Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 31, 2009, 05:29 PM   #1
Personal Sales Rating: (0)
goucho's Avatar
Drives: '06 Evo 9 MR
Boost Surging/Slipping?
So recently I have been having some boost issues that I can only describe as a surging slip. If I give it full throttle in 4th, 5th or 6th gear from ~0psi it will build up boost then "slip" for a half of second (similar to a clutch slipping) as it reaches ~18psi. It then "catches" boost and continues to function normally.
I have the Greddy Profec B-Spec II and it was tuned by AMS. I have had no problems for the past 2 years. I have tried adjusted almost everything (eg... SET, GAIN, START BOOST, LIMITER) and nothing seems to work. I know it's not the clutch slipping because it grabs fine taking off and full throttling through gears.
Also, I don't seem to have this problem in first, second or third gear; nor when I build a decent amount of boost before going WOT. It's as if the boost builds up too quickly, the EBC or ECU limits it for a second, then continues as normal.
Any thought? Advice? I've tried searching and haven't found anything directly related. Thanks!
__________________
2006 Mitsubishi EVO IX MR
[AMS TBE-HFC, Cone Filter, MAF, Greddy Profec II EBC, AMS IC/LICP, AMS Tune] 325HP, 314 TQ
MR BenEVO's Photography:http://www.photo.net/photos/goucho
MR BenEVO's Myspace:http://www.myspace.com/benegro
Offline
Old Oct 31, 2009, 06:08 PM   #2
EvoM Moderator
Personal Sales Rating: (12)
MR Turco's Avatar
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
Sounds like your clutch is slipping.
__________________
-Mike
The Rules - love them
TephraMOD V7 - now serving 25x30 fuel and timing maps and Gear Dependent Boost Control
Quote:
Originally Posted by beavis820 View Post
turco is a damn fine mechanic without me
Online
Old Oct 31, 2009, 06:37 PM   #3
goucho's Avatar
so why would it not slip when I launch or two-step? Or full boost in the lower gears? or with boost pre-built up?
__________________
Offline
Old Oct 31, 2009, 07:24 PM   #4
Personal Sales Rating: (3)
Drives: 06 EVO WW RS
Stock clutch??? How many miles?
If your clutch is starting to slip it will be more apparent in the higher gears first. Probably happens around peak torque when the most load is put in the drivetrain. Lower gears help pull the car so it may not show up during WOT runs....but it will as the clutch gets worse.
Offline
Old Oct 31, 2009, 11:20 PM   #5
Personal Sales Rating: (15)
Evo_Kid's Avatar
Drives: 01 Audi S4 (DD) 04 WW VIII RS (project/fun/track) 06 TB IX GSR (sold) 05 AS VIII GSR (sold)
Do the RPM jump up and back down?
Offline
Old Nov 1, 2009, 12:45 PM   #6
goucho's Avatar
The RPM's do not slip or jump. They do stall when the boost stalls for that brief half second.
Maybe it is the clutch... It's the stock one with 34,000 miles on it (which is a lifetime considering most people). But I have been very good about not abusing it and it still grabs good with the occasional launch. I've been looking to upgrade in the future though, so maybe it will come sooner than later.
I just want to make sure I'm not have engine/turbo issues instead.
__________________
Offline
Old Nov 1, 2009, 02:13 PM   #7
Evo_Kid's Avatar
Have you logged this?
You can take off your intake to check your turbo. also maybe wanna do a compression test and leak down test to check engine.
Offline
Old Nov 1, 2009, 02:29 PM   #8
Drives: Evo IX
What are your profec settings?
Offline
Old Nov 1, 2009, 05:22 PM   #9
goucho's Avatar
Quote:
AMS Tune Settings
Set 72%
Gain 7%
Set Gain 18.8psi
Warning 23.5psi
Warning L. 7%
Boosting ~22.5psi PEAK
__________________
Offline
Old Nov 2, 2009, 03:53 PM   #10
Personal Sales Rating: (1)
EVOLUTION9MR's Avatar
Drives: WW EVO 9 MR
Quote:
I HAVE A SIMILAR PROBLEM MY RPM JUMPS UP AND DOWN ON ALMOST ALL GEARS. EVEN IN FIRST I STEP ON IT AND IT GOES TO ABOUT 4000 RPM AND ONCE BOOST STARTS TO GO HIGHER RPM COMES DOWN AND THEN UP AGAIN. U SEEM TO KNOW SOMETHING EVO KID. PLEASE HELP. COULD IT B THE CLUTCH? REMEMBER NEWBEE HERE.
__________________
2.75" APEXI DP, 3"CATBACK, K&N TYPHOON INTAKE, GREDDY RS BOV(WASTE OF CASH).
Offline
Old Nov 2, 2009, 07:15 PM   #11
Evo_Kid's Avatar
Quote:
yes if your RPM jumps up then goes back down, you most likely need a new clutch.
Offline
Old Nov 2, 2009, 07:32 PM   #12
Personal Sales Rating: (8)
2003 Mitsubishi Lancer Evolution
cfdfireman1's Avatar
Drives: EVO IX
Famous last words.
Get the car on an open stretch of road with no traffic get the car into 5th gear at about 4K RPM and open it up, watch the Tach as you do it and tell us what happens.
Offline
Old Nov 3, 2009, 03:18 PM   #13
Drives: WW EVO 9 MR
that was my first guess but i thought to look around a bit for some help. thanks evo kid.any suggestions on a clutch?thanks.
__________________
Offline
Old Nov 3, 2009, 03:54 PM   #14
Evo_Kid's Avatar
PM me and we'll chat.
Offline
Tags
audi, clutch, s4, slipping
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
