Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 30, 2009, 05:19 PM   #1
Personal Sales Rating: (0)
Willsredix's Avatar
Drives: red evo ix
coils keep burning??? need help??
Ok so i have an evo ix and one morning i started the car and it had a huge misfire problem, checked the plugs two were bad so i replaced them. then i went to start the car and still have the misfire problem. so then i found out one of my coils was bad so i replaced them with the OKD coils, then i started the car again and one of the coils started to smoke and was really hot!!! so i think my engine wire harness might be messed up some where??
Offline
Old Oct 30, 2009, 05:57 PM   #2
Personal Sales Rating: (1)
hotdog's Avatar
Drives: 2008 Evo X
Are you running a Twin Power DLI, by chance? When mine bit the dust on my 8, it ended up being that; bypassed it and it stopped eating coils, until I replaced it. Faulty unit I'm assuming.
Of course, if you're not running one... nevermind
__________________
2008 Evo X GSR. Rally Red.
Buschur
UICP/LICP
Buschur Intake/MAF Pipe/Shield
Buschur Cat Back Bullet
Buschur Test Pipe
Buschur Shifter Bushings
Buschur Evo X FMIC
Offline
Old Oct 30, 2009, 05:59 PM   #3
Personal Sales Rating: (4)
Piro Fyre's Avatar
Drives: 2003 Evolution - Yellow
I had a coil imploded on me before. Found out it wasn't grounded properly. Check the harnesses to see if it's connected to the chassis or the block.
Offline
Old Oct 30, 2009, 06:02 PM   #4
_mcjonnyp's Avatar
Drives: evo & 240
check the harness for loose grounds, loose connections or fried relays
Offline
Old Nov 1, 2009, 05:52 PM   #5
Willsredix's Avatar
Drives: red evo ix
ya i have the HKS DLI on there but i took it off when i started to have the problem, i also started taking apart the harness everything look good and i ran new power and trigger wire not ground and it was still misfiring. i guess ill have to try the ground too! i was also thinking it could be maybe be the injector driver or maybe the ecu is taking a fart?
Offline
Tags
burning, coil, evo, misfire, plugs
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
