsm, dual, factory, flywheel, giant, lawsuit, licp, muse, nassert, problems, spec, zx10r
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
